e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
82 registered members (4WD, 2015_PSD, BAJA_05, 94astro, Avery4, 2010Civic, 6 invisible), 2,213 guests, and 65 spiders.
Topics306,301
Posts5,289,834
Members71,618
2019 BMW 530i - B46 Engine - Formula M 5W40 #5427246 05/12/20 11:05 AM
G
GeniePro Offline OP
G
Hello,
I've been reading about this quite a bit but I really can't really decide what oil to use for the new car. I got the car used so it doesn't have the free maintenance plan. On my 2013 F150 3.5L Ecoboost, 2011 528i - I use Mobile1 Formula-M 5W40, even though they should use 5W30, no issues - since I'm live in Houston TX - 90% of the time is hot smile.
But now the B46 engine needs 0W20 or 0W30 and I have only 17400 miles.
Based on the standard it seems that "MB-229.5" standard is more strict than "BMW Longlife-01 FE", "BMW Longlife-14 FE+".
What's your take? Anybody else using Formula M in B46 engine?
Thank you,
Re: 2019 BMW 530i - B46 Engine - Formula M 5W40 [Re: GeniePro] #5427270 05/12/20 11:39 AM
B
BMWTurboDzl Offline
B
229.5 is based on A3/B4 which has a higher min HTHS of 3.5 where as LL01FE which is based on A5/B5 which has a HTHS of (3.0 min to under 3.5). You'll gain worse FE on the thicker oil with no measurable reduction in protection for around town driving. Remember BWM specs LL01FE for the current M3/M4.
The B46 is not particularly choosy. Per BMWTIS you can run
LL01 (Based on ACEA A3/B4 as is MB 229.5)
LL01 FE (A5/B5)
LL04 (Not officially in US due to sulfur levels. ACEA C3)
LL12 FE (Not officially in US due to sulfur levels).
LL14 FE+
LL17 FE+
BMW transitioned their US fleet to "FE" oils around 2013 but the engines are designed to run on a variety of grades so don't worry too much about it.
The Formula M 5w40 as you know is marketed as a Mercedes Benz specific fill but who knows if the oil isn't the same Mobil Oil 5w40 with LL01. Just keep in mind that you're still within the factory warranty period.
435i
Re: 2019 BMW 530i - B46 Engine - Formula M 5W40 [Re: GeniePro] #5427349 05/12/20 01:02 PM
L
loneryder Offline
L
I think it's the best oil on the market but it is expensive. It doesn't list any other specs on the label because it was made for MB but if you look at the Lubrizol charts, it covers all the bases.
Re: 2019 BMW 530i - B46 Engine - Formula M 5W40 [Re: loneryder] #5427374 05/12/20 01:26 PM
G
GeniePro Offline OP
G
It's cheaper than the BMW oil smile.
Re: 2019 BMW 530i - B46 Engine - Formula M 5W40 [Re: GeniePro] #5427522 05/12/20 04:51 PM
X
xyxptlx Offline
X
I’ve only heard of one engine fail during warranty period, it was for using the wrong viscosity oil. Although it was a Duramax.
FCPeuro has Liquimoly and BMW oil Change kits. They offer free lifetime replacement, when your OCI come due send it back and they replace it. I haven’t used the free replacement but they have good customer service. They come well recommend on Bimmerpost.
Re: 2019 BMW 530i - B46 Engine - Formula M 5W40 [Re: GeniePro] #5427769 05/12/20 10:44 PM
edyvw Offline
Originally Posted by GeniePro
Hello,
Thank you,
These oils:
Pennzoil Platinum Euro 5W40 (on sale usually at AAP for $33 5qt)
Valvoline European Vehicle 5W40 (Wal Mart: $6.79 for 1qt).
Castrol Edge 5W40 (Wal Mart: $22-28 for 5qt)
Online:
Motul X-Cess 5W40
Pentosin 5W40
Pentosin Super Pento 5W30
etc, etc, etc.
Personally, I would use BMW LL01 oils, not FE oils. That engine can use pretty much anything LL.
Also, BMW updated LL01 specification in 2018 and it is very similar to MB229.5. Just get oils that have both approvals.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
