Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
96 registered members (10WSmuckers, 53' Stude, 2015_PSD, 4WD, 330indy, 55hambone, 11 invisible), 2,518 guests, and 24 spiders.
Topics305,939
Posts5,283,310
Members71,540
Pressure Washer Pump Oil #5425168 05/09/20 11:20 PM
Propflux01 Offline OP
Simpson 3100. I've had it for about 6 years. I wanted to change the pump oil for PM reasons, but manual states no service needed. Pump has no visible plugs to add or remove oil, but I did find this sticker on the bottom of the pump. Anyone know how to go about this if its possible? [Linked Image]
[Linked Image]
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425232 05/10/20 05:39 AM
R
RyanY Offline
R
The Simpson 3100 is a "maintenance free" pump that does not require oil change. Apparently the manufacturer expects the oil to last as long as long as the pump, at which point you buy a new one.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425240 05/10/20 05:58 AM
T
tundraotto Online Content
Online Content
T
Change it with SAE30 non-detergent oil.
Mag 1 makes a pressure washer specific one for cheap.
You will have a hard time finding a non-detergent 15W-40.
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425242 05/10/20 06:09 AM
M
Mainia Offline
M
In our CAT pressure pumps we use an IOS 68. We use a special synthetic industrial oil from Summit Industrial Products (Kluber Oil). For ease of getting oil on your side, you should just get oil for a CAT pump that has the add-pack for those small pumps.
https://www.amazon.com/CAT-Pumps-Pressure-Washer-Pump/dp/B0000AX3WI/ref=sr_1_1?crid=IBOJX7RFMD85&dchild=1&keywords=cat+pump+oil+iso+68&qid=1589108920&sprefix=CAT+pump+oi%2Caps%2C176&sr=8-1
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425263 05/10/20 06:48 AM
O
Oildudeny Offline
O
As mentioned might be a non serviceable pump.. You can always contact the manufacturer.
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425302 05/10/20 08:01 AM
dlundblad Offline
You can use automotive engine oil in a pump issue free. I’ve seen it done before in industrial settings issue free. 1 was at a carwash with Cat pumps the size of a small engine with good ol Mobil 1 10w30.
That said, if there’s no drain and fill plug, about all you can do is let it be unless you want to tear into it and possibly risk damaging a good working pump.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425317 05/10/20 08:22 AM
B
Belker Offline
B
Propflux01,
The webpage listed below has some service information for your pump along with a copy of the owners manual and a parts schematic. Hopefully there is enough information there to help you with the oil change.
Belker
https://www.allpartsinc.com/oem-pump-kit-3400-psi-3-4-shaft-520002.html
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425448 05/10/20 10:36 AM
O
Oildudeny Offline
O
I wouldn't use detergent motor oil in a pump or compressor. You'll get foaming.
Re: Pressure Washer Pump Oil [Re: Propflux01] #5425507 05/10/20 11:51 AM
Thank you for the responses.
AS with most items, I want it to last longer than the MFG wants me to have it.
I didn't expect to fond a 15/40 oil, and have pump oil in a 30 W here now.
Contacting the MFG will get me the same information I get in the manual. "Your pump does not need to be serviced" Neither does those "lifetime fill" transmissions.. But this is BITOG...
Yes, tearing into it wasn't my first choice.
Thank you Belker, I will look into that!
I know that is the norm for compressors as well.
Re: Pressure Washer Pump Oil [Re: Propflux01] #5426509 05/11/20 02:49 PM
N
nobb Offline
N
Wow that must be a really cheap pump, even the cheapest ones I've seen had some sort of drain/fill port. With this unit I'm assuming you'd have to open up the casing via the 4 screws to get in there to do a drain + fill.
Re: Pressure Washer Pump Oil [Re: Propflux01] #5426573 05/11/20 04:17 PM
dawgn86 Offline
You should be able to unbolt the pump from the engine and then unbolt the pressure unloader valve assembly. Then unbolt the head of the pump unit, pour out old oil. Clean it out and usually they take 4-5 ounces of oil.
2019 Acura MDX
2019 Ford F150
2007 Acura MDX
2016 Volvo XC90
2013 Toyota Tacoma PreRunner
Re: Pressure Washer Pump Oil [Re: Propflux01] #5426744 05/11/20 07:47 PM
another Todd Offline
Is there a drain or fill plug under one or both of those stickers? Seen that before when the manufacturer doesn't want you in there.
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
Re: Pressure Washer Pump Oil [Re: Propflux01] #5429444 05/14/20 08:36 PM
No fill or drain at all. At first that's what I thought the sticker was hiding.
Re: Pressure Washer Pump Oil [Re: Propflux01] #5429445 05/14/20 08:36 PM
