Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
92 registered members (4WD, 53' Stude, 94astro, Alfred_B, 928, AlienBug, 8 invisible), 2,502 guests, and 52 spiders.
Topics306,017
Posts5,284,913
Members71,558
Page 1 of 4 1 2 3 4
2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation #5427629 05/12/20 07:14 PM
shimps1 Offline OP
I have a brand new Yukon Denali, with roughly 2000 miles. It is actually a 2019 model year, manufactured in March of 2019, so the truck sat on the dealer's lot for roughly a year prior to being sold to me.
Due to that, I want to get the first oil change done early. My gut says the oil in there is the factory fill, and having sat and been idled for a year can't be good for it. Would you all agree, or am I being overly cautious?
The owner's manual recommends 0W-20 Dexos1.2 approved oil. Given I am located in Iowa, I would like to keep that 0 weight for winter driving. I tow a 1200 lbs trailer occasionally, but that is definitely not hard for the truck, so I am not worried about that use.
I would typically go straight to Pennzoil Ultra Platinum, but it seems that it is not Dexos1.2 approved. Pennzoil Platinum is however. Should I use Platinum, or is there a better oil out there? This is a long term car, so after this oil change i plan to follow 5k intervals, regardless of the oil life indicator.
Should I stick with a GM OEM filter, or is there a better brand that others have found?
Thanks!
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427645 05/12/20 07:28 PM
N
nascarnation Offline
N
If you're a COSTCO person, they have a low price Dexos spec oil, 22 bucks for 10 quarts that's good stuff.
But Shell Gas Truck is more manly, and will make yours feel like it's got the old 8.1 liter V8!
Or you could get some 10 buck a quart boutique brand and feel like a mideast potentate.
The UPS package vans in my area have switched from Cummins 6BT diesels to GM 6 liter gas, I'd be interested in knowing what they run.
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427652 05/12/20 07:40 PM
Z
zfasts03 Offline
Z
I would change it out early. My 2016 Suburban 5.3 L83, I changed at 1000 miles (3 months since build) and had very fine visible metallic particles in the oil.
You can certainly use any 0w-20 Dexos1gen2 that you like.
I ran Mobil 1 0w-20 AFE for the first 2 changes, then went to Amsoil 0w-20 Sig. Series and will stick to this.
I am running the revised Fram XG10575 with 22 psi bypass (been out for over a year now) so all stock should be 22 psi. You can tell by looking at the bypass valve. White 22 psi, black is the old one 12 psi). Whichever filter make sure it has the 22 psi bypass. Wix/Napa Gold is a reputable and fairly priced filter with the correct bypass.
Pennzoil Platinum 0w-20 would be great as it is Dex1gen2. However, as you mentioned the Pennzoil Ultra Platinum in NOT Dex1gen2.
If I was buying off the shelf and wanted to stay frugal, in spec. and great protection I believe I would go with QSUD 0w-20.
FWIW, my engine was quiet and smooth on M1 0w-20 as well as Amsoil SS 0w-20 with no oil consumption.
The ACDelco PF63e is an ecore design that has been fine, just not one of my top picks.
By the way the Amsoil SS 0w-20 isn't a Dex1gen2 license oil, but I still like it!
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427665 05/12/20 07:52 PM
Z
zfasts03 Offline
Z
For me realistically I should run whatever is cheapest that meets spec. because it will rust out before it wears out.
- 03 Corvette Z06
Amsoil 5w-30 SS
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427675 05/12/20 08:02 PM
T
tblt44 Offline
T
Shell gas truck is good stuff.
I am running costco oil now in my Avalanche 5.3 with 183k
Just put in supertec HM in my Tahoe 5.3, just hit 200k
I'm running fram ultra in both
Ran Mobil 1 mostly, valvoline after it started to leak, also ran penzoil .castrol, Quaker state once or twice.
No real difference in any
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427709 05/12/20 08:38 PM
CT8 Offline
Any oil that meets the specs in the owners manual from a major oil company would be fine. Fram filters would work.
2015 F150 2.7
2018 F350 6.2
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427746 05/12/20 09:24 PM
K
ka9mnx Offline
K
Do EXACTLY what your owners manual says, No need (wasteful) to change factory fill early. ANY D1/g2 will work. And the factory filter is fine. Sheesh!
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427749 05/12/20 09:42 PM
B
blufeb95 Offline
B
Is Meijer a thing in Iowa, they've got their Dexos approved 0w20 on sale right now for buy one 5qt jug get one 50% off which makes it $25 and some change for 10qts if you don't have a Costco membership should be virtually the same oil both are pacakged by Warren Distribution, Also if Menards is around where you're at they might have FVP in individual quarts for $3 which in at least what I've seen is packaged by Warren as well.
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427752 05/12/20 09:49 PM
4WD Online Confused
Online Confused
The PP and OEM filter would be good as you had in mind …
they don’t really mince words in the GM owners manual over Dexos
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427759 05/12/20 10:10 PM
G
GMBoy Offline
G
First off, thank you for buying one of our Arlington Texas built SUV's!
My choice would be Mobil 1 0W/20 and any decent filter of your choice but PP is a fine choice as well! Run that oil for 5000 miles then dump...Keep it simple.
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427775 05/12/20 10:52 PM
shimps1 Offline OP
I can't find Mobil 1 0W-20 except for their AFE product, is that the one you guys are referencing?
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427784 05/12/20 11:03 PM
B
blufeb95 Offline
B
You can order extended performance from Walmart, if you order 2 jugs you can get free shipping, also right now Mobil1 has a rebate you can get $24 back for 2 jugs of Extended Performance or $20 back for 2 jugs of AFE, which makes them the same price after rebate, I'd go with extended performance, AFE is mostly GTL, EP is mostly PAO.
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427785 05/12/20 11:15 PM
3
379KITTY Offline
3
In response to one of the above posts - I was a fleet supervisor for UPS early 90's. Everything gas or diesel got bulk 15w40. May be different now.
I personally wouldn't run Xw20 in anything. Yep I'm a dinosaur and not a CAFE fan. 5w30 is as low as I'd go - 5w40 or 15w40, even 15/20w50 in severe use or old non-roller engines (which is not what OP is asking about).
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: shimps1] #5427789 05/12/20 11:28 PM
Strjock81 Offline
2016 White Town and Country Touring
2015 White Yukon XL Denali
2014 White Ram 2500 CCSB 4x4 Cummins Bighorn
Re: 2019 Yukon Denali 6.2L L86 Oil/Filter Recommendation [Re: 379KITTY] #5427791 05/12/20 11:31 PM
B
blufeb95 Offline
B
The car's brand new and thus under warranty, the manual calls for only Dexos approved 0w20 and nothing else, that's the only thing that should be put in the engine during the warranty period. I don't see the point of throwing a 15w40 or 20w50 into a modern car, the engine will last a very long time on 0w20 or even 5w30 after the warranty is over and depending on the use case 15w or 20w oil might be a terrible thing to put in a car if it's primarily used for short trips because it'll never get filtered because the bypass will always be open.
Page 1 of 4 1 2 3 4
