Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
92 registered members (53' Stude, Alfred_B, 97prizm, Al, 4WD, AlienBug, 8 invisible), 2,315 guests, and 32 spiders.
Topics306,016
Posts5,284,876
Members71,558
Page 1 of 6 1 2 6
Automatic Stop and Start #5426946 05/12/20 02:18 AM
R
rrretiree7 Offline OP
R
I just bought a 2016 Jeep Cherokee that turns off the engine when you stop and then restarts when you start out again. I spoke
to my mechanic and he says I will burn out my starter prematurely. Anyone know anything about it, and will it improve my MPG? Thanks guys
Re: Automatic Stop and Start [Re: rrretiree7] #5426947 05/12/20 02:22 AM
R
rubberchicken Offline
R
Yes it will improve your gas mileage around town. The more stoplights, the more the savings. Exactly how much is debatable . In my experience with Fords the starter seems a bit beefer on engines with stop start. Also the stop-start only works when the engine is warmed up, so the starting load is less than a cold engine. I would expect that there is a manual disable button that allows you to turn off that feature if it bothers you.
Re: Automatic Stop and Start [Re: rrretiree7] #5426952 05/12/20 02:46 AM
Char Baby Offline
The way that I understand it is, the starters & oiling systems are designed for this duty. Just as engines & fuel systems today, are designed to be able to withstand the lugging that the transmissions create in the name of fuel economy...IDK if I said all of that correctly but, I know what I am trying to say. It's all good!
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Automatic Stop and Start [Re: Char Baby] #5426961 05/12/20 03:19 AM
Skippy722 Offline
This is the way I understood it as well, it’s beefed up to handle the additional load, and it uses a different battery than the normal 12v that powers the rest of the vehicle.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Automatic Stop and Start [Re: rrretiree7] #5426965 05/12/20 04:12 AM
demarpaint Offline
I see you live in NYC. Once things go back to normal and we have normal traffic imo that system may drive you nuts. I won't get into any more of my feelings about the system, other than common sense indicates your mechanic is correct. Just think about it, even if the system is built to handle it, the less a car starts and restarts the less wear on the starter, and other related components. The good news is you can disable it, which is what I would do, every time I drove the vehicle. hide
God Bless Our Troops
Re: Automatic Stop and Start [Re: demarpaint] #5426977 05/12/20 04:52 AM
Char Baby Offline
I agree with that too. Even though the systems are designed/built to go the distance, they'll still wear out sooner by using them more, than using them less.
Not all Start/Stop systems can be turned off. The Jeep system may have an OFF switch, IDK but, e.g., the Chevy Equinox does not while other GM vehicles do. And this upsets some people.
Re: Automatic Stop and Start [Re: Char Baby] #5426979 05/12/20 04:55 AM
demarpaint Offline
I agree with that too. Even though the systems are designed/built to go the distance, they'll still wear out sooner by using them more than using them less. Not all Start/Stop systems can be turned off. The Jeep system may have an off switch but, e.g., the Chevy Equinox does not. And this upsets some people.
Good point about the Chevy. Then I'd look in the aftermarket for a dongle that can be plugged into the OBD2 port to disable it. If that doesn't exist I'd pass on the car, but that's just me. wink
Re: Automatic Stop and Start [Re: rrretiree7] #5426997 05/12/20 06:17 AM
M
madRiver Offline
M
He is correct it would burn out a normal starter. However vehicles with auto-start stop having starting systems not starters. They are designed for the task of increased cycles. Also remember it is much easier to start stop a hot engine then a cold start.
Our 2018 Tiguan has the system I notice a few MPG difference when temps are such that system does not engage due to extreme cold or high temps. When it is temperate like around 50-60F it seems to save fuel as engine spends its time off sitting in deep traffic.
Re: Automatic Stop and Start [Re: rrretiree7] #5427002 05/12/20 06:23 AM
Z
Zaedock Offline
Z
I don't mind the S/S system in my '19 Escape around town, but if I'm sitting on the Pike trying to get out of Boston, I turn it off because it drives me nuts.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Automatic Stop and Start [Re: rrretiree7] #5427009 05/12/20 06:30 AM
T
thooks Offline
T
We bought a new Highlander last September. It's a habit that we've gotten into to turn it off after every start. We don't even think about it anymore.
How about instead of having manufacturers develop new batteries, starters, systems and nonsense, the governments are required to come up with better traffic management plans?
Re: Automatic Stop and Start [Re: rrretiree7] #5427013 05/12/20 06:36 AM
B
BMWTurboDzl Offline
B
These systems are fairly advanced. The SS will typically not activate when the engine is cold, or outside temps are really high, etc. The starter is designed to fail at similar intervals as a traditional starter. So the "addtional wear" is moot because it does not matter if a starter fails at 190k miles vs 200k miles. Big deal.
435i
Re: Automatic Stop and Start [Re: rrretiree7] #5427019 05/12/20 06:43 AM
T
thastinger Offline
T
Does the auto S/S disable itself if the AC is on?
Re: Automatic Stop and Start [Re: thooks] #5427032 05/12/20 07:00 AM
E
ernied Offline
E
I bought a 2020 Hyundai santafe that came with stop start. I hate it drives me crazy. I turn it off as soon as I start the engine.
2015 Hyundai sonata
Re: Automatic Stop and Start [Re: rrretiree7] #5427040 05/12/20 07:08 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Traffic moves well around here. The waits at traffic lights are short. I disabled the start/stop mechanism on our BMW. Thankfully it is once and done and not reset every trip.
Start/stop is only useful when stops are longer than 7 seconds.
Re: Automatic Stop and Start [Re: rrretiree7] #5427043 05/12/20 07:09 AM
X
XCIDMigs Offline
X
https://www.youtube.com/watch?v=tBJ_J-o-drc
These systems suck in my opinion and if you want you can turn off forever.... Also most do not use anything more heavy duty on the componentsu. Whatever nonsense sales people tell you about that might need some research. I Bought a 2019 colorado after finding that 2020 was bringing a SS system which you cannot dissable easily and checked with the part department, the starter motor and battery was the same part # as the ones used in 2019. GL with yours
Page 1 of 6 1 2 6
