Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
104 registered members (55hambone, 2015_PSD, 4WD, 390pi, 2010Civic, 10 invisible), 2,526 guests, and 33 spiders.
Topics306,060
Posts5,286,630
Members71,593
Napa Premium Brake Rotors w/ Graphite Guard #5425911 05/10/20 10:11 PM
N
NASTI Offline OP
N
Has anyone had any luck using these? Are they made by BPI? Just found out that some newer applications (2010+) have this graphite coating on the hats and phosphate surface finish on them now.. Curious to see how well the coating holds up in rain or salty winters.
[Linked Image from napabrakes.com]
FEATURES AND BENEFITS
Features and Benefits
All NAPA® Brakes Premium™ Rotors feature:
Consistent with OE in heat dissipation, stopping distance, brake fade, rotor and friction wear and noise suppression
OE-matched air gap, plate thickness and vane configuration
CNC mill-balanced for optimal weight distribution and consistent performance
Non-directional finish removes peaks and directional lines
Manufactured to SAE G3000 standard and machined to the tightest tolerances
12 month/12,000 mile warranty
2010 and newer applications now include:
Graphite guard: Provides corrosion protection to critical areas of the outside of the rotor hat and plate edges. Graphite Guard is robotically applied and tests to withstand 120 hours of salt spray exposure.
Phosphate Finish: Allows for better adhesion of the Graphite Guard and produces an attractive appearance on the disc plate surface.
Upgraded packaging
https://www.napabrakes.com/products/rotors/premium.html
https://www.youtube.com/watch?v=-8k31_6Z14Q&t=2s
2005 Subaru Impreza WRX STI
2015 Audi S3
2008 Lexus RX350
2000 Lexus ES300
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: NASTI] #5426083 05/11/20 07:32 AM
B
buck91 Offline
B
Hmm, also curious about this and whether its any better than any other e-coat. Ran the Raybestos element3 rotors with their proprietary fusion 4.0 coating on our explorer for two winters. Held up just fine over that short time. Running the zinc coated PowerStop rotors on my F150 right now, but they have seen less than one full salt season at this point so its hard to comment.
I did run the Frontline rotors from Advance Auto with the e-coat on my truck for about 5 years and they held up pretty well in the salt belt here. Not perfect, but pretty dang good!
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: NASTI] #5426127 05/11/20 08:26 AM
G
Gebo Offline
G
All I know is I had a poor experience with the Napa brake rotors I bought for my 2002 4Runner.
They lasted about 6 months and I got the shudders again.
I may have just got some bad ones. IDK??
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: Gebo] #5426170 05/11/20 09:09 AM
K
kschachn Offline
K
If you're getting vibration after only six months that could indicate a problem other than the rotors.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: NASTI] #5426184 05/11/20 09:18 AM
G
Gebo Offline
G
Could be but the new rotors I replaced them with have lasted about 5 years with no shudder problems. That's all I know. shrug
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: NASTI] #5426206 05/11/20 09:44 AM
doitmyself Offline
Well, their Ultra Premium rotors claim 300 hour salt test, so your 120 hour salt test rotor is a lower quality product for corrosion resistance according to their marketing. https://www.napabrakes.com/products/rotors/ultra-premium.html
There are lots of past discussions about coated rotors here. I do not think we ever came to any conclusions. Some think that the NAPA product is supplied by Raybestos. Maybe the ultra premiums are the Raybestos specialty rotors with a complete coating....it has been suggested before. The Premiums have just the hat and edges protected. The ultra premiums have 100% protection (inside the vanes, etc.).
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: doitmyself] #5426213 05/11/20 10:02 AM
Donald Offline
Inside the vanes would seem to be important. That is about the only place where if severely rusted could cause one to toss a rotor for rust alone.
2015 Ford F-250 w/Powerstroke
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: Gebo] #5426227 05/11/20 10:12 AM
diyjake Offline
I had the same exact issue with cheap rotors (brakemotive).
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: NASTI] #5426782 05/11/20 08:24 PM
H
Hysilver Offline
H
I've used the ultra premiums with the black painted hat and vanes. The vanes rusted rather quickly, but the rotors are still in use years later. Such a dirty environment and many hot/cool cycles that I can't imagine any kind of coating lasting long.
Re: Napa Premium Brake Rotors w/ Graphite Guard [Re: Gebo] #5427034 05/12/20 07:01 AM
L
Lubener Offline
L
More likely calipers, even the best rotors will warp when overheated or run through a deep puddle.
The "thinking" man's friend.
