Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
79 registered members (aquariuscsm, BlueOvalFitter, 2011335d, ABN_CBT_ENGR, 830Lee, 7 invisible), 2,134 guests, and 61 spiders.
Topics306,090
Posts5,287,253
Members71,596
Page 1 of 3 1 2 3
Toyota 1MZ-FE, original timing belt at 292k #5426912 05/12/20 12:01 AM
G
getawheel Offline OP
G
2003 Highlander 1MZ-FE VVT-i, 292,511 mi, all factory timing components. I was surprised to see how good the belt looked. A testament to quality parts, I take back anything negative I’ve ever said about Toyota.
[Linked Image]
The water pump did not have long left, it was not making noise but turned quite rough by hand, bearings were shot. It had a couple months, tops. Glad I finally convinced the owner to do the job. We replaced the belt, water pump, tensioner and pulleys with OEM parts. Also did spark plugs (NGK Iridiums), PCV valve, ATF change (MaxLife), PS flush and obviously new coolant (Pentosin A1).
We’ve been maintaining this car for years but it’s impossible to get the owner to come in on time. It had 13,500 miles, 7 months on the last oil change I did (HK conventional), dipstick was dry. I filled it with M1 HM 5W-30 this time, rear main seal was dripping but the engine was dry otherwise. Maybe the M1 will slow the leak down, if it gets worse it’ll make no difference as I’d have ended up resealing the engine anyways. I’ve had good luck with M1 HM before so we’ll see.
1993 Ford Mustang 2.3L/5-speed, 32k
2002 Ford Ranger 3.0L/5R44E, 254k
2002 Honda CR-V AWD 2.4L/5-speed, 169k
2006 Jaguar XJ8 Vanden Plas 4.2L, 103k
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5426933 05/12/20 12:55 AM
B
BlakeB Offline
B
Looks good! Did you also use Maxlife for the PS fluid?
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5426937 05/12/20 01:16 AM
ctechbob Offline
And here I felt bad letting my Accord go 128,000 on its timing belt, although much like that Toyota, it came out looking like it could go another 100k.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5426938 05/12/20 01:23 AM
daves87rs Online Content
Online Content
Nice!
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier (project)
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5426998 05/12/20 06:17 AM
diyjake Offline
I am surprised you decided to a do a timing belt job on a car that with that many miles and a customer that lets their dipstick run dry, sounds like that motor might not have much life left.
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5427053 05/12/20 07:18 AM
supton Online Content
Online Content
Sounds like it gets a lot of driving, so it's probably hit the magical spot for longevity. Few cold starts, few temp cycles. Lots of rotations on the bearings but maybe it all just got the right amount of usage over time so as to maximize life.
Not bad. Not for me but it sounds like the owner has it figured out to a T. Risky business but maybe they also don't care--when it breaks, they figured they have their monies worth already, so why bother worrying about it? Run it till she blows. Not my style in cars but I certainly have done that for push mowers...
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: supton] #5427072 05/12/20 07:44 AM
B
bbhero Offline
B
I may well be wrong here...
Is this a non interference motor??
Well looked it up.. it is a interference motor...
Yeah... Not good to wait on that timing belt...
I'm glad it didn't break on ya.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: bbhero] #5427121 05/12/20 08:38 AM
L
LotI Offline
L
Even a non-interference motor can break things when the belt goes. The valves may be ok but the belt goes somewhere.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
19 Buick Regal TourX
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5427141 05/12/20 09:02 AM
Char Baby Offline
Toyota/Lexus OE timing belts & parts in most of their vehicles(I say most 'cause IDK every single one), are frikken awesome. I've seen'em w/250k that looked almost new.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5427257 05/12/20 11:19 AM
T
twoheeldrive Offline
T
Quality parts for sure.
When I changed the belt on my Toyota V8 after 18 years and 90,000 miles, the belt was fine, not worn, no cracks, but the tensioner had seized up.. The belt was still fairly tight, but probably would have loosened up over time.
... using Mobil 1 since 1976.
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: supton] #5427268 05/12/20 11:37 AM
G
G
Nope, used bulk AAP/CarQuest Dex/Merc ATF
It runs great and the car is in decent shape otherwise, I figured it was worth it. This owner has had the car since 40k and their maintenance practices haven’t changed a bit. I’m trying to get them to do more regular maintenance. It did have some oil in it, probably just under 4 quarts. If I could change it at 5k-7500 it wouldn’t ever get low.
This is a tough one to figure out. The owner pays to have anything fixed when it breaks, but does no preventative maintenance whatsoever. I can’t explain it. It would be far cheaper in the long run to do regular fluid and filter changes and other maintenance items.
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5427271 05/12/20 11:39 AM
slacktide_bitog Online Content
Online Content
Toyota makes the best cars happy
Working on the 1MZ is scary and difficult, which is why people put it off. I hope you replaced the valve cover gaskets too smile
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5427411 05/12/20 01:51 PM
G
GSCJR Offline
G
My co-worker changed his at just shy of 300k Kms. on his 1995 Camry but I chickened out and replaced mine several years ago at 185k Kms on my 2003 Highlander. I only replaced the timing belt and serpentine belts. Sold it last year with original timing components and water pump. This one trumps my story getawheel!
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: getawheel] #5427436 05/12/20 02:27 PM
P
painfx Offline
P
The owner must have been ignorance or cheap. This is an interference engine. One snap it is game over. Looks like he got lucky.
Re: Toyota 1MZ-FE, original timing belt at 292k [Re: painfx] #5427441 05/12/20 02:35 PM
K
kschachn Online Content
Online Content
K
No it is not an interference engine. I have changed timing belts on numerous 1MZ-FE engines and you can rotate the crankshaft with the cams in any position.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Page 1 of 3 1 2 3
