Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
10 registered members (bachman, Char Baby, blufeb95, Silk, MrQuackers, 1 invisible), 1,153 guests, and 85 spiders.
Topics306,047
Posts5,286,363
Members71,593
Pressure Washer Hoses #5427248 05/12/20 11:09 AM
G
Gebo Offline OP
G
Can you buy pressure washer hoses that do not kink up?
I’m tired of having to stretch mine out in the backyard just Be able to take the twists and turns out of it so I can wind it back up.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Pressure Washer Hoses [Re: Gebo] #5427255 05/12/20 11:18 AM
H
hatt Offline
H
Sure. Buy some good commercial hose. I don't know what to tell you with the 1/4 inch homeowner stuff if that's what you have.
I always stretch out pressure washer hose before rolling it back up. Maybe you don't really have a problem.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Pressure Washer Hoses [Re: Gebo] #5427276 05/12/20 11:43 AM
T
tbm5690 Offline
T
Go with rubber. I have a 3/8" that I bought last year...still kinks at times but not nearly as much as the cheapo 1/4" PVC that came with the washer. It'll last alot longer too.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport & Tech
2007 Honda Shadow Spirit VT1100C
Re: Pressure Washer Hoses [Re: Gebo] #5427284 05/12/20 11:54 AM
G
Gebo Offline OP
G
Where I buy this rubber hose?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Pressure Washer Hoses [Re: Gebo] #5427317 05/12/20 12:27 PM
Hootbro Offline
Two seconds of Google foo with keywords will get you results. Big box stores like Home Depot and Lowes sell rubber pressure washer hoses. I have a couple of Goodyear branded ones that work great.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2018 Chevrolet Colorado Z71 3.6L (Dealer Bulk 5W-30)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: Pressure Washer Hoses [Re: Gebo] #5427357 05/12/20 01:12 PM
T
twouvakind Offline
T
Just put the friggin' Maxlife in and be done with it!
Re: Pressure Washer Hoses [Re: Gebo] #5427368 05/12/20 01:21 PM
R
Rand Offline
R
pvc gets stiff. they are all stiff when using.. but non-pvc much less.. when putting away etc.
https://www.amazon.com/Flexzilla-Pressure-Washer-Fittings-ZillaGreen/dp/B00K1DI42C
Re: Pressure Washer Hoses [Re: Gebo] #5427372 05/12/20 01:25 PM
N
Nukeman7 Offline
N
Try Northern Tools if there is one in your neck of the Commonwealth:
Northern Tools PW Hoses
Re: Pressure Washer Hoses [Re: Gebo] #5427413 05/12/20 01:52 PM
Chris142 Offline
Local hose supply place. They also make hydraulic hoses for tractors and such. Start there.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Pressure Washer Hoses [Re: Gebo] #5427420 05/12/20 01:58 PM
Chris142 Offline
Re: Pressure Washer Hoses [Re: Gebo] #5428809 05/14/20 07:54 AM
G
Gebo Offline OP
G
Thanks for your suggestions. Today I called a hydraulic hose place and he referred me to Cardinal rubber. I called and they got them in stock. Made in the USA.
50 ft, 100 ft, 4000 psi and up. BINGO!
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Pressure Washer Hoses [Re: Gebo] #5429501 05/14/20 10:11 PM
M
motor_oil_madman Offline
M
that's pretty normal to have to stretch them out. It takes me about 10 minutes to get mine connected and fired up. I also like to run water through the water hose before connecting it to the machine to blow out any dirt and grime. Then I connect it to the pressure washer and do the same thing with the high pressure hose. I connect it and let the water run through which is usually rusty at first because I don't want to clog the nozzle on my gun. Call me crazy. but that's how I like to do it. I don't do much pressure washing though and my hoses don't get used often. I also like to hook them up to compressed air after i'm done to blow out any water so it doesn't sit inside when not in use and rust out the hose, but sometimes I forget.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Pressure Washer Hoses [Re: Gebo] #5429503 05/14/20 10:12 PM
M
M
This also primes the pump too.
Re: Pressure Washer Hoses [Re: Nukeman7] #5432911 05/18/20 11:06 PM
M
M
Most of the good hoses are 3/8'' but the crappy hoses he's talking about are like 1/4'' and only fit homeowner model pressure washers
