Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
94 registered members (AbbyMaster, 86cutlass307, 53' Stude, 830Lee, Alfred_B, akh, 3 invisible), 2,236 guests, and 41 spiders.
Topics306,053
Posts5,286,534
Members71,593
Cleaning brass #5427527 05/12/20 05:05 PM
7
762fermeandyou Offline OP
7
I have been ultrasonic cleaning brass with hot water, tablespoon dish detergent, 1:3 ratio of white vinegar. Takes about an hour. Once dry I will tumble in corncob and my brass looks new and is clean inside and out. What is everyone using to clean their brass to reload? Do store bought products work better or faster than my homemade cleaner?
62 Mercury Meteor 5.0 10w30 VPB blend / FL1A
95 Jeep ZJ 4.0 5w30 Havoline Conv / Rislone ZDDP / XG8A
15 Silverado 5.3 0w20 QSUD / PF63E
17 Explorer 3.5 N/A 5w20 Napa syn / Napa Proformer
Re: Cleaning brass [Re: 762fermeandyou] #5427528 05/12/20 05:10 PM
W
WhyMe Offline
W
started with corn cob and vibrating tumbler. went wet tumbling a few years ago. will never go back to corn cob. even real tarnished brass will look like new after a run in my wet tumbler . lemi shine and dawn and water is what i use in my wet tumbler
Re: Cleaning brass [Re: WhyMe] #5427542 05/12/20 05:29 PM
7
7
wet tumbler use pins as media?
Re: Cleaning brass [Re: 762fermeandyou] #5427565 05/12/20 05:55 PM
W
WyrTwister Offline
W
VibraShine tumbler with corncob + walnut shell .
Wyr
God bless
Re: Cleaning brass [Re: WhyMe] #5427601 05/12/20 06:31 PM
wwillson Offline
Administrator
Administrator
Ditto for me. WhyMe's formula is exactly what I do and you can't believe how clean and shiny the brass will be. Franklin wet tumbler and 5 pounds of stainless steel pins. Buy the Franklin kit that comes with the separator and buy a release magnet to pick up the pins you'll drop. I'll never ever go back to media tumbling.
Re: Cleaning brass [Re: wwillson] #5427635 05/12/20 07:20 PM
2015_PSD Offline
Same here. I built a wet tumbler from scratch and posted the information and all of the parts a while back. I use Armorall Wash and Wax, Lemishine, and S/S pins. The Armorall leaves a bit of wax behind that keeps them from tarnishing.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Cleaning brass [Re: wwillson] #5427643 05/12/20 07:25 PM
T
TurboLuver Offline
T
Same Here...
2015 Lexus GS350 F Sport RWD
2008 Civic SI
1999 GMC Suburban K2500
1997 Jeep Cherokee Country
Re: Cleaning brass [Re: 762fermeandyou] #5427647 05/12/20 07:33 PM
CourierDriver Offline
old fashion Brasso and rag
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
No matter what time it is,its always time for a nap
Re: Cleaning brass [Re: 762fermeandyou] #5427706 05/12/20 08:35 PM
R
Reddy45 Offline
R
I still use a dry tumbler for range pick up brass. It is a good "initial clean" before I deprime the cases. This prevents sand and grass and dirt from clogging up my dies.
After the primers have been removed, and case mouths flared, then I do wet tumbling to clean out the primer pockets and give them a nice shine.
Re: Cleaning brass [Re: 762fermeandyou] #5427750 05/12/20 09:46 PM
U
UG_Passat Offline
U
some of the big ammo manufacturers tumble in corn cob after they chemical clean the brass
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Cleaning brass [Re: 762fermeandyou] #5427815 05/13/20 02:13 AM
W
WhyMe Offline
W
i reload a lot of 9mm and 40 for action games. i used to use the pins and it got the inside and outside clean . i have gotten lazy and stopped using the pins on brass that is not tarnished. the outside gets clean by the cases rubbing against each other and the inside get clean enough .
i use pin for exttremely tarnished brass.
Re: Cleaning brass [Re: 762fermeandyou] #5427882 05/13/20 06:17 AM
W
WyrTwister Offline
W
For dirty range brass , I wash in warm water + liquid dish soap , until I have remove as much dirt as I can . Dry in the oven at 200F . When dry , deprime with a Lee universal de-priming die .
Wyr
God bless
Re: Cleaning brass [Re: 762fermeandyou] #5427935 05/13/20 07:31 AM
T
tc1446 Offline
T
Walnut in a vibrator shines as well or better than new brass. I have used corn cob but walnut lasts much longer.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Cleaning brass [Re: wwillson] #5428363 05/13/20 03:55 PM
7
7
Thank you. I was reading another forum and couple guys said that they experienced damage to case mouth and had to deburr/trim after tumble.
Re: Cleaning brass [Re: 762fermeandyou] #5428382 05/13/20 04:17 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I dont reload a ton yet. I do d-lead in a soda bottle, shake it a while to get the big dirt out... Then small batches in a little tumbler I have, with SS pins.
Make maybe 50 at a time so far. More manageable for me.
With kids around I never wanted to mess with corncob tumbling. Didnt want any chance of any wrong dust or residue anywhere nearby.
