Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
85 registered members (2015_PSD, 390pi, 4WD, 14Accent, 87sammy, 4 invisible), 2,342 guests, and 67 spiders.
Topics306,058
Posts5,286,611
Members71,593
Does thicker PS fluid increase pressure? #5428342 05/13/20 03:12 PM
N
NICAT Offline OP
N
Hi.
I searched forum for finding information about how oil viscosity affect Power Steering performance. But unfortunately couldnt find detailed information.
So does using higher viscosity power steering fluid make steering wheel lighter ?
Regards.
Re: Does thicker PS fluid increase pressure? [Re: NICAT] #5428344 05/13/20 03:19 PM
M
mk378 Online Content
Online Content
M
No it would not. Thicker fluid does not flow as readily and is likely to reduce the system performance, unless the pump is worn and unable to generate pressure with a thin fluid.
The degree of power assist is set up by a spring in the control valve. The driver has to put some force on the wheel before the valve allows fluid pressure to work on the piston in the rack. It is designed not to be zero effort because that would have no "road feel" and make the car difficult to control.
Re: Does thicker PS fluid increase pressure? [Re: mk378] #5428371 05/13/20 04:04 PM
N
NICAT Offline OP
N
Thanks for technically detailed answer.
So theoratically using softer spring may increase the performance ?
And how about using smaller pulley? (i do not feel any difference at higher RPMs. 600 vs 3000 rpm. . Should i ?)
Re: Does thicker PS fluid increase pressure? [Re: NICAT] #5428388 05/13/20 04:22 PM
ABN_CBT_ENGR Online Content
Online Content
Yes, no, maybe, possibly but that depends on what or how you are defining performance.
The pump can only pump to the head allowed by the RPM
Pressure is determined by resistance to the flow ( cumulative back pressure)
The control valve has a minimum pressure
Once open its basic hydraulics- fluid moves piston and transmits both ways.
So what part of that are you wanting to alter?
Re: Does thicker PS fluid increase pressure? [Re: NICAT] #5428427 05/13/20 05:03 PM
MolaKule Offline
Global Moderator
Global Moderator
Here are some files you can download to better understand hydraulic principles:
https://yuken-usa.com/pdf/special/Basic_Hydraulic_And_Components_(Pub._ES-100-2)_.pdf
https://www.hwhcorp.com/ml57000-012-ch1.pdf
https://abctlc.com/downloads/courses/HYDRAULICS.pdf
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Does thicker PS fluid increase pressure? [Re: ABN_CBT_ENGR] #5428451 05/13/20 05:30 PM
N
NICAT Offline OP
N
Thanks for answer.
What i meant by saying increasing performance was making steering wheel lighter to turn. Just thought that if some is good more is better smile
That is not criticallly important of course. Just wondered if there are any DIY method for this. Seemingly there is none
Re: Does thicker PS fluid increase pressure? [Re: MolaKule] #5428455 05/13/20 05:34 PM
N
NICAT Offline OP
N
Thanks sir smile
