Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
86 registered members (830Lee, Alfred_B, aquariuscsm, 2oldtommy, 55hambone, Astro14, 7 invisible), 1,994 guests, and 34 spiders.
Topics306,103
Posts5,287,518
Members71,601
Page 1 of 3 1 2 3
Noack Variances #5428985 05/14/20 10:16 AM
B
buster Offline OP
B
Since I've been on a Noack tear lately, mostly due to having 2 GDI engines, I've noticed what others have said in the past about Noack testing having a margin of error. Noack is an approximate figure. It's not the end all, but it is something to consider. Also, companies will play games with this number and obviously choose the lowest value they can obtain.
Just for fun, here are some examples from an independent lab and the product data sheet comparisons. The data is from the YouTube channel which has been very consistent.
Amsoil SS 0w20 PDS - 8.5%
Lab Tested - 9.5%
Amsoil SS 0w30 PDS - 8.8%
Lab Tested - 9.5%
Redline 0w20 PDS - 9.0%
Lab Tested - 9.4%
Ravenol 0w20 ECS - 7.4%
Lab Tested - 7.5%
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Noack Variances [Re: buster] #5428993 05/14/20 10:23 AM
K
kstanf150 Offline
K
With the exception of the Amsoil differences
RL and Ravenol seem to be pretty dang close
That’s for the info !
Re: Noack Variances [Re: buster] #5429000 05/14/20 10:33 AM
B
buster Offline OP
B
Link to the source of the lab data.
Re: Noack Variances [Re: buster] #5429022 05/14/20 10:54 AM
Quattro Pete Offline
Did they test multiple bottles/batches or just one?
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Noack Variances [Re: Quattro Pete] #5429034 05/14/20 11:11 AM
B
buster Offline OP
B
Likely just one. That would be quite expensive I'd imagine.
Re: Noack Variances [Re: buster] #5429052 05/14/20 11:27 AM
Right, but considering bottle-to-bottle, batch-to-batch variation, in addition to the already inherent difficulty of accurately measuring Noack, it makes their test results less valuable, but better than nothing, I guess. Thanks for sharing.
Re: Noack Variances [Re: buster] #5429058 05/14/20 11:37 AM
B
bbhero Offline
B
I don't believe the variation would be all that great and worthy of much real world concern. ..
Not likely at all too see one batch with a Noack of 8.8 percent and the next batch at say 14.5 percent....
Using properly proportional weights/amounts of each base oil added to a blend would very likely produce a very highly consistent oil performance in all measurable means and testing procedures.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Noack Variances [Re: buster] #5429081 05/14/20 11:59 AM
dave1251 Offline
Within a percent I would chalk this to margin of error.
don't use.
Re: Noack Variances [Re: buster] #5429087 05/14/20 12:08 PM
B
buster Offline OP
B
Agree cheers
Re: Noack Variances [Re: dave1251] #5429103 05/14/20 12:24 PM
In which case, you can say that all of these oils tested correctly, compared to their spec sheet.
Re: Noack Variances [Re: buster] #5429121 05/14/20 12:49 PM
sloinker Online Shocked
Online Shocked
The Ravenol is within error margins. The Red Line isn't and the Amsoil is fraud. I wonder if the oil oxidzes to a degree starting immediately after blending and this affects the test?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Noack Variances [Re: buster] #5429127 05/14/20 12:56 PM
K
kschachn Offline
K
Without knowing which specific ASTM test was used and the repeatability and reproducability from that standard it is impossible to tell whether the listed numbers are equivalent to the published values. Tests like pour point, flash point and Noack generally have wide reproducibility values.
In order to be able to make a valid comparison the tests must use the same ASTM procedure, the facility must use ASTM certified test equipment, and they must follow the test exactly as written, including minimum sample size and proper data analysis. No exceptions.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Noack Variances [Re: sloinker] #5429129 05/14/20 12:57 PM
K
kschachn Offline
K
What are the margins for this test?
But before you answer that, which test is it?
1994 BMW 530i, 252K
Re: Noack Variances [Re: buster] #5429159 05/14/20 01:42 PM
B
buster Offline OP
B
ASTM D5800 was used for Noack.
The point of the post was just that there is going to be some small variation in the numbers that's all.
Re: Noack Variances [Re: buster] #5429180 05/14/20 02:17 PM
K
kschachn Offline
K
Thanks. I no longer have access to the ASTM procedures and I couldn't find a rogue copy online. There are four different procedures in the standard however (A, B, C or D) so it also matters which procedure is being used.
1994 BMW 530i, 252K
Page 1 of 3 1 2 3
