Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
79 registered members (Atrocious, 2015_PSD, 4WD, Avery4, b1amgm47, 7 invisible), 2,255 guests, and 67 spiders.
Topics306,299
Posts5,289,798
Members71,618
Homelite Gas Trimmer - "Experiment" #5426941 05/12/20 01:59 AM
Z
ZeeOSix Offline OP
Z
I dug out an old 2-cycle Homelite gas trimmer I had laying around. I think the last time it was used was 10~12 years ago - eek - experiment time. It ran when it was last used.
I had some pre-mixed gas so thought I'd put some gas in the empty tank and see if it would fire up. Had to pull the spark plug and "prime" it a few times, but it finally started but would only run if choked, then unchocked ... choked then unchoked. Wouldn't take any throttle. It did try to idle for a little bit. Then all of a sudden it stopped and I couldn't get it started again. Noticed that one of the rubber hoses coming out of the gas tank "popped off" - you'll see later why in the photo below. The rubber hoses still seemed pliable and soft, but after inspecting further I discovered why it stopped running ... and probably why it would only run unless choked and unchoked.
Guess I might try to find some fuel hose and a filter that will work (lots available on Amazon), and will probably have to open up the carburetor because it probably got some hose chunks sucked inside it - maybe not if I'm lucky. Amazon has tons of new carbs for weed eaters for cheap (like $10~15 for the carb, fuel hoses & filters), but I couldn't find the model number of this Homelite listed in any of the Amazon carbs being sold - I think it's about vintage 1995 (so ~25 years old!). If I need a new carb maybe I can just match up the carb mounting bolt pattern and get one not specific for this Homelite that might work -? I don't plan on spending much to see if I can get it working good again ... the rest of the trimmer is in good shape.
[Linked Image]
All the hose that was inside the tank basically disintegrated. The hose outside the tank seemed fine.
[Linked Image]
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5426968 05/12/20 04:27 AM
W
WyrTwister Offline
W
Just order the hose & filter , first . Then replace them & see if it runs OK . Before you try to replace the carb .
Best of luck ! :-)
Wyr
God bless
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5426989 05/12/20 05:55 AM
P
pbm Online Content
Online Content
P
After fiddling with 2 strokes every year I finally went to a 40V battery operated trimmer and haven't looked back.
I had the same issue with mine and couldn't get it right.
Gas operated 2 stroke trimmers are great for a guy that uses them constantly (never let's them sit)...but for a
homeowner who only uses it occasionally....I'm for battery operated trimmers.
'Journalism is Dead'
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427015 05/12/20 06:38 AM
J
JLawrence08648 Offline
J
Drain the carb, fresh gas not from your old gas can, replace the hoses, replace the 2 diaphragms in the carb.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427042 05/12/20 07:09 AM
L
LubricatusObsess Offline
L
I just did what you're doing! Mine was a Stihl Pole Saw that only gets run once in a while. Couldn't keep it running - the rubber diaphragms had age-hardened and weren't pumping gas (pulsa-jet design carb).
Dug around the net and found Stihl had changed carb suppliers from USA Walbro to Chinese outfit. Don't recall the name now. Took off this carb, and it was already a Chinese Carb (20 years old), so went on the net, found the carb number, and ordered one for $15 from Amazon. Carbs aren't worth taking apart and replacing the elastomers any longer, unfortunately. Slapped the new carb and hoses in, runs perfect.
Elastohydrodynamic Lubrication makes the world go 'round!
2017 Ram 2500 - PUP 0W-40, Fram XG
2011 Chev Traverse - PUP 5W-30, Fram XG
2005 Chev Kodiak C5500 - PUP 10W-30, Fram XG
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427160 05/12/20 09:21 AM
W
wayne50 Offline
W
With nothing to lose, take carb apart to see if any sludge buildup. Clean passages with carb spray and possibly replace the 2 diaphragms as suggested above.
I have an older Homelite ST285BC.
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427416 05/12/20 01:55 PM
Z
ZeeOSix Offline OP
Z
Does anyone know by looking at the photo which hose is fuel inlet and which one is outlet?
The hose on the left goes into where the primer bulb is, so I'm assuming that would be the fuel inlet to the carb - ?
[Linked Image]
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427515 05/12/20 04:39 PM
E
eljefino Offline
E
Sometimes weed whackers pressurize the fuel tank which forces the fuel up into the carb. That is to say, I can't answer your question. wink
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427570 05/12/20 05:59 PM
R
RyanY Offline
R
Which model trimmer is this? It's been a while since I had a Homelite 2 cycle but IIRC they had several different carbs over the years. IDing the model would help determine which carb was used and the line configuration.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5427609 05/12/20 06:40 PM
N
NormanBuntz Offline
N
I've had good luck getting hard to find OPE parts from www.jackssmallengines.com.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Homelite Gas Trimmer - "Experiment" [Re: RyanY] #5427810 05/13/20 01:30 AM
Z
ZeeOSix Offline OP
Z
It's a model ST2517 (UT20611-R) ... info from the owner's manual. The UT number is also on the tag that's on the trimmer.
Re: Homelite Gas Trimmer - "Experiment" [Re: JLawrence08648] #5427862 05/13/20 04:58 AM
L
Lubener Offline
L
That likely will solve his problem. Diaphrams stiffen up with age and will not draw the fuel in.
The "thinking" man's friend.
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5428306 05/13/20 02:28 PM
R
RyanY Offline
R
Check the diagram on page 3 of the PDF at the following link. From what I can tell the filter attaches to the right hose in your photo, and the left one goes into the tank.
Edit: this link is better. Just scroll to search for your model.
https://www.mymowerparts.com/pdf/Homelite-Parts-Manuals-For-Strimg-Trimmers/
Re: Homelite Gas Trimmer - "Experiment" [Re: ZeeOSix] #5428478 05/13/20 06:05 PM
super20dan Offline
don't waste money on this pos. desighned to be a throw away. buy a pro quality unit and it will likely last 20 years
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Homelite Gas Trimmer - "Experiment" [Re: RyanY] #5429212 05/14/20 03:10 PM
Z
ZeeOSix Offline OP
Z
Great find on the parts diagram ... thanks! Yes, you're correct ... the filter is on the fuel intake hose, which would go to the right top fitting on the carburetor in the photo I posted.
It looks like there were two different brands of carburetors used on this model. Just looked at mine and it says "ZAMA" on the carb, so that might help me find a new carb assembly for cheap on Amazon if I decide to go that route (using the model number of the ZAMA carb in the parts info). I might just buy some hose and a filter for like $8 and try that first. Don't plan on spending much to see if I can get some use out of it. It's in good shape besides the fuel lines rotting away.
Update - found this ZAMA C1U series carb rebuild kit for $6.58. Looks like the right one ... says it fits the C1U-H18A which is what the parts diagram shows.
https://www.amazon.com/HIPA-Carburetor-Rebuild-Diaphragm-Homelite/dp/B00X43EB0U/
