Umph...
OK... I'm considering to use it this summer (phew.. said it). I searched and found this thread. To find a fresh bottle I may need to go some industrial site but I guess it'll be dirt cheap.
The funny thing is, it is among the recommended oils in my '84 v6 GM, and it perfectly fits my climate range yeararound, -5 to 34°C (23 to 93°F). On the manual it sits at the chart between 15w 40 and straight 30. It is recommended, as SF/CD rated, with 7500 mile OCIs!
So, I've been thinking on this for days and may be I dumbed myself, but why not? What would you do, would you try while we're entering the spring and save the first 0w 30 GLX for the winter (to better see if there is difference). Per the manual it fits the bill perfect. Visc. @ 100°C is ~8.9, looks low but while the 5w 30 isn't allowed above 100°F, 20w 20 is allowed! It states "Lower viscosity engine oils can provide better fuel economy; however, higher temperature weather conditions require higher viscosity engine oils for statisfactory lubrication"
What would be the worst case scenario for 3000 mile before drain? Right now in the crankcase is Havoline 5w 40 synth.
