Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
80 registered members (Astro14, bbhero, AdRock, 340_Magnum, alchargo, 6 invisible), 1,623 guests, and 29 spiders.
Topics306,112
Posts5,287,757
Members71,602
What are other uses for Type F Transmission Fluid #5425807 05/10/20 07:47 PM
T
Tygrant Offline OP
T
What other uses are there for type F transmission fluid other than power steering in my old explorer? I was given a few gallons of type F transmission fluid. It won’t work in our Honda or 2019 F-150. Thought there might be other things I could use it for and ideas?
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425811 05/10/20 07:49 PM
danez_yoda Offline
it cleans well. i use ot for teleflex cables in my boat. pump some down ther to loosen dried up grease and make steering much easier.
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425814 05/10/20 07:52 PM
W
Wolf359 Online Content
Online Content
W
I think the mix for a good lubricate is automatic transmission fluid and acetone. I guess type F still qualifies as transmission fluid.
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425829 05/10/20 08:07 PM
K
kstanf150 Offline
K
Drag racer guys love Type F
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425861 05/10/20 08:44 PM
R
Rand Offline
R
80's deere tractors specifically the 316 and 318
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425864 05/10/20 08:53 PM
Chris142 Offline
Soneone was looking for some a day or 2 ago.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425950 05/10/20 11:28 PM
CR94 Offline
My Mazda specified Type F for the transaxle.
I've used it to thin #90 gear oil for use on bicycle chains.
I may have also used it in a hydraulic jack.
2011 Toyota Prius now at 110K
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5425959 05/10/20 11:48 PM
sloinker Offline
Torqueflite guys use it to firm up the shifts, maybe the Turbo 350/400 guys do to? Old school!
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5426104 05/11/20 08:06 AM
dwcopple Offline
gun lube
2017 Acura MDX SH-AWD
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: What are other uses for Type F Transmission Fluid [Re: dwcopple] #5426122 05/11/20 08:22 AM
L
LotI Offline
L
Originally Posted by dwcopple
gun lube
Make Ed’s Red, a great all-purpose cleaner, if you have stuff to clean.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
19 Buick Regal TourX
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5426126 05/11/20 08:25 AM
M
Miller88 Offline
M
Mix it with acetone for good penetrating.
Type F smells terrible though. Like cat pee.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5426242 05/11/20 10:30 AM
K
Kira Offline
K
Is the following true?
Type F has "more texture" in it as Ford transmissions used bare metal plates instead of fiber-coated waffles. The metal plates would last longer because they wouldn't collide as hard due to said texture.
I was told this.
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5426264 05/11/20 10:51 AM
R
racin4ds Offline
R
Type F had NO friction modifiers in it, thats why it is still used today for drag racing and guys wanting firm, solid shifts. Todays autos are for pansies that don't want to feel the shift at all, which results in major slippage every gear change which wears clutches and associated parts faster.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: What are other uses for Type F Transmission Fluid [Re: Tygrant] #5426406 05/11/20 01:16 PM
T
Tygrant Offline OP
T
Great ideas thanks, I was looking at using it in a log splitter for hydraulic fluid bit it sounds like mixing the two isn't a good idea and don't really want to flush system completely
