Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
108 registered members (4WD, 330indy, 55hambone, 53' Stude, 14Accent, 1978elcamino, 9 invisible), 2,592 guests, and 59 spiders.
Topics305,938
Posts5,283,292
Members71,540
Car fire caused by oil filter? #5428675 05/13/20 11:02 PM
T
TrainingPolicy Offline OP
T
I'm not sure how many of you are active on Youtube, but a well-known Youtuber (Adam LZ) posted a video about his Ford Mustang Shelby GT500, caught on fire on track due to the oil filter coming loose and spraying oil causing an engine fire. According to the video, this is a well-known issue with this car. So, I guess we should be talking about engine oil filter torque specs now. LINK TO VIDEO: https://www.youtube.com/watch?v=zzFz5xtF47o&t=1790s
EDIT: Ford Mustang Shelby GT350 NOT GT500.
2003 Infiniti G35 6MT 104k
2005 Honda Accord 235k
2010 Hyundai Santa Fe 110k
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428685 05/13/20 11:10 PM
Z
ZeeOSix Offline
Z
Guys on the Mustang boards with the GT350 had oil filters that would often loosen up - apparently related to engine vibrations of the flat plane crankshaft. The fix was to torque to spec (of course) and then lock wire the filter to prevent it from loosening. Ford changed the oil filter from a spin-on to a cartridge filter on the later model GT350s. Apparently the GT500 still has a spin-on.
Update - I see in the video it is a GT350 ... not a GT500.
Re: Car fire caused by oil filter? [Re: ZeeOSix] #5428687 05/13/20 11:18 PM
T
T
Guys on the Mustang boards with the GT350 had oil filters that would often loosen up. the fix was to torque to spec (of course) and then lock wire the filter to prevent it from loosening. Ford changed the oil filter from a spin-on to a cartridge filter on the later model GT350s. Apparently the GT500 still has a spin-on.
Thanks for catching that, yup totally put GT500 instead of GT350.
Also towards the end of the video, he stated Ford offers a relocation kit for $500 to allow it to become a cartridge-style filter. I am super interested to see who did it, to see how it works.
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428694 05/13/20 11:45 PM
CR94 Offline
A few years ago there was a rash of fires from oil leaking from double-gasketed filters on Hondas.
2011 Toyota Prius now at 110K
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428703 05/14/20 12:30 AM
A
AC1DD Offline
A
Typical Ford...they have a design defect and instead of them stepping up and fixing it at NC they charge the customer for their error, and $500 at that...
Re: Car fire caused by oil filter? [Re: CR94] #5428741 05/14/20 05:10 AM
T
Tjbouwhu Offline
T
WASHINGTON (Reuters) - At least 27 Honda CR-V sport/utility vehicles from the 2003 and 2004 model years burst into flames shortly after getting their first oil changes, according to newspaper reports Friday...There were about 140,000 CR-Vs sold in the United States in 2003 and Honda said 22 of them caught fire from the apparent oil filter problem, the Post reported. So far this year, five owners of 2004 CR-Vs have reported such fires to NHTSA, the newspaper said.
The problem is believed to happen one of two ways: The O-ring gasket on the old oil filter sometimes sticks to the crankcase, and if the new filter is installed over it, oil can leak around it. Or, if the gasket on the new filter isn't lubricated properly, it might set incorrectly and allow oil to leak around it. Then it can spray onto the hot manifold and burn.
Tom
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428780 05/14/20 07:17 AM
A
anthonym6 Offline
A
Honda S2000s also have this problem. Most likely due to the high RPMs, and during track use they can vibrate loose. It is best to use the OE filter and torque them to the correct spec with a torque wrench. They also have a few safety devices that can be purchased from a few different companies that uses a bracket and a clamp on the filter to prevent it from coming off.
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428890 05/14/20 08:58 AM
Donald Offline
I torque filters to the max torque my 66 yr old hands can provide.
2015 Ford F-250 w/Powerstroke
Re: Car fire caused by oil filter? [Re: AC1DD] #5428901 05/14/20 09:13 AM
J
jeepman3071 Offline
J
Yup, how thoughtful of them. LOL crazy It's not like the GT350 is a huge volume seller.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428974 05/14/20 10:07 AM
R
ragtoplvr Online Content
Online Content
R
K&N filters which I so not like that much, have a nut on the bottom drilled already for safety wire.
Rod
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5428983 05/14/20 10:16 AM
J
jeepman3071 Offline
J
I guess I'm just confused about how one would safety wire a spin-on canister oil filter to not come off.
Re: Car fire caused by oil filter? [Re: jeepman3071] #5428999 05/14/20 10:30 AM
T
T
Yeah, I am thinking the same thing. Does anyone have any photos or links to one of these?
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5429042 05/14/20 11:19 AM
J
jeepman3071 Offline
J
Even with something like the K&N which has a hole already on the filter nut, I'm assuming some sort of bracket would need to be made for the engine block.
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5429053 05/14/20 11:28 AM
sohccammer427 Offline
Was there a car in that video? grin
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Car fire caused by oil filter? [Re: TrainingPolicy] #5429076 05/14/20 11:52 AM
9
928 Online Content
Online Content
9
Race guys would put a big hose clamp on the filter, tighten & then safety wire it to the nearest object-
