Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
38 registered members (blufeb95, billpace1956, ArrestMeRedZ, BTLew81, Aero540T, carlprop, 2 invisible), 1,068 guests, and 59 spiders.
Topics306,113
Posts5,287,783
Members71,602
Wix 51394 #5425565 05/10/20 01:37 PM
K
kenwin30 Offline OP
K
I have been using this filter on my JD Zero Turn, Oreilly didn't have it so I crossed it to a Mobil M1-102A filter, the Mobil filter seems bigger than the Wix, will it be ok ?
Re: Wix 51394 [Re: kenwin30] #5425571 05/10/20 01:44 PM
K
Kira Offline
K
If the baseplates match up and it'll fit, I'd use it with confidence.
Never had a problem crossing filters for OPE.
Re: Wix 51394 [Re: kenwin30] #5425592 05/10/20 02:18 PM
O
Oildudeny Offline
O
very good filter.. i have used the napa version of the wix on my corolla's thumbsup approved
Re: Wix 51394 [Re: kenwin30] #5425624 05/10/20 03:13 PM
B
blufeb95 Online Content
Online Content
B
If the filter amount can accomodate the slightly larger o-ring it should work, I'm most familiar with Fram numbers, that mobil filter seems to directly cross reference the Fram 3614 while the Wix directly cross references a Fram 4967, the 4967 is a little smaller in diameter and has a smaller gasket by about .3inches, if it'll mount and not leak I don't think the larger filter should be too much of a problem although I typically wouldn't recommend running super oversized filters on small engines as the filter may steal too much oil from the sump and starve the engine of oil but the 3614 is about 25cuin in empty can volume and the 4967 is about 17cuin so with the larger media cartridge there's only a few more ounces held in the 3614, I wouldn't be super worried, just don't stick something like a Fram 3600 or 8 sized filter on a small engine that calls for a 4967.
Re: Wix 51394 [Re: kenwin30] #5425640 05/10/20 03:36 PM
N
NormanBuntz Offline
N
I believe the sister 1394 is readily available at Napa. I've used it on a standby generator.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Wix 51394 [Re: blufeb95] #5425678 05/10/20 04:32 PM
SubieRubyRoo Offline
If you were to only add the recommended amount of oil, I would agree. But if you add the recommended amount, start the engine for a couple minutes to let everything circulate and fill the filter, shut it off and then bring the oil level to the correct amount on the dipstick, then there should be no problem at all. My ZT had one of the tiniest 3/4-16 filters I've personally seen from the factory (I forget the Hydro-Gear part #), but it couldn't have been more than maybe 4oz worth of oil. Since it's mounted horizontally, I was able to dry-fit a 3600 and find that it just cleared the frame. It's been running like that for several months.
De omnibus dubitandum.
Re: Wix 51394 [Re: blufeb95] #5425686 05/10/20 04:59 PM
P
pbm Offline
P
I know that many have used a 3614 on Toyota's that call for a 4967.....but I'd like to know if a 4967 or the slightly longer 4386 can be used in place of a 3614 even though the gasket is smaller?
I ask because I have several of the 4967 and 4386 filters from my Toyota that I could use in my Focus if I sell the Corolla. A few years ago my niece had one of the smaller one's installed
on her Focus at a quick lube place and it didn't seem to cause an issue. Any thoughts?
'Journalism is Dead'
Re: Wix 51394 [Re: SubieRubyRoo] #5425732 05/10/20 06:05 PM
B
Online Content
B
The only problem with doing that is if the ADBV fails then the sump will get flooded.
Re: Wix 51394 [Re: pbm] #5425770 05/10/20 06:55 PM
B
Online Content
B
You'd need to measure the oil filter mount and make sure that the ID of the gasket hits a flat surface and that it's not sealing against a section that's milled out where oil is supposed to be flowing. I'm not really sure about running smaller filters but the 4386 would probably be fine as it's roughly the same length as the 3614 just 3/10 of an inch smaller diameter wise without seeing the filter media cartridge I can't say how that would effect the surface area, the 4967 just seems really really small I'm not sure I'd use it in an application that calls for a 3614 being both 3/10 smaller and being .4in shorter, I took apart a Cor3506ACC recently which should be about the same as the PH3506 and internally about the same as the 3614 minus the bypass valve in the leaf spring and having a 13/16-16 taping plate installed, the media cartridge was only about 2.25in tall, so when you shorten the filter .4in I'd assume that directly translates to media cartridge being .4in shorter since the leaf spring and adbv should take up the same amount of space in the can so going down from the 4386 to the 4967 would make the media cartridge about 1.85in long so you lose about 18% of the surface area there. I think I still got that cut up filter out in the garage maybe I'll measure the pleat depth and calculate what area would be lost if you shorten them around .15in although I'm not sure if the pleats in the 4967 and 4386 might be more dense than those in the 3506 or 3614 or similar diameter filters.
Re: Wix 51394 [Re: kenwin30] #5426079 05/11/20 07:26 AM
E
Eddie Offline
E
Why not use the recommended filter and sleep well. I see little or no value in trying to fit something not even crossed over that happens to screw on. Ed
2014 CX5 Touring 2.5L :-)
Re: Wix 51394 [Re: Eddie] #5426313 05/11/20 11:42 AM
dwendt44 Offline
Like some here, I'm a believer in using the largest filter that will fit.
Zero turns don't have as much room as some tractors but the 3614 should fit in space provided.
The larger filter means we can extend oil changes and even run that filter two oil changes.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Wix 51394 [Re: dwendt44] #5426340 05/11/20 12:19 PM
J
jeepman3071 Offline
J
My 2¢
Just be careful using the largest filter you can fit, you might actually be hurting more than helping. A lot of these small engines don't have super high oil pressure or pump volume, and some need to fill the filter first before oil gets to the bearings. A larger filter will take longer to fill (initially, and if the ADBV fails) before the oil reaches the bearings. A larger filter won't really do any favors besides adding a tiny amount more oil capacity. I've cut open small engine filters (the OEM sizes) that have been on for years, and they weren't clogged or anywhere near capacity. Something like a 3614 or Wix 1348 size is perfectly fine, but I've seen pics on here of guys running filters that stick out 10" from the engine. crazy
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Wix 51394 [Re: kenwin30] #5427199 05/12/20 10:10 AM
B
bchannell Offline
B
I would also be sure to check the bypass rating of the filter you intend to use. While I'm relatively sure the 4967, 1394 etc, and maybe even the 3614 all have similar bypass ratings, so that shouldn't be a problem in this case. I use 4967 on my JD 425 and 3614 on my Toyota truck simply because that's what they call for.
Re: Wix 51394 [Re: bchannell] #5427231 05/12/20 10:47 AM
B
Online Content
B
The 4967, 4386, 8, 16, 3614, 3600 all have pretty similar bypass ratings around 12-14 psi.
Re: Wix 51394 [Re: kenwin30] #5429295 05/14/20 05:06 PM
53' Stude Offline
So does the tough Guard 8316. 14psi
https://www.fram.com/parts-search/TG8316
2009 Toyota Camry LE
