Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
95 registered members (bbhero, andyd, Best F100, Alain2, ammolab, 55hambone, 5 invisible), 2,227 guests, and 18 spiders.
Topics306,107
Posts5,286,543
Members71,586
What can I use to removescratches from sunglasses? #5424980 05/09/20 06:49 PM
daves66nova Offline OP
I have a lot of safety/ sunglasses from work. They are plastic. What can I use to make them like new again? Any type of super fine grit sandpaper or type of polish that I can use?
THIS SPACE FOR RENT, PLEASE PM ME.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5424988 05/09/20 07:03 PM
T
Taildragger Offline
T
Dollars. Yup, lots of dollars.
73 Big Block, 4sp Corvette
Couple of airplanes
2019 F-150 Coyote
"Turbos on an engine is God's way of telling you it ain't got enough cylinders." Mike Skinner
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5424993 05/09/20 07:11 PM
AZjeff Offline
Depends on what they're made of. Some plastics polish well, others not. Polishing/cutting compound and a buffing wheel could do it. Some lenses have coatings that you aren't going to fix.
Most safety glasses aren't very expensive and hardly worth the effort.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5424996 05/09/20 07:13 PM
yeah ,i know, but I have like 25 of them at my house. Some aren't that bad.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425010 05/09/20 07:33 PM
J
John_K Offline
J
Lens Buff Eyeglass Scratch Remover
2009 Mercury Grand Marquis, 8 cyl auto, 98xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 101xxx miles, Maxlife/OEM Filter
Current oil stash: 446 qts.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425015 05/09/20 07:41 PM
A
Alfred_B Offline
A
Chrome polish might work well.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425029 05/09/20 07:59 PM
T
TmanP Offline
T
Try this on a cheap pair, but here's what I did when I scratched my normal glasses (no promises, of course):
-make a thick baking soda paste
-polish with a circular motion
-rinse
-repeat if still scratched
I read this on the internet when I scratched my normal glasses up pretty good (dropped them face down on concrete). I was skeptical, but it worked super well. The scratches disappeared and the glasses lived for several more years.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425052 05/09/20 08:27 PM
Dinoburner Offline
Try a good cleaner wax, works here. A light touch with a micro fiber cloth.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425062 05/09/20 08:42 PM
skyactiv Offline
Try Brasso if you have any. I used it on a laptop screen with success.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425068 05/09/20 08:51 PM
Dave9 Offline
As hard as it is to believe, a good polish for plastic is called... wait for it... plastic polish.
They sell this.
If you have deep scratches, you'll have to decide if it's worth the bother, to use progressively finer grits of sandpaper to get down through the depth of the scratch, before then going on with finer abrasives and then plastic polish.
A cleaner wax might be the last step, but you might also find that while it does a good final polish, that ultimately you need to strip it off with detergent because it leaves funny halo artifacts.
Clear plastic that you have to look through at close range is a special case. Personally, if I have to wear something that's been refinished, it gives me a headache if worn for more than a few minutes at a time but maybe that's just me or maybe a few minutes are all you need for certain tasks.
You don't mention what you have as far as resources, tools and materials. Although it is less than ideal, you might be able to get a fair amount of improvement with nothing more than a dremel tool with a cotton swab in it, with a lot of toothpaste on it. The deep scratches might not be worth the bother for salvage purposes. You can still polish into a deep scratch and improve it even if you don't get rid of it.
Then again, maybe just get a new pair of safety glasses and take better care of them? A lot of those I find, were scratched up as much from poor handling and storage as from work related injuries.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425092 05/09/20 09:19 PM
wwillson Online Content
Administrator
Online Content
Administrator
I asked an optician friend of mine this question. The bottom line is you can't remove the scratch, which requires polishing the lens, without changing the prescription in that area. I've spend a lot of money over the years replacing glasses that get a scratch where I look through them.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425131 05/09/20 10:20 PM
pkunk Offline
Polywatch. It's made for plastic watch crystals but works well for some sunglasses
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425160 05/09/20 11:07 PM
KJSmith Online Confused
Online Confused
My wife had a problem loosing/breaking sun glasses.
I told her to buy a more expensive pair and she would be more conscious of them and not abuse them.
That has worked for well over 30 years.
If your getting them free from work, throw them away.
Re: What can I use to removescratches from sunglasses? [Re: wwillson] #5425169 05/09/20 11:24 PM
These aren't prescription.
Re: What can I use to removescratches from sunglasses? [Re: daves66nova] #5425327 05/10/20 08:37 AM
sloinker Offline
Why bother?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
