I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
46 registered members (Arcoril, ArrestMeRedZ, 928, Black_Thunder, AZjeff, 77GrandPrix, 5 invisible), 1,339 guests, and 36 spiders.
Topics306,032
Posts5,285,230
Members71,566
Amsoil SVG versus Mobil1 Syn Gear Lube #5427345 05/12/20 12:53 PM
J
JerryBob Offline OP
J
Wondering if Amsoil SVG gear oil for my Toyota Tacoma (non slip locking diff) is any better than the off-the-shelf Mobil 1 Syn Gear Lube. Both are GL-5. I want to change front/rear diffs, and the transfer case, all calling for GL-5.
I guess using the LS gear oil in a non-LS diff is ok?
https://www.mobil.com/en/lubricants...roducts/mobil-1-syn-gear-lube-ls-75w-90/
https://www.amsoil.com/p/severe-gear-75w-90-svg/
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427362 05/12/20 01:16 PM
2015_PSD Offline
You will undoubtedly receive many opinions on this, but arguably Amsoil gear oil is one of the best (if not the best) on the market and I have used it with great results. I am not affiliated with Amsoil in any way--just my experience. With that said, M1 is also great oil. You may want to consider moving your viscosity up 1 level for the rear axle to 75W-110 as it was the upper viscosity that 75W-90 used to be before the SAE J306 tables were updated a while back.
PS...no issues using LS oil in a non-LS axle (only the reverse is an issue with potential clutch pack chattering).
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427363 05/12/20 01:17 PM
Donald Offline
I would think the Mobil 1 is equivalent to the Amsoil Long Life gear lube and the Amsoil SVG is a step up from the Mobil 1.
I use SVG as the cost is pretty low (when you consider quantity and frequency) and I can be confident that I have one of the best gear oils in the differential. I sleep well.
2015 Ford F-250 w/Powerstroke
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427402 05/12/20 01:47 PM
B
BAJA_05 Offline
B
Been using the Mobil 1 gear oil in my Ram in signature for the last 60,xxx miles. Great gear oil at a great price. Amsoil is really great also -- just never tried it personally in a vehicle. Did run it in my 08 Road King 103c.i. with good results.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427461 05/12/20 02:59 PM
4WD Offline
I have used Mobil Delvac 1 in three G80 lockers now and the front diffs too … $100 gets free shipping so that’s three gallons or two plus grab something else.
https://www.summitracing.com/parts/mob-122035-1
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427518 05/12/20 04:45 PM
K
kstanf150 Offline
K
I’ve used both
Amsoil is in the Mustang
M1 is in my truck
No issues with either
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427532 05/12/20 05:15 PM
dave1251 Offline
I use Chevron Delo in my truck no issues at all. If blended by a reputable blender I can't foresee any issues.
don't use.
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427595 05/12/20 06:28 PM
B
Bighorn2500 Offline
B
Amsoil SVG 75w110 in both axles on the truck.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: dave1251] #5427616 05/12/20 06:53 PM
4WD Offline
Delo XDM in the Tahoe …
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427638 05/12/20 07:23 PM
A
aquariuscsm Offline
A
I would say Amsoil Severe Gear is the best of the best. THIS is where Amsoil truly shines!!
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427697 05/12/20 08:27 PM
B
buck91 Offline
B
The only time I had an axle bearing go bad on my was running M1 75w90 in a Ford 8.8 light duty application. *shrugs*
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: JerryBob] #5427717 05/12/20 08:45 PM
L
LubricatusObsess Offline
L
Probably ok with either. I've used Mobil 1 Syn Gear Lube 75W-90 for 30 years without issue. Never did a post gear inspection or UOA, though.
Unless severely misapplied, gearboxes are pretty tough and often will die of contamination (dirt, water past seals or ingested in breather tube) 1st before any oil breakdown. In fact, CAT moved their bulldozer drivelines up in the 1980's for just this reason - too many geardrives were dying from dirt contamination past the seals, so they moved the geartrain up.
Agree Amsoil Severe Gear PAO is top in the market. I'd probably only use for a severe application - racing, overload, hot climate, etc. Otherwise M1 should be good enough. LS in non-clutch differential is ok. The other way around is not ok. Just changed my Chev Kodiak C5500 rear end @ 50,000 miles with M1. 2-1/2 gallons!
Elastohydrodynamic Lubrication makes the world go 'round!
2017 Ram 2500 - PUP 0W-40, Fram XG
2011 Chev Traverse - PUP 5W-30, Fram XG
2005 Chev Kodiak C5500 - PUP 10W-30, Fram XG
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: buck91] #5427723 05/12/20 08:50 PM
4WD Offline
I only lost the ring, pinion, spiders, bearings, and pins with Pennzoil ran from 30k to 62k …
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: 4WD] #5427733 05/12/20 09:05 PM
K
kstanf150 Offline
K
I’d call that total failure with Pennzoil !!!
Re: Amsoil SVG versus Mobil1 Syn Gear Lube [Re: 4WD] #5427738 05/12/20 09:11 PM
L
L
UOA? Never heard of this happening.
