Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
109 registered members (77GrandPrix, Astro14, Alfred_B, A_Harman, 2015_PSD, 2010Civic, 8 invisible), 2,203 guests, and 21 spiders.
Topics306,108
Posts5,286,590
Members71,586
Page 1 of 3 1 2 3
Nissan Kicks 89 octane #5423955 05/08/20 09:32 AM
L
lexus114 Offline OP
L
I bought a 2020 Nissan Kicks SR. I noticed pretty quickly that the little 1.6 liter motor struggled a bit getting up to speed. And passing on the interstate. So I first tried Shell 89 octane. I Immediately Noticed it was much peppier. And transmission was also smoother. Then for the heck of it. I tried 90 octane ethanol free gas in it. Wow, even better! Is the ecm mapped to be able to advance timing and other adjustments to make it better for the higher octane? One of the reasons I tried 89 octane. Was in the owner’s manual it stated to use an octane of at least 87. I would much appreciate your thoughts on this. Thank you..
Re: Nissan Kicks 89 octane [Re: lexus114] #5423959 05/08/20 09:39 AM
B
Boomer Offline
B
All the years (seven) that I owned a Nissan Frontier, I always ran it on 89 octane. I kept careful mileage records on regula, tried 89 and found that my cost per mie was actually lower. Also, slight pinging on grades went away as well. I run both my VWs currently on 89 octane for the same reason.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Nissan Kicks 89 octane [Re: lexus114] #5423966 05/08/20 09:52 AM
supton Offline
Sounds like you found your answer: it runs better on 89. As Boomer indicates, if the cost per mile is lower on 89, then that is the right answer all around.
[Some would run the 89 regardless of cost, just because it drives better--that of course makes sense too, but for many people, they find no difference in how something drives or fuel economy, thus higher octane makes no sense.]
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Nissan Kicks 89 octane [Re: lexus114] #5423978 05/08/20 10:12 AM
Char Baby Offline
Yeah, I've never gotten better fuel economy with any higher grade of octane. Slightly better throttle responce maybe in one or two older carbed engines but that's it.
Not more power but better responce. However, only enough responce to be felt in the seat of the pants but barely noticeable on a stopwatch.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Nissan Kicks 89 octane [Re: Char Baby] #5423993 05/08/20 10:46 AM
L
lexus114 Offline OP
L
Well I figured that little motor could use all the help I could give it..😆
Re: Nissan Kicks 89 octane [Re: lexus114] #5424006 05/08/20 11:01 AM
P
Pelican Offline
P
Originally Posted by lexus114
I bought a 2020 Nissan Kicks SR. Was in the owner’s manual it stated to use an octane of at least 87
Wait till the recommended 87 octane crowd see this! smile
Re: Nissan Kicks 89 octane [Re: lexus114] #5424009 05/08/20 11:06 AM
L
Lolvoguy Offline
L
Wow, I thought it was because it's Turbo that the additional octane helped the power.
Didn't think they'd run a NA setup in a 1.6 mini SUV in 2020!
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Nissan Kicks 89 octane [Re: Pelican] #5424015 05/08/20 11:22 AM
dtownfb Offline
I was thinking the "Top Tier" gas crowd would chime in.....
2006 Toyota Camry
2013 Toyota Sienna
2015 Toyota Camry
Re: Nissan Kicks 89 octane [Re: lexus114] #5424024 05/08/20 11:34 AM
O
Oildudeny Online Content
Online Content
O
Your brain is mapped to believe the extra money you're paying for fuel is giving you performance perks.. You'll never see noticeable gains like that especially in an engine like that and not immediately either it would take some mileage to see change but that would be in a higher output and high displacement engine.
Only thing you'll notice in slightly better mpg
Re: Nissan Kicks 89 octane [Re: lexus114] #5424028 05/08/20 11:46 AM
V
Vern_in_IL Offline
V
I see slight improvements, but it is not economical, the cost spread is way too high.
93 is 75 cents higher, even if it did help a little, it still did not recoup. the cost.
Re: Nissan Kicks 89 octane [Re: lexus114] #5424069 05/08/20 12:34 PM
W
walterjay Offline
W
87 Octane in my Tucson turbo does not work well. It is loud and struggles to go up long steep hills. With 89 it is perfectly happy and runs like a champ. No increase in gas mileage but it is able to use the fuller potential of the engine/turbo with 89. I also tried 93 octane and there was no appreciable difference in performance over 89. Twice I accidentally refilled with 87 and man the difference was incredible. Even my wife noticed when driving it.
Re: Nissan Kicks 89 octane [Re: lexus114] #5424081 05/08/20 12:50 PM
Z
Zaedock Offline
Z
Not even liquid Schwartz would turn a 122HP, struggle up hills engine, into a peppy ride.
The advance mapping takes time to learn and is not something you'll feel when you drive away from the gas station. I'm thinking the mental supercharger may have kicked in a bit when you hit the 89 button at the pump.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Nissan Kicks 89 octane [Re: lexus114] #5424086 05/08/20 12:53 PM
H
HowAboutThis Offline
H
I've put 87, 89, 91, 92 in my Corolla. It was all the same. Slow, underpowered, and gas mileage of 40-42.
Re: Nissan Kicks 89 octane [Re: Zaedock] #5424101 05/08/20 01:19 PM
L
lexus114 Offline OP
L
I think it’s more like char baby stated. Just better throttle response.
Re: Nissan Kicks 89 octane [Re: HowAboutThis] #5424103 05/08/20 01:21 PM
L
lexus114 Offline OP
L
My daughter has a new Corolla. She loves it.
Page 1 of 3 1 2 3
