Walmart closing all Tire and Lube Expree in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
100 registered members (53' Stude, Alfred_B, 2010Civic, ABN_CBT_ENGR, 94astro, AlienBug, 11 invisible), 1,910 guests, and 39 spiders.
Topics306,088
Posts5,287,179
Members71,596
1982 Honda 185S 3 wheeler #5426833 05/11/20 09:12 PM
M
mobilaltima Offline OP
M
For a friend of mine, needed some work so we made a deal that if I fixed it I could use it whenever I want and I've been using it alot, runs great after a new carb and intake boot. I've been using 10W40 wet clutch oil, which I think is Honda spec, I don't run it hard, mostly on trails, but I do like to open it up in 5th gear every now and then. Should I step it up to a 20W50 wet clutch oil, or would it be too thick? I'm thinking Valvoline Motorcycle 20W50....and should I stay conventional or go with synthetic? Was thinking Mobil 1 4T 10W40 or Mobil 1 V Twin 20W50 if I go with synthetic.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5426847 05/11/20 09:30 PM
CT8 Offline
If you don't run it hard the 10W-40 would be fine . The 20w-50 wouldn't hurt at all .
2015 F150 2.7
2018 F350 6.2
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5426908 05/11/20 11:26 PM
Chris142 Offline
Those ran decades on dirty 10w40. Don't over think this.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5426928 05/12/20 12:46 AM
E
ecotourist Offline
E
Seems to me 3 wheel ATVs had a problem on rough trails. If you were tipping to either side, you would automatically put your foot down to regain your balance, and the back wheel would run over your foot and drag you off.
I'd be really careful on rough trails. There's a reason you don't see them around much any more.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: 1982 Honda 185S 3 wheeler [Re: ecotourist] #5427021 05/12/20 06:46 AM
T
thastinger Offline
T
You won't find this on any "rough trails" because the only suspension on it is the tires.
Re: 1982 Honda 185S 3 wheeler [Re: ecotourist] #5427077 05/12/20 07:49 AM
Chris142 Offline
That is dirt bike guys thar have never riden one. You need lots of body english to ride one properly. I used to race them lol
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5427089 05/12/20 07:59 AM
N
Normac Offline
N
IIRC, back then Honda spec'd their 10w30 and 10w40 in almost everything. I'd run a Xw40 and forget about it.
Those things will run for years on end with anything you put in them.
Seeing as how your down South, I'd run Rotella (or your favorite flavor of) 15w40 and enjoy the heck out of it.
True victory does not come from defeating an enemy, true victory comes from giving love and changing an enemies heart.
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5427149 05/12/20 09:12 AM
sunruh Offline
i remember when the 185 came out.
yes practially anything today is better whan when that was new.
i remember the very 1st 3wheeler i saw...my friend got an Honda ATC 90. that was the 1st model made.
then the 70, then 185 and finally the 250r
my brother had the yamaha tri-moto 125 and then the 225dx
and you should know, a 3 wheeler is illegal anywhere except private land.
motorcycle oil myth buster
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5427187 05/12/20 09:52 AM
dblshock Offline
have a couple ES200 '84 200 Big Red shaft drives, I'll run any W40 usually a 15W40...just dug them out for the season here, although seldom used I keep them on.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5427225 05/12/20 10:42 AM
J
joekingcorvette Offline
J
I had a couple of them and they are a blast.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5428630 05/13/20 09:37 PM
dblshock Offline
[Linked Image]
2010 most recent pic I took of the 200ES twins.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 1982 Honda 185S 3 wheeler [Re: dblshock] #5428635 05/13/20 09:42 PM
4WD Offline
Yeah … had a boss crack ribs on one of those … Y’all be careful now …
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5428639 05/13/20 09:45 PM
dblshock Offline
oh I'm aware owned these for 27yrs.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 1982 Honda 185S 3 wheeler [Re: mobilaltima] #5429529 05/14/20 11:14 PM
dblshock Offline
what I understand is that these old 3 wheeler's are actually more capable than my Rincon, Rubicon or Foreman's..however you must accept a slower pace and even get off and walk them in certain situations, learn to use a rope and capability becomes amazing, far beyond the ATV or SXS golf carts that have become so popular.
we ford deep rivers and get into impossible situations like many, conquering adversity in the wilderness is a big part of the recreation, with tolerance, ATC's can tag along with a well equipped ATV.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 1982 Honda 185S 3 wheeler [Re: sunruh] #5430476 05/16/20 08:25 AM
cronk Offline
This is incorrect. They are illegal to make and sell new. You can still use them as you would any atv.
I used to own a couple and had one of them legally registered with liability insurance.
This was in the nanny state of New York even!
I still see some on the atv trails when I ride.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
