PUP SP
by Koncrete_Cam - 06/05/20 05:52 AM
Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
Jettero, stubby73, Polkaman, Ramboagain, tekfire07
71609 Registered Users
67 registered members (Best F100, Alfred_B, 4WD, BBC_bias, alarmguy, 1911CHAMPION, 5 invisible), 978 guests, and 23 spiders.
Topics306,230
Posts5,288,685
Members71,609
2016 Golf 1.8T engine leaks #5425487 05/10/20 11:23 AM
M
mb32 Offline OP
M
My sister took her 2016 Golf 1.8 in for a routine oil change this past week. The shop (indy VW shop and not dealer) noted that there was evidence of oil leaking near the bellhousing from the rear main seal. It was also noted that there was some coolant residue on the water pump housing, so it also appears to be leaking.
I did a bit of research and it sounds like the rear main seals are failing on this generation of engine. Car has just under 50,000 km so it will be going in shortly to VW to see if they will do the repairs under warranty. I am hoping that they do and that the replacement seal is an improved part from the original. Anyone with the 1.8 EA888 have these issues before and were successful in having it done under warranty?
Re: 2016 Golf 1.8T engine leaks [Re: mb32] #5425502 05/10/20 11:45 AM
Danno Offline
If the rear main is found to be leaking, it should be covered under the 5yr/100k kms powertrain warranty.
Might be worthwhile to call the 1-800 number here to validate ahead of time before going to the dealer.
https://www.vw.ca/en/owners-and-drivers/warranties-and-coverage.html
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2016 Golf 1.8T engine leaks [Re: mb32] #5425505 05/10/20 11:50 AM
V
Vercingetorix Offline
V
Bad PCV valve can cause rear main seal leaks
Re: 2016 Golf 1.8T engine leaks [Re: mb32] #5425514 05/10/20 12:08 PM
sloinker Offline
Check for hard vacuum on the dip stick tube, oil fill cap. This indicates a bad separater pcv valve. This will cause a rear seal failure if not caught and corrected early. usually there is a noise coming through the vent hole on the pcv valve. Distinctive sound.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
