2016 Ford F-150 spark plugs
Oklahoma
So, I changed out my spark plugs today and one of the spark plugs I pulled had oil on one of threads. It was the spark plug front driver side. Should I be worried or is this a normal thing?
I often get 100,000 miles or more from factory plugs . But I have not owned a Ford in years .
Right now , I am driving a 2014 F150 w/100,000 + miles . It is a company truck . Only thing I do to it is out gas in it , get the oil / filter changed every 3,000 miles ( dino oil ) and drive it .
If it needs work , I take it to the shop of the boss's choice .
As far as yours , I would replace plugs as needed , bur I ask if the CEL has come on at any time .
Check all the plugs and fluids . Check , visually , all your sensors ( including O2 sensors ) . Are you using " good " gas or the cheapest you can find ? Ethanol / gas mix or pure gas ?
Is most of your driving city or open highway ?
They look fine. A direct injection engine creates more soot and carbons the threads up a bit, but those are fine.
Originally Posted by double vanos
If your truck doesn't use any oil, I wouldn't be worried.
I agree ^^^^^^^
I don't see any signs of ash on those ground straps... So that would tend to have me think it's not burning oil. Otherwise the plugs look to be in good shape.. .
Just did mine on my 2016 with 60,000 miles. No oil on the threads and the plugs actually were in great shape. Gap was almost perfect too. In a habit of doing 60k changes after dealing with the 3v spark plugs.
Front drivers side is the location of the oil fill. Anyone spill a little oil at some point?
I always get my oil changed at the dealership with a tire rotation. So there is a possibility it could've spilt not sure how they fill the trucks.
I appreciate the help. Just worried I had issue since only one plug had oil on the threads.
