50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
79 registered members (AlienBug, 1978elcamino, 2004tdigls, 53' Stude, AndyB, Alfred_B, 7 invisible), 2,296 guests, and 24 spiders.
Topics306,015
Posts5,284,856
Members71,558
2005 Silverado 3500 Service Air Bag #5424941 05/09/20 05:46 PM
shibby6600 Online Content OP
OP Online Content
I keep getting a service air bag light only when it is cold out. I've replaced the front air bag sensor (the 3500's do not have side sensors that I'm aware of), and cleaned the ground by the front drive side frame. What gets me is this comes on intermittently, but if it does it's less than 40*F. It really likes to do it when it's single digits in the winter. Sometimes it will go out while driving, other times it flashes on and off every 10 seconds, and others it stays on the whole drive. Once in a while when cold it won't come on at all. I have never had it come on when it's more than 50*F outside. This intermittent behavior makes it really hard to tell if anything I do either fixes it, or being able to track it down.
Any suggestions or starting places?
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5424965 05/09/20 06:31 PM
E
eljefino Offline
E
Seems like you should pull codes, preferably when it's going on.
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425045 05/09/20 08:19 PM
H
Hysilver Offline
H
I have an 06 1500, but there were two sensors. It said service airbag so I replaced one. It didn't fix it. Replaced the other, fixed. Maybe you have two up front?
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425285 05/10/20 07:27 AM
E
eljefino Offline
E
The system is more than just sensors... there's also the clockspring, which can be a wear item.
There will definitely be more than one sensor-- the system has redundancy.
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425292 05/10/20 07:40 AM
M
mattd Offline
M
BOTH front sensors under the radiator are the most common issue on those generation trucks.
There will be a history code stored. Try to have omit read
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425337 05/10/20 08:43 AM
6
64bawagon Offline
6
Not sure on the 3500 but the 2500 trucks I have worked on from that era also had one under the drivers seat.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425359 05/10/20 09:06 AM
OP Online Content
Forgot to mention I did pull the codes, but all of them were unknown to the scanner and internet search hasn't helped much.
C0026
C2575
U1301
If anyone has references to where the two airbag sensors in the front are that'd be helpful. I've only ever seen one and found references to there being one. The 3500's are setup different than a lot of the smaller trucks.
I'll take a look under the seat, but I don't think I remember seeing one when I pulled the seat to replace the heating pads.
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425537 05/10/20 12:34 PM
M
mattd Offline
M
What module were those pulled from? You need to scan the RCM. Air bag codes are B series codes. C codes are chassis codes.
ASE Master, L1, L2
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425675 05/10/20 04:27 PM
OP Online Content
It was all of the modules the scanner could do, one of those rental types at the auto store. There were no B codes stored (or it didn't read them), just the chassis and network codes.
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425730 05/10/20 06:03 PM
M
mattd Offline
M
You probably need a different scanner.
ASE Master, L1, L2
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5425942 05/10/20 11:07 PM
G
GMBoy Offline
G
Most popular airbag issue with these year range GM trucks including SUV models. There are 2 sensors in front on the rad support. You can tell them by the YELLOW connector. Yellow is used for all airbag connections. I always replace both at once. Did about 6 or 7 this year alone. Runs about $100 a sensor depending where you buy. I once got 2 used for $150. Verify your codes 1st with a proper scan tool first.
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5427524 05/12/20 04:53 PM
OP Online Content
I'm not saying anyone is wrong about there being two sensors, but I would really love for someone to point them out to a blind old me. I only see one sensor (that I replaced last year due to this same issue and the new sensor didn't fix it), which lives in the center of the bottom of the radiator support. There is no left or right sensor, and I cannot find any harnesses with yellow connectors outside of this single sensor.
I have told almost everyone that 3500's are different than 1500/2500's, and I keep hearing there's two sensors on all trucks. Please tell me exactly where they are, because all I see is the one in the picture below (if the picture uploader worked?).
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5427550 05/12/20 05:39 PM
OP Online Content
Got a scanner that could read airbag codes. B0035 - Auxiliary Discriminating Sensor Closed or Shorted to Ground. Symptom of this is setting the airbag light, as I've been seeing.
Any clues where to go from here?
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5428290 05/13/20 02:09 PM
Z
zrxkawboy Online Content
Online Content
Z
I looked up your truck in the Chilton Library. It shows that it could have come with either one or two front sensors...apparently yours has one. It also shows a sensor in the passenger door, near the bottom rear.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: 2005 Silverado 3500 Service Air Bag [Re: shibby6600] #5429576 05/15/20 02:19 AM
OP Online Content
I checked the inside of both passenger doors and could not find any sensors.
I also cleaned the two ground points on the driver side frame, tightened the front sensor pins, looked for any rub through on the harness, pulled the fuse block and checked the wires, pulled the seat and checked the SIR module connector. I can't find any place this would be shorting to ground, unless the sensor itself is bad. I really don't want to buy another $100 sensor just to have it not be it.
