Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
96 registered members (Alfred_B, 4WD, 928, AlienBug, 53' Stude, ABN_CBT_ENGR, 6 invisible), 2,391 guests, and 22 spiders.
Topics306,016
Posts5,284,888
Members71,558
C3 replace stub hubs what lube etc? #5428110 05/13/20 10:16 AM
cknight49090 Offline OP
I bought a C3 for a song a while back 79 with 99,000 miles.The guy I bought it from bought it 7 years ago for $10,000 with 93,000 and put probably$ 7,000 in repairs including a new engine 6000 miles ago.Yeah he knew nothing about cars and was just paying basic shop prices.But I bought it needing stub hubs which I bought.The old ones are wore to the point one has been rubbing the housing and the inner tires are wore.I am going to take the cover off and inspect hopefully just replace the side yokes and seals clean up the rest.Has anybody done this and could give me some insight? Also I saw some lucas gear lube at meijers buy one get one 50% off I really wasn't thinking lol but its 80/90 and claims to have posi additive already. I figure I can drain and fill later.I am thinking about adding a magnetic drain plug to the cover.I also bought lube-Guard posi additive.What do you think about the lucas and lube guard?In stead of GM posi lube?I also was thinking these stub hubs wearing like that could I avoid this by maybe using a different lube? I then thought if flat tappet cams wear why couldn't I use a little redline cam break in?
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428129 05/13/20 10:29 AM
T
Therealdusky Offline
T
Factor in replacing all bearings and clutch plates while at it. Get the eaton plates instead of the snowflake plates when you replace them.
Circlips will have fallen of and ground everything up.
Any LSD additive will do.
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428133 05/13/20 10:33 AM
I am going to tear down and inspect.Your saying to rebuild the posi right? I thought about that I wanted to upgrade your saying the eaton plates are much better?What about the springs couldn't I tighten it all up a little? I thought about a moroso brute strength is the same as oem with better internals. I was thinking about contacting them and buying the clutches and springs.
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428189 05/13/20 11:53 AM
I have it on ramps it looks like the spring has to be removed. Can I even pull the half shafts without removing anything?
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428200 05/13/20 12:11 PM
J
JeffKeryk Offline
J
I highly suggest joining the Corvette forum.
C3 Forum
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: C3 replace stub hubs what lube etc? [Re: JeffKeryk] #5428207 05/13/20 12:17 PM
Good idea thanks.
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428459 05/13/20 05:37 PM
The vette forum is ok but for the lube I still need the bitogers.Is my idea stupid to add redline cam additive to help with the wear issue?
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428536 05/13/20 07:28 PM
J
JeffKeryk Offline
J
You will find some of the best rebuilders and most experienced C3 Corvette mechanics anywhere on the forum.
From serious racers to aftermarket geeks to the purists, the information is the best anywhere for these cars.
2018 Lexus RX450h
2006 Acura TSX
Re: C3 replace stub hubs what lube etc? [Re: cknight49090] #5428657 05/13/20 10:20 PM
I don't doubt you but in regards to lubes and things of that nature I trust bitog ers ! And that's a nice C3 I have a entry level lol.I think redlines and 67 caps would set yours off.
