Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
76 registered members (830Lee, 4WD, ABN_CBT_ENGR, 55hambone, 555, Al, 7 invisible), 2,115 guests, and 27 spiders.
Topics306,053
Posts5,286,514
Members71,593
Page 1 of 3 1 2 3
40:1 fuel mix in a 50:1 engine #5428372 05/13/20 04:05 PM
A
Alfred_B Offline OP
A
I just got a Poulan Pro leaf blower that requires 50:1 mix. My weedwacker is a 40:1 mix so I used the same fuel in the leaf blower until I buy a separate container.
There was no smoke or strange behavior. Is the worst thing that can happen a prematurely fouled plug? Or am I looking at a pending catastrophic engine failure?
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428375 05/13/20 04:08 PM
CT8 Offline
More oil is better.
2015 F150 2.7
2018 F350 6.2
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428379 05/13/20 04:13 PM
J
jerryg Offline
J
I mix my sthil 50-1 oil at 40-1 use in all my equipment,weed eater,blowers, chain saws. No problems in years using it.
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428381 05/13/20 04:16 PM
FowVay Offline
I have l let my Husqvarna 125B blower idle out an entire 15 ounce tank of fuel that was mixed at 32:1 and it didn't even come close to fouling a plug. These modern JASO FC/FD oils are simply amazing.
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428395 05/13/20 04:31 PM
Chris142 Offline
Run it. It will be fine.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428403 05/13/20 04:44 PM
Z
Zaedock Offline
Z
I do it all the time. My wife is using the Covid time to build a new patio/sitting area out back. We have a push leaf blower, but to get in the nooks and crannies, I just bought her a Poulan Pro PRB26 for Mom's day. She loves it. I added the 40:1 and she fired right up (the leaf blower, not the wife).
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428410 05/13/20 04:48 PM
T
tundraotto Offline
T
No problem - in fact it will be beneficial if you tune the carb properly to take advantage of the new ratio.
If you do = cooler running engine with more power.
Re: 40:1 fuel mix in a 50:1 engine [Re: CT8] #5428414 05/13/20 04:52 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Originally Posted by CT8
More oil is better.
To a point. I think the trade-off is fouling of the plug and exhaust if too much oil is used.
I use 32:1 for everything. I haven't had any fouling problems over the decades. Find a decent way to measure so you don't up with some extreme mixture.
One colleague tells me he just throws a splash of oil into the gas with his calibrated eye. This may explain why one 2-cycle mower I bought had to have the carbon chipped out of the exhaust to get it working again.
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428430 05/13/20 05:06 PM
R
ripcord Offline
R
40:1 is fine -- done it a lot when all that was available at the gas station was no-name 2 cycle oil. The rest of that unit will likely fall apart before the bottom end wears out.
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428439 05/13/20 05:17 PM
T
totegoat Offline
T
Better too rich than too lean. I keep 40:1 mixed up for my saw and 50:1 for my blower because its what they call for. I use ethanol free gasoline.
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428452 05/13/20 05:31 PM
Cujet Online Content
Online Content
There are many factors behind the lifespan of a two stroke engine. Oil ratio being one of them, more is absolutely better, with a few qualifications. It must be a quality oil, jetting and timing must be correct and quality fuel of sufficient octane must be used. Even mild detonation can greatly shorten the life of a two stroke.
The other aspect of a two stroke engine is component and build quality. The Poulan leaf blower uses a consumer grade engine, even with the use of plenty of oil, good fuel and proper jetting, it's lifespan won't match that of a professional grade engine. My 20 year old Echo is still running perfectly, even with a great many hours of abuse.
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428469 05/13/20 05:52 PM
CT Rob Offline
40;1 will be fine .Run it and forget about it. cool
2017 Toyota Tundra SR5 Crewmax 4x4 Trd offroad.Inferno Orange.All stock for now....
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428486 05/13/20 06:19 PM
O
opus1 Offline
O
The Toro dealer that sold me my snowthrower said that even though the manual says 50:1 mix is needed (and that's also stamped on the gas cap), he'd recommend using 40:1.
18 years later the thing still runs like a beast.
Don't worry about it.
Current Fleet:
2010 Hyundai Sonata GLS
2009 Chevy Cobalt SS Sedan (yes,the turbo)
2002 Dodge Dakota SXT Club Cab
1994 Ford Ranger XLT (RIP, Dad)
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428572 05/13/20 08:15 PM
Dinoburner Offline
One of the other times this was discussed on BITOG a landscaper claimed he ran 100/1 in some equipment. I`v had no problems with 50/1 in the Sthil equipment and 40/1 Yamalube in an Echo 750EVL chain saw.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: 40:1 fuel mix in a 50:1 engine [Re: Alfred_B] #5428574 05/13/20 08:16 PM
N
nwjones18 Offline
N
I'm that reckless soul running TCW3 at 50:1 in all of his OPE regardless of what it calls for ratio wise and I have never had any issues.. You will be just fine. Stihl and Poulan chain saws, Husky weedeater and Hitachi leaf blower.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Page 1 of 3 1 2 3
