The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
100 registered members (97prizm, Alfred_B, ABN_CBT_ENGR, 77GrandPrix, antonmnster, 928, 9 invisible), 2,241 guests, and 33 spiders.
Topics306,106
Posts5,286,527
Members71,586
Water rights- "the miners inch" #5427793 05/12/20 11:39 PM
U
UncleDave Offline OP
U
Recently moved from Southern Cal to Northern California to an area that was basically gold rush country.
Was looking for houses when an owner mentioned she had a "half a miners inch".
I didnt expound on it at the time, but had fun looking up what it meant.
I hated the house but loved the property so I kept looking.
I also searched for properties with this special right, but settled on an acre and a half with a productive well.
I was mentioning to my neighbor that I couldn't figure out how to turn a few of the sprinklers on , and he mentioned a particular one was fed with "irrigation water" -so I called the water company and lo and behold unbeknownst to the real estate agent I'm entitled to and am plumbed to receive "a half a miners" inch of water from April till october for a flat rate.
Not sure what Im going to do with it yet, but Im tickled to bits I have this.
Never knew about the history behind this unique system of hand dug ditches, measurements and allotments.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Water rights- "the miners inch" [Re: UncleDave] #5427832 05/13/20 03:42 AM
Z
ZeeOSix Offline
Z
So what's it mean, so everyone doesn't have to research it. grin2
Re: Water rights- "the miners inch" [Re: UncleDave] #5427886 05/13/20 06:25 AM
M
maineiac Offline
M
Since you asked grin2
Do you know what a miner's inch is?
During the early settlement of western America a mining measurement was used for a short time for river, canal and ditch measurements.
By LeRoy W. Hooton, Jr.
August 26,2009
The term miner's inch seems to be an oxymoron when measuring water flow in rivers, canals and ditches. Nevertheless, during the early settlement of western America this method of measuring water used for mining operations was adopted by early engineers and farmers to measure non-mining waters. However, this method of measuring water was short-lived, but it can be found in old documents, lawsuits and decrees.
A miner's inch represents the rate of water flow in a miner's sluice through an orifice one inch square, or one-inch in diameter, through a two-inch thick plank with a head of six inches. This single orifice was limited to low flows in the range of 1.5 cubic feet per minute (11.25 gallons per minute). For hydraulic mining the standard orifice is square and the head 4 to 9 inches. This method of measuring flow may have European origins and most likely was introduced in the U.S. during the California Gold Rush years.
The statutory quantity of water represented by a miner's inch varies within the states. In Idaho, Kansas, Nebraska, South and North Dakota, New Mexico, Washington, southern California and Utah a miner's inch equals 0.020 cubic feet per second (cfs). It equals 0.025 cfs in northern Nevada, Arizona, Oregon and Montana. Colorado's unit of measurement is 0.026 cfs.
Water flow data, measured in “miner's inches” do not appear in early records kept by Salt Lake City. The City's water records are expressed in million gallons per day (mgd) and cfs. These units of measurement are interchangeable by using a conversion factor. If the flow is measured in mgd, it can be converted to cfs by multiplying it by 1.547. Or if measured in cfs, the number can be converted to mgd by dividing it by 0.646.
One of the first City recorded flow measurements appeared in the City Council minutes of August 12, 1872. Herman Schussler, Civil & Hydraulic Engineer was hired by the City to design the water system to convey water from City Creek into a piped system to serve the business district. In his report he wrote, “By an approximate gauging I found the creek to deliver in the neighborhood of ten million gallons per diem of 24 hours, which amount is far in excess of the water required.” At that time there were no flow measuring devices on City Creek, so Mr. Schussler must have used his judgment to determine the flow rate.
The first measuring device installed in City Creek occurred in 1892. A Cippoletti weir was installed at a location of the old highline diversion into a wooden tank, which would later be the site for the Pleasant Valley Reservoir.
In 1888, the City entered into an exchange agreement with the water users of Parley's Creek. The City diverted Parley's creek water into its municipal distribution system at Suicide Rock and replaced this water to the farmers from the Jordan & Salt Lake Canal. As part of the exchange agreement, two flow measurements were required during the irrigation season. In order to meet this requirement, it would have been necessary to install a measurement device. By 1906, there were 12 Cippoletti and one Rectangular weirs installed on Parley's Creek. The flow data from these devices are recorded in cfs.
An inventory of measuring devices was contained in the 1906 Annual Report of the City Engineer. In total, 34 weirs were listed measuring the stream flows of City Creek, Emigration, Parley's, Big Cottonwood and Little Cottonwood and 16 irrigation diversion ditches on Big Cottonwood Creek. Two weirs were Rectangular and the remaining 14 were Cippoletti weirs. During that year, the City Engineer reported, “It is important that the City have a record of the flow of water in the different streams which are a possible source of future water supply, as well as in the streams we draw our present supply.” This was sound advice, as during the next thirty years the City would continue to make exchange agreements with the farmers on Mill Creek, Big Cottonwood and Little Cottonwood creeks. It was noted that a weir was installed on Little Cottonwood Creek during the year. The weir was the first measuring device of record on this creek.
By 1909, according to that year's annual report, the number of measuring weirs had increased to 76 including 28 weirs on the Jordan & Salt Lake Canal.
In 1879, the United States Geological Survey (USGS) was formed by Congress. Shortly afterwards, John Wesley Powell was appointed director of the organization. His task was to make a topographic survey of the American West. Later in 1888, Congress amended the task to include identifying potential irrigation projects and reservoir sites on western rivers and streams to pave the way for increasing the population of the West. The federal government had an enormous impact on water resource measurement and engineering.
weir
Most likely, during the USGS's early history and particularly in southern California, the miner's inch was used as a means of measuring and recording flow data. However, there is no contemporary indication of this fact on the USGS' web pages. An inquiry was made to Ken Dixon, USGS Alaska Science Center Earth Science Information Center – Anchorage. Mr. Dixon checked USGS records dating back to 1898- 1920 and could not find any data recorded in miner's inches. He wrote “While I never found a Water Supply Paper that used the measurement, I managed to find a bulletin that used the miner's inch in the text from Bulletin 613 dated 1915 entitled, "Guidebook of the Western United States - Part C, The Santa Fe Route.". Mr. Dixon's cursory review of USGS documents indicates that most likely miner's inch measurements were not used after 1898.
In Utah, with statehood in 1896, a year later in 1897, the office of the State Engineer was established. The State Engineer's primary duty then was to measure stream flows, approve plans for dams and supervise state irrigation works. The position's duties were enlarged in 1901 when the State Engineer was given the authority to supervise the distribution of water. Under Utah's administrative rules adopted in 1903 the State Engineer's duties were expanded to include the receipt and approval of applications to appropriate water and to make complete a hydrographic survey of each river system. During this early period, the state quantified the rate of flow of water in cfs, and for volume the unit of acre-feet. In the State Engineer's list of definitions, the term miner's inch is defined as: “an old term for the rate of discharge through an orifice one inch square under a specific head; in Utah, it equals 0.020 cfs.”
It appears that the use of the miner's inch became obsolete early in the history of western America with the evolution of better technologies and hydrological structures capable of accurately measuring water flows ranging from small irrigation diversions to high flood stage stream and river flows. The federal government probably had the greatest influence on water measurement technology and data collection with the USGS and Reclamation Service's extensive surveys of the West's water resources. It appears that the miner's inch method of measurement was limited to a period of the early settlement of the West. However, it did provide a means to quantify early farmers' irrigation rights. This is demonstrated by the fact that 14 states established statutory standards for the miner's inch.
Today, there have been enormous advancements in measuring the nation's water. New technologies now allow real time transmission of stream flow data from over 4,200 gaging stations across the U.S. Much of this information is available via the Internet.
Re: Water rights- "the miners inch" [Re: ZeeOSix] #5427887 05/13/20 06:26 AM
B
BMWTurboDzl Offline
B
http://sacramentovalley.org/stories/half-a-miners-inch/
California has some interesting water rights laws. Basically "free" access to 11 gals a minute (or is it 5.5 gallons) of water based on water rights from the 1850's.
435i
Re: Water rights- "the miners inch" [Re: UncleDave] #5427906 05/13/20 06:59 AM
Astro14 Offline
For those of us who grew up in the East, with abundant surface and well water, the relative scarcity of water, and the associated legal framework in which water exists, is often a surprise.
Riparian Law is a big area of legal practice in Colorado, and throughout the Rocky Mountain West.
https://en.wikipedia.org/wiki/Riparian_water_rights
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Water rights- "the miners inch" [Re: UncleDave] #5427913 05/13/20 07:11 AM
Chris142 Offline
OT: Are you going to pan for gold? We do in the gully behind my house after the rains. We always find very small flour gold. I have water rights where I live. I have my own well and can use as much as I need.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Water rights- "the miners inch" [Re: UncleDave] #5427936 05/13/20 07:32 AM
B
Barkleymut Offline
B
I have often fantasized about moving to NV or CA and living a very simple life while looking for gold.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Water rights- "the miners inch" [Re: UncleDave] #5427955 05/13/20 07:51 AM
Snagglefoot Offline
Water wells around here in SE BC just north of the border beyond Idaho are unregistered and free at the moment. Pulling water from a body of water, including a creek, or river, requires a Permit from the Department of Forests, Lands and Natural Resources Operations, (FLNRO). We pronounce it Flin Row.
Canada has more fresh water than the rest of the world, combined.
If you want the job done right......do it yourself.
Re: Water rights- "the miners inch" [Re: UncleDave] #5427956 05/13/20 07:52 AM
I
izualangel Offline
I
I never knew what that term meant. Thank you. There are a lot of older neighborhoods around here that still have irrigation water. Every few days you'll see a stream running through channels between homes, down the gutters, into the storm drains. It's a remnant from those old days where people had an entitlement to irrigation water.
2006 Subaru Outback 2.5i - Mobil 1 5w-30 HM with WIX 57712
2019 KIA Forte 2.0L - Mobil Super 5w-20 with OEM filter
Re: Water rights- "the miners inch" [Re: UncleDave] #5428011 05/13/20 08:42 AM
Snagglefoot Offline
Actually, I thought you said miner’s itch. I think I know what that is. LOL
Re: Water rights- "the miners inch" [Re: Chris142] #5428018 05/13/20 08:52 AM
CT8 Offline
Over the years there have been various proposals from the state government to control the use of your well water by putting meters on wells so far the proposals have been defeated .But as property rights are being reduced it will be interesting to see what happens.
2015 F150 2.7
2018 F350 6.2
Re: Water rights- "the miners inch" [Re: izualangel] #5428019 05/13/20 08:53 AM
CT8 Offline
That is a fairly good way to irrigate. there is little impact oncost of filtering etc which is done for drinking water.
2015 F150 2.7
2018 F350 6.2
Re: Water rights- "the miners inch" [Re: ZeeOSix] #5428070 05/13/20 09:43 AM
U
U
Heres the best vid/ quick explanation I can find.
https://www.youtube.com/watch?v=Az0N1qauuds
Uncle Dave
Re: Water rights- "the miners inch" [Re: BMWTurboDzl] #5428091 05/13/20 10:03 AM
U
U
It'd be around 5.5 for me as I'm only entitled to a half an inch or about 8K a day.
Uncle Dave
Re: Water rights- "the miners inch" [Re: UncleDave] #5428218 05/13/20 12:36 PM
Z
ZeeOSix Offline
Z
Nice. thumbsup
