Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
102 registered members (2010Civic, bbhero, 2015_PSD, Alfred_B, Best F100, BeerCan, 6 invisible), 2,180 guests, and 23 spiders.
Topics306,108
Posts5,286,567
Members71,586
New Firestone Champion Fuel Fighters #5424399 05/08/20 10:37 PM
M
Mark72 Offline OP
M
I just installed a new set of these tires on my 98 Olds. Also had it aligned. And what I'm noticing is the same with the old tires. When I get to 75-80 mph I feel ever so slight vibration but the steering wheel isn't shaking at all. My concern is am I wearing out these new tires fast are causing bad tread wear? The car tracks perfectly straight to as the alignment is spot on.
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424460 05/09/20 05:20 AM
T
The_Nuke Offline
T
Rotate front tires to back and vice versa. Does anything change or does the vibration remain the same?
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424475 05/09/20 06:33 AM
CapriRacer Offline
Since the vibration was there before AND after new tires, it's not likely tires.
Make sure it isn't the road. If you can only get to 75-80 mph only on one road, you have to eliminate that possibility by finding another place to test.
A slight vibration isn't enough to cause premature wear.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424491 05/09/20 07:03 AM
K
Kira Offline
K
Is that a '98 Olds or an Olds 98? I believe 1995 was Oldsmobiles last year.
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424558 05/09/20 09:01 AM
Char Baby Offline
My thinking is...
Maybe your old tires needed a rebalance and you never got it done.
And maybe your installer didn't do a proper job balancing you new Firestone Champion Fuel Fighters.
I am going through this right now with my new Pirelli Cinturato P7 A/S+. They were out of balance right from the start and I gave my installer a 2nd chance to rebalance them. They noticed that all 4 tires(in 3wks/300mi) were out of balance on the insides. The rebalance made things a little better but, not gone completely.
So, I had them Road Force Balanced yesterday. And this made things RIGHT! But, the guy doing the RFB said...
"If my installer had done a Dynamic Balance rather than a Static Balance, I wouldn't have had any issues from the beginning". But the guy doing the RFB only does RFB'ing and is a traveling tire installer. He came to my home.
In a nutshell, give your installer/tire shop another chance to rebalance your tires before taking the next step(RFB or suspension work or wheel work).
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424615 05/09/20 09:50 AM
J
JohnG Offline
J
If you feel the vibration in the seat, I've got two words for you:
Road Force Balance.
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424631 05/09/20 10:04 AM
Nick1994 Online Content
Online Content
Probably a bent wheel or a bad CV axle.
Could even be something like a bad motor/transmission mount.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: New Firestone Champion Fuel Fighters [Re: JohnG] #5424743 05/09/20 01:34 PM
K
krzyss Offline
K
Road Force Balance.
That is 3 words!
Krzyƛ
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424756 05/09/20 01:55 PM
Dave9 Offline
Count yourself lucky, that slight vibration is a reminder that the steaming pile known as an olds 98, had a poor suspension for high speed use when new, and is unlikely to have gotten much better after a quarter century of aging and fuel saver tires.
You are driving too fast for the conditions. If you must, try swapping the wheels front to rear.
crush
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5424790 05/09/20 02:33 PM
P
Powerglide Online Content
Online Content
P
Every Firestone tire I've ever had rode hard, were difficult to balance (out of round) and tended to be a bit noisy...with one exception. The Firestone Denstination LE. But they wear well and don't dry rot in the Florida heat. Anecdotal at best. FWIW
Re: New Firestone Champion Fuel Fighters [Re: Mark72] #5425642 05/10/20 03:37 PM
J
JohnG Offline
J
Quote
BTW Mark72, your 98 Olds was most likely built on the same chassis as my 99 STS. This car was EXTREMELY sensitive to tire vibrations from "out of round" (it's more than that, but I'm simplifying) tires.
And yes, Road Force Balance did eventually solve my problems. However, I had to educate the tire technician on the Hunter machine, AND had to get the tires down below 15# Road Force (yes, it's measurable) before the tires were right.
Good luck!
