I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
37 registered members (ArrestMeRedZ, 2009Caraman, AZjeff, Blkstanger, blufeb95, Arcoril, 2 invisible), 1,214 guests, and 22 spiders.
Topics306,032
Posts5,285,231
Members71,566
Front Axle Ring Gear Rotation Direction? #5426398 05/11/20 01:08 PM
2015_PSD Offline OP
This may seem like a silly question, but the forest and the trees have merged. crackmeup
The rear axle ring gear rotates towards the front of the vehicle, picking up oil from the sump and slinging it over the top of the pinion gear from the top of the ring gear.
Since the from axle is installed "backwards" does its ring gear pick up oil from the sump and sling it under the bottom of the pinion gear from the bottom of the ring gear OR does it rotate the same as the rear axle (towards the front of the vehicle)?
Try not to laugh too hard when reading/answering.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Front Axle Ring Gear Rotation Direction? [Re: 2015_PSD] #5426408 05/11/20 01:17 PM
wwillson Offline
Administrator
Administrator
The front ring gear rotates in the same direction as the rear ring gear. The "front ring gear picks up oil from the sump and slings it under the bottom of the pinion gear" - correct
Re: Front Axle Ring Gear Rotation Direction? [Re: wwillson] #5426419 05/11/20 01:21 PM
4WD Offline
Which is the easiest route and a lower capacity gets the job done …
It also forms a “viscous coupling” …
Re: Front Axle Ring Gear Rotation Direction? [Re: 2015_PSD] #5426423 05/11/20 01:26 PM
2015_PSD Offline OP
Ah--that is what I thought and now that I am about to install the "permanent" axle covers, I may need to rethink the temperature sensor probe location for the front axle. I am not sure enough oil will be slung towards the upper part of the axle cover to capture a reading, but then again, I need to spend some time off road in 4x4 mode to see since it has a front axle disconnect which prevents the axles and drive shaft from turning in 4x2 so the oil is not moving anyway.
Thanks guys!
Re: Front Axle Ring Gear Rotation Direction? [Re: 2015_PSD] #5426557 05/11/20 03:54 PM
Z
Zaedock Offline
Z
There are channels cast in to the housing that help channel gear oil to the pinion bearings (primarily the outer). These channels are especially important in High Pinion front axles, such as the custom Ford unit in the front of my Jeep. Also, while the ring gear does a lot of slinging, the carrier is also spinning and throwing the goo.
Regarding pinion lube, if you could draw a line from the fill plug straight back, the pinion would likely be partially submerged in gear oil as well, on a low pinion axle.
I just checked the Sterling in my truck and the Fill plug is quite a bit higher than the pinion centerline.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Front Axle Ring Gear Rotation Direction? [Re: Zaedock] #5426571 05/11/20 04:15 PM
2015_PSD Offline OP
This is a good idea, I will check mine. I have been reading quite a bit about low pinion vs. high pinion. In the end, the oil may actually be capable of being slung onto the temperature probe but with the front axle disconnect I will not be able to see that until I'm off road.
Re: Front Axle Ring Gear Rotation Direction? [Re: 2015_PSD] #5426599 05/11/20 04:42 PM
ABN_CBT_ENGR Offline
Thanks guys!
If I may, what exactly are you wanting to accomplish or measure and then to what purpose?
Might be able to assist if I understood better. I have designed many gear drives and installed all kinds of sensors- depends on what the metric is that determines what sensor and where it needs to go
Re: Front Axle Ring Gear Rotation Direction? [Re: ABN_CBT_ENGR] #5426648 05/11/20 05:52 PM
2015_PSD Offline OP
Thanks guys!
Axle fluid temperatures; the rear works fine, but the front has not posted any numbers yet. However, that was expected, because the FAD disconnects the driveshaft and axles so there is no fluid moving.
I wanted to confirm which way the ring gear rotates so in the event after I do a 4x4 drive off-road for several hours I do not have a reading then is due to the path oil takes and I will need to consider a different location for the sensor.
Re: Front Axle Ring Gear Rotation Direction? [Re: 2015_PSD] #5427262 05/12/20 11:23 AM
F
Fattylocks Offline
F
Thanks guys!
Sounds like a plan. Let's go!
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
