Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
95 registered members (2015_PSD, 2009Edge, Ag76, amblerman, 53' Stude, Alfred_B, 10 invisible), 1,901 guests, and 48 spiders.
Topics306,089
Posts5,287,201
Members71,596
Your Thoughts about a Piston Soak and Diesel Oil in Corolla? #5428475 05/13/20 06:02 PM
G
giantsforever Offline OP
G
2006 Corolla with stock 1ZZ-FE engine, 141k miles, and unknown maintenance history. Oil cap calls for 5W-30 SL. I've had it less than 1,000 miles. Piston crowns are black and only on spark plug #4 is black residue (didn't think to take a photo before cleaning it). No pinging or check engine light. Accelerates okay.
Is it wise to clean those piston tops with a piston soak? What would you recommend soaking it with?
How about using synthetic diesel motor oil, eg Chevron Delo fully synthetic 400 XSP CK-4/SN 5W-40, to clean engine internals?
Thanks
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428477 05/13/20 06:05 PM
javacontour Online Content
Online Content
Leave it alone and drive it. See if it consumes oil. Choose what you want to use for your next oil change based on what it does over the next 2-4k miles.
I'd just use a good quality 5W30 and drive the car.
network down, IP packets delivered via UPS -BOFH
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428481 05/13/20 06:14 PM
G
G
Thank you.
Can you recommend any good 5W30 synthetic oils for this car?
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428482 05/13/20 06:15 PM
skyactiv Offline
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428484 05/13/20 06:17 PM
K
Kansas_Ron Offline
K
I have had better results with a 10W30, yours may vary. With the miles on it you will have a clogged cat nearing 190,000-200,000 miles and don't forget the O2 sensors. Just drive it and monitor it and keep it topped off.
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428487 05/13/20 06:20 PM
J
JohnG Online Content
Online Content
J
You've cleaned the top of the piston, good. The real problem may be stuck rings on the cylinder. There were some really poor VII's back then that may have caused this issue. I don't know if it's a huge problem at this point, but I understand you wanting to have the engine in perfect shape.
GM made a very good soaking solution at one point for carbonized rings. I don't really think any of motor oil is going to do the job. I think it would need to be more of a solvent based solution.
I'd also make sure that the carbon was NOT coming from a rich fuel mixture in that cylinder.
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428517 05/13/20 06:59 PM
G
G
Thanks.
JohnG, what are VIIs?
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428522 05/13/20 07:09 PM
I
Imp4 Offline
I
Don't do anything to it.....yet (except maybe the plugs if they appear to be original).
The thing is, you're likely looking at 141,000 miles worth of accumulation on those piston crowns. And quite possibly original spark plugs. So it might not be a big deal at all assuming the plugs have been cleaned as you described or changed out for a fresh set.
If it drives well, gets decent mileage, check engine light is off and it doesn't consume an appreciable amount of oil, then just drive it.
You wont know if it consumes oil until you have 2k-3k+ miles on it. So just drive it for a while and monitor performance. It's quite likely that all it needs is gasoline and a regular preventative maintenance schedule.
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428531 05/13/20 07:21 PM
simple_gifts Offline
IIRC it seems the 1zz-fe burning issue was not a prevalent from 2005-7; my friend has a vibe with 160K and there is no wild consumption; i would leave it alone or use some redline or amsoil fuel system cleaner.
2004 Prius; 131K; ATM
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428533 05/13/20 07:23 PM
J
Online Content
J
VII's are viscosity index improvers. Likely are being called something different these days, like VI's or something. Older oils, like SL/non synthetics had improvers that would "coke" or burn in the ring pack forming carbon and preventing them from moving correctly.
The Northstar engine had rings very near the top of the piston, so they were subject to a lot more heat than normal. Everything was fine, except the engine oil was not up to that job back then. Today, those improvers are much better at withstanding higher temps. Unfortunately, just putting in "newer" oil will not unstick a ring pack if it is carboned up. GM made a solvent to do this job, and it worked pretty well I understand.
This is all dependent on what has caused your carbon buildup on the piston crown of course. It could be fuel for all I know.
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428570 05/13/20 08:11 PM
P
Powerglide Offline
P
You guys speak of 2006 as if it was 1976. The oils that went into that motor were more than adequate and perfectly capable of preventing the "coking" you're referring to. It's the lack of proper OCIs that caused whatever deposits may have accumulated on the Pistons, the ring packs, and the combustion chamber.
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428612 05/13/20 09:06 PM
J
jqgz Offline
J
Pull plugs, spray in an ounce of Kreen into each cylinder, and turn engine over by hand a few times to work it into the rings a bit. Allow to evaporate be careful not to hydrolock it. Then, put a bit of kreen in the oil and the gas.
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: javacontour] #5428719 05/14/20 02:30 AM
Char Baby Offline
^^^This!
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: Powerglide] #5428779 05/14/20 07:17 AM
dave1251 Online Happy
Online Happy
Great post! I believe you are hitting the bullseye.
don't use.
Re: Your Thoughts about a Piston Soak and Diesel Oil in Corolla? [Re: giantsforever] #5428782 05/14/20 07:18 AM
R
Rob_Roy Offline
R
If the engine appear to operate normally, there is no need to do abnormal maintenance. A tank or two of gas treated with your favorite injector cleaner certainly won't hurt, and a set of plugs if they are due.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
