Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
92 registered members (ABN_CBT_ENGR, Arcoril, 2009Edge, Al, 2015_PSD, aquariuscsm, 10 invisible), 2,295 guests, and 24 spiders.
Topics306,122
Posts5,286,878
Members71,588
Page 1 of 3 1 2 3
Thinner control arm bolt make any difference? #5424886 05/09/20 04:32 PM
T
tookien Offline OP
T
I had to cut one of the bolts while changing a front control arm.
I installed a high grade bolt in replacement but it's a tiny bit thinner. The diameter is 0.97 mm smaller (0.038 inches) than the original bolt.
I torqued it down and drove it around and it's holding up with no issues, no torque steer or alignment problem.
Is that any cause for concern and should I just leave it?
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424890 05/09/20 04:36 PM
I
Imp4 Online Content
Online Content
I
The wrong size bolt is never the right answer.
Vibration will eventually lead to fatigue.
Fatigue will lead to failure.
Can you afford that??
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424894 05/09/20 04:38 PM
spasm3 Offline
I would get a replacement. There could be slight movement that wears and either fails or wallows out the new control arm.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Thinner control arm bolt make any difference? [Re: Imp4] #5424897 05/09/20 04:43 PM
T
tookien Offline OP
T
The original bolt isn't exactly vibration free either as it still has play within the bushing of the control arm.
I'm thinking that the small difference shouldn't be a problem because the outer ends of the bushing compresses the outside mounts when it's torqued down.
So yes I agree with you in most cases but in this case I'm just not sure it applies.
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424899 05/09/20 04:43 PM
ABN_CBT_ENGR Online Content
Online Content
Nothing to add to the reasons already stated- they are correct
Replace it with the proper dimension and grade fastener
Re: Thinner control arm bolt make any difference? [Re: spasm3] #5424904 05/09/20 04:49 PM
T
tookien Offline OP
T
To break a grade 10.9 bolt would take quite a bit of force. The difference here is so tiny in terms of the thickness.
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424905 05/09/20 04:50 PM
I
Imp4 Online Content
Online Content
I
Yes, it still applies.
Especially here with a control arm and the movement and vibration it sees.
Do it right.
Change it out.
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424907 05/09/20 04:51 PM
spasm3 Offline
Should not be much, check Rock Auto or a u pull it yard.
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424908 05/09/20 04:55 PM
Online Content
Incorrect but it depends on the definition and direction of that "force". Fasteners are designed for tension loading for engineered joints. When shock and bending loads ( shearing) are introduced- they all break with very little force.
That thickness could ( not saying absolutely will) be enough clearance from design to introduce shearing or shock loading over time and cause failure.
Re: Thinner control arm bolt make any difference? [Re: ABN_CBT_ENGR] #5424915 05/09/20 05:08 PM
T
tookien Offline OP
T
Thanks. I'll keep an eye out on it.
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424917 05/09/20 05:15 PM
Online Content
Other than safety, the reason I point that out is that I frequently have to do failure analysis on sheared bolts.( especially on high impact equipment at mines and lumber mills)
By the time I get there they have gone from 5 to 8 to B-7 ( even welding heads sometimes) and they are all still snapping.
Its almost always a case of the joint and/or the fastener losing dimensional tolerance and creating those loads which result in failure.
May not be the case in your application but its a very common failure mode. Not worth the risk.
Re: Thinner control arm bolt make any difference? [Re: ABN_CBT_ENGR] #5424924 05/09/20 05:24 PM
T
tookien Offline OP
T
Personally I've used slightly thinner bolts (the same ones in fact) on control arms in the past on my other vehicle and drove it for years without failure.
IMHO, as I don't really want to start an argument, it really depends on the context. As I mentioned the original bolt has play within the control arm bushing as well, so the logic clearly doesn't really follow that in this case play will cause failure.
I understand the argument from safety so I will look out for any pplay, I would really be concerned if this was a low grade stainless steel bolt.
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424925 05/09/20 05:25 PM
skyactiv Offline
This is another thread where the OP is looking for an answer he agrees with. In this case, he wishes people would say, "you'll be fine". I concur with the majority here.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Thinner control arm bolt make any difference? [Re: tookien] #5424937 05/09/20 05:42 PM
SLO_Town Offline
The biggest problem with using a smaller diameter bolt is that it does not fit precisely into the bore of the bushing and holes in the frame mounting points. Using a smaller diameter bolt may work for awhile, but eventually it was loosen and start elongating the frame mounting point holes. Then you're screwed.
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Thinner control arm bolt make any difference? [Re: skyactiv] #5424938 05/09/20 05:44 PM
I
Imp4 Online Content
Online Content
I
Precisely.
Page 1 of 3 1 2 3
