2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
102 registered members (alarmguy, ammolab, 390pi, 55hambone, 2015_PSD, 10 invisible), 2,591 guests, and 25 spiders.
Topics306,061
Posts5,286,636
Members71,593
Acura TL -- complete strut assembly!!! #5424563 05/09/20 09:10 AM
B
BAJA_05 Offline OP
B
Acura in signature, has original OEM factory struts/shocks/springs -- would like to go with full strut assembly. What do use BITOGs fine folks recommend. Do not want something real cheap but neither do I want something mind boggling expensive. Please help me out. Would be for front and rear.
Dale
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5424574 05/09/20 09:21 AM
N
NormanBuntz Offline
N
KYB or Sachs available from many sources.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Acura TL -- complete strut assembly!!! [Re: NormanBuntz] #5424594 05/09/20 09:37 AM
M
Mainia Offline
M
I second that. Monroe, and other lesser names just don't last.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5424598 05/09/20 09:39 AM
B
BAJA_05 Offline OP
B
I see they have different price ranges for the KYB -- which ones? Went on Amazon -- no KYB strut assembly fits on my Acura??
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5424599 05/09/20 09:39 AM
Danno Offline
Just installed Monroe Quick struts on a 2010 Mazda3. Work great.
Available at Rockauto for about $90.
https://www.rockauto.com/en/catalog/acura,2008,tl,3.2l+v6,1440497,suspension,strut+/+coil+spring+/+mount+assembly,15174
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5424606 05/09/20 09:44 AM
B
BAJA_05 Offline OP
B
Opinions on Gabriel complete strut assembly?
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5424666 05/09/20 10:59 AM
L
LazyDog Offline
L
Not good at all, I bought a pair and lasted about 6 months only!
Re: Acura TL -- complete strut assembly!!! [Re: Mainia] #5424744 05/09/20 01:35 PM
B
bullwinkle Offline
B
I have Monroe quick struts on the MGM in my sig, they've been good for about 3 years so far.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5424755 05/09/20 01:54 PM
slacktide_bitog Online Content
Online Content
Honda actually sells OEM quick struts for your TL. About $200 each
Does the TL have the same suspension as the Accord? If so, you can get Accord quick struts. There are more choices that way. For example, KYB makes quick struts for the Accord but not the TL If not, there's still Monroe.
My choice in quick struts would be
OEM (if you can afford them) > KYB > Monroe
Re: Acura TL -- complete strut assembly!!! [Re: bullwinkle] #5424808 05/09/20 02:56 PM
L
Lolvoguy Offline
L
Usually they don't even make it to the end of the warranty period.
The MGM suspension was designed with technology from the 1950' s.
Therefore it has significantly different suspension design and needs than an Acura.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Acura TL -- complete strut assembly!!! [Re: BAJA_05] #5425329 05/10/20 08:37 AM
B
BAJA_05 Offline OP
B
Went with the most expensive Monroe had to offer off Rock Auto. Will give feedback once there installed.
Dale
