Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
55 registered members (Ag76, 10WSmuckers, bdcardinal, BlakeB, Aero540T, 3 invisible), 1,366 guests, and 30 spiders.
Topics306,113
Posts5,287,769
Members71,602
01 Suburban 1500 4x4 poor handling new shocks #5425727 05/10/20 05:58 PM
dogememe Offline OP
From the day I bought my Suburban about 10-15k miles ago I noticed that it had a very floaty handling and it just felt unstable at high speeds and around corners.
This is my first GMT800 but I've owned a dozen GMT400s and other large vehicles so I'm used to driving full size trucks and SUVs and I'd say that this Suburban handles far worse than any of those.
I installed new KYB ExcelG shocks all the way around and it didn't make a huge difference. It helped but it's not as good as I expected. Are my shocks defective? Could it be something else?
Thanks.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425735 05/10/20 06:08 PM
J
Jethro_Bob Offline
J
Might be a good idea to check the sway bars and end links, Previous owner could have removed or possibly modified them for off road use, (or simply worn bushings at that age)
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425736 05/10/20 06:10 PM
E
Egg_Head Offline
E
Suburban w/ 291k miles feels unstable at high speeds???
I'd look at tires, front suspension components, sway bar end links, maybe go with urethane sway bar bushings.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
1978 K-5 Blazer 400ci
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425741 05/10/20 06:15 PM
CKN Online Content
Online Content
Yes-could be a number of WORN OUT componets.
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425742 05/10/20 06:17 PM
DuckRyder Offline
I would say a comprehensive inspection by someone with a clue (probably not a tire store) is in order.
Jetro and Egg Head on the right track ... (I cannot believe i just typed that)
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: DuckRyder] #5425750 05/10/20 06:29 PM
W
Wolf359 Offline
W
Jetro and Egg head on the right track on the right track... (I cannot believe i just typed that)
Yeah, the list goes on too, inner/outer tie rods, ball joints, control arms/bushings, wheel bearings, etc. Basically a front end suspension issue.
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425764 05/10/20 06:48 PM
R
ripcord Offline
R
Definitely get it inspected. If that's not an option, get underweight the front end and have someone yard back and forth on the steering wheel. Look for anything that is moving that shouldn't be. If it's make clunking noises, check for excessive movement of the rack due to worn bushings. Check the ball joints for excessive play. Also, get the rear supported on the frame with jack stands and try check the rear end for sketchy bushings, shackles, etc. Get something to lever with and shove stuff around. At those kinds of miles, you are due for some suspension work.
https://www.youtube.com/watch?v=0ZTXvDBA2wM
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425805 05/10/20 07:45 PM
CT8 Offline
2001 Chevy Suburban 5.3 ~291K Miles the miles look at the miles not the oil of filter, :[ Valvoline Maxlife 10W-30, ACDelco Filter.]
2015 F150 2.7
2018 F350 6.2
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425852 05/10/20 08:28 PM
AZjeff Offline
Man, I'd expect a GM truck with 290k miles to drive poorly unless I saw receipts for lots of chassis repairs. Throwing shocks on it before knowledgeable inspection of every piece of the steering and suspension is just firing up the parts cannon.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425938 05/10/20 10:57 PM
G
GMBoy Offline
G
You have worn suspension components. I see this on a daily basis - some so bad it won't stay in a lane. Most likely culprits are the inner and outer tie rods, ball joints and pitman arm. Also look at your sway bar bushings for a bonus ride/handling improvement. When buying tie rods - STAY AWAY from Ac delco advantage parts - they are cheap chinese. I had a 2006 Yukon where I installed these per the customer (he bought them thinking he was getting OEM GM parts - they aren't).....no kiddding...5 months later they were worn terrible. So loose you could shake them. I replaced them with MOOG problem solvers which are a better internal design and a little beefier. Never any returns with those. These 800 series trucks run nice and are durablel but the front ends usually need work after the 150k mile mark.
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5425967 05/11/20 12:21 AM
A
A_Spruce Offline
A
I have an 03 2wd with 155k on it with similar problems. Replaced the shocks front and back due to noise and harsh ride (Monroe OE Spectrum), it helped but has not cured all the suspension noises. There is a twisting rubber noise and a clunk that are only heard when flexing the suspension over speed bumps and driveway approaches. She isn't exactly unstable at speed, but she is very susceptible to crosswind.
Visual inspections, everything appears to be in good shape, no movement that I can get, however, I don't have the ability to raise and support the vehicle properly to adequately exert inspection force on the various components. I am suspecting worn or bad bushings here and there, I've just not been able to confirm it yet. There is also negligible tire wear, which is the opposite of what you'd expect from front suspension component wear.
'03 Suburban
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5426076 05/11/20 07:21 AM
R
Rob_Roy Offline
R
In addition to checking for worn suspension components, a bad tire can cause all sorts or handling issues, along with the alignment being off.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5426163 05/11/20 09:02 AM
K
krismoriah72 Offline
K
Agree with others to look at your suspension for worn parts..but tires are also a big factor.
Report back with the tire brand and make you currently have as well as tire pressure.
You have one of the heaviest vehicles that GM makes.. proper rated tires and inflation make a huge difference in handling.
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5426701 05/11/20 07:05 PM
another Todd Offline
On a big vehicle, go with the better mono tube shocks such as KYB gas-a-just...much better control. ExcellG shocks are not heavy duty enough to control that vehicle IMO. I put the KYB gas-a-just on my Yukon and they are outstanding.
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
Re: 01 Suburban 1500 4x4 poor handling new shocks [Re: dogememe] #5426794 05/11/20 08:39 PM
T
Toyt1219 Offline
T
Might want to make sure you don’t have the smooth ride auto level suspension option. I forgot the glove box code but you can look it up. If you go to auto parts store and ask for shocks they will give you some that will fit but they will cause the issue you have and the ride height will sag in the back.
Since those auto level shocks are so expensive people just replace the rear springs so they can put on regular cheap shocks.
But ya.... with those many miles every thing needs to be inspected very closely for safety.
