Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
88 registered members (2015_PSD, 4WD, 390pi, 2010Civic, 69Torino, 9 invisible), 2,365 guests, and 61 spiders.
Topics306,059
Posts5,286,616
Members71,593
Under Hood Inspection - Throttle Cable #5428851 05/14/20 08:32 AM
M
MasterSolenoid Offline OP
M
Was checking under the Hood for potential problems / Vehicle in Sig.
I noticed the Throttle Cable had two problems:
1) Frayed wire
2) Slack in it
This is the Cable that goes from Gas Pedal (thru Fire Wall) to Throttle Body.
Could not find on Rock Auto so I ordered from local Dealer at $32.00 (I feel a fair price)
Should have tomorrow.
I could not feel any problems with acceleration but a 'new' Cable sure won't hurt.
Just another thing to check while your hood is open.
Photo is NOT of my vehicle.
[Linked Image]
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5428855 05/14/20 08:38 AM
M
mk378 Online Content
Online Content
M
The cable always needs to be a little slack when the gas pedal is not pressed, or it's going to hold the throttle open and cause high idle speed.
After installing new cable have an assistant floor the gas pedal (engine NOT running) while you check that the throttle lever moved to the fully open position.
Re: Under Hood Inspection - Throttle Cable [Re: mk378] #5428871 05/14/20 08:47 AM
Donald Offline
Flooring the gas pedal with engine running would seem like more fun.
2015 Ford F-250 w/Powerstroke
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5428878 05/14/20 08:52 AM
A
ARCOgraphite Offline
A
Like mk378 said, there is suppose to be some slack.
Set it up so it ALMOST goes to WOT when you mat the pedal hard.
Engine OFF of course. Two people required - or a broomstick smile
Whatever slack there is after that adjustment - is supposed to be - Unless it is excessive with the new cable.
Then you may have been sold the WRONG length cable.
- Ken
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5428970 05/14/20 10:03 AM
M
M
OP here,
Some slack - YES.
But over the four inch length area of exposed cable, I get an up/down slack of one inch.
I really don't know how the Cable could stretch because it only pulls against a Spring loaded lever.
By buying OEM, I'm hoping 'it is what it is' / and all will be well.
There should be NO setting-up / adjusting …. just install.
2 Wheel Drive
3.0 Liter Engine
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5429143 05/14/20 01:19 PM
Q
Quest Offline
Q
Response:
(a ) frayed wire, no good.
(b )slack? that's normal (Allow thermal expansion, etc.)
Replace the throttle cable ASAP before it snaps on you causing extreme dangerous situ (i.e. going down the highway).
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5429167 05/14/20 01:54 PM
B
Barkleymut Offline
B
If his throttle cable snaps, I don't think that will cause an extremely dangerous situation....unless there is a semi tailgating him.
OP, you have been driving that Ranger for the last 18+ years? Cheers2 How many miles do you have on her? My dad got an 05 Ranger a couple of years ago and he loves it.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Under Hood Inspection - Throttle Cable [Re: Barkleymut] #5429174 05/14/20 02:12 PM
M
M
Dangerous situation / maybe, maybe not … But it would mean a tow home which I don't want to pay.
Yes, I've been driving it for 18 years / my only vehicle / currently 159,000 miles.
It's been a great vehicle to own because ALOT of the repairs I've been able to do myself / You-Tube is great.
2 Wheel Drive
3.0 Liter Engine
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5429207 05/14/20 03:04 PM
M
Online Content
M
It looks like there may be slotted holes for the bolts that hold down the cable bracket allowing it to move for adjustment.
Re: Under Hood Inspection - Throttle Cable [Re: MasterSolenoid] #5429221 05/14/20 03:28 PM
01rangerxl Offline
That is a good price. A lot of Ford OE parts for Rangers are not very expensive.
The throttle cable slack used to be a common topic on Ranger forums. A lot of people would do the "throttle cable mod" which was putting zip ties around the slack on the pedal end. I tried it on a truck I used to have and didn't like it because I could feel the zip tie moving when I pressed the gas and it caused a "click" in the pedal, so I cut it off. Just replacing the cable is a much better idea, especially for $32.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 239K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 203K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 256K miles
Re: Under Hood Inspection - Throttle Cable [Re: ARCOgraphite] #5429382 05/14/20 07:14 PM
CR94 Offline
Originally Posted by ARCOgraphite
... Set it up so it ALMOST goes to WOT when you mat the pedal hard.
... Whatever slack there is after that adjustment - is supposed to be - ...
Good points missed by most. In other words, you do not want the cable adjusted so tight that there's excessive stress on the throttle shaft when the accelerator is pressed all the way down hard, nor should it be set up so loose it doesn't reach WOT.
2011 Toyota Prius now at 110K
