Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
96 registered members (2015_PSD, bbhero, Alfred_B, azjake, 55hambone, 5 invisible), 2,254 guests, and 28 spiders.
Topics306,108
Posts5,286,567
Members71,586
Viscosity Index Improver Compatibility #5427728 05/12/20 09:00 PM
O
OilUzer Offline OP
O
does the type of vii (vm) used in today's engine oil dependent upon the base oil (syn, blend of conventional)?
My question is not about which type of vii is better than others ...
basically can a company use the same vm in their synthetic as well as their dino line? Any issues with chemical incompatibility (polymeric molecules), etc.?
Re: Viscosity Index Improver Compatibility [Re: OilUzer] #5427739 05/12/20 09:12 PM
L
LubricatusObsess Offline
L
Now there's an intense question. confused
Elastohydrodynamic Lubrication makes the world go 'round!
2017 Ram 2500 - PUP 0W-40, Fram XG
2011 Chev Traverse - PUP 5W-30, Fram XG
2005 Chev Kodiak C5500 - PUP 10W-30, Fram XG
Re: Viscosity Index Improver Compatibility [Re: LubricatusObsess] #5427776 05/12/20 10:52 PM
O
OilUzer Offline OP
O
You would think plastic is plastic but I am not a chemist . what about performance? Can one kind of vm perform better in one base oil as oppose to other?
if it doesn't have a simple yes answer, it may fall under MolaKule's department LOL
Re: Viscosity Index Improver Compatibility [Re: OilUzer] #5428042 05/13/20 09:14 AM
CT8 Offline
Add packages seem similar at the price point levels and there are different qualities of Viscosity improvers.
2015 F150 2.7
2018 F350 6.2
Re: Viscosity Index Improver Compatibility [Re: CT8] #5431783 05/17/20 07:16 PM
O
OilUzer Offline OP
O
I did a bunch of search and didn't found anything as far as incompatibility ...
However, it seems like companies may use a better vii in their top oil. maybe top of the line extended oil gets a better vii but that doesn't mean it can't be used in their conventional oils. Just a guess not sure.
