Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
84 registered members (55hambone, 1978elcamino, 2015_PSD, 64bawagon, 97prizm, alchargo, 11 invisible), 2,062 guests, and 91 spiders.
Topics306,053
Posts5,286,491
Members71,593
Swapped my gauge cluster incandescent bulbs for LED, wow! #5423875 05/08/20 07:38 AM
dwcopple Offline OP
Gigantic difference. T10 LED bulbs with built in chipset so you can't reverse polarity by mistake. $7 for 10. Needed 5 for the cluster. Used 2 more for the plate bulbs out back. Huge difference on the '98 Stang.
2017 Acura MDX SH-AWD
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5423878 05/08/20 07:51 AM
Cujet Offline
Glad that you got good results. There are so many poor LED replacement products available, often times the results are less than ideal and color temperature/color rendition index is often very poor.
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: Cujet] #5423892 05/08/20 08:12 AM
N
Normac Offline
N
Exactly.
OP - if you don't mind me asking, what brand of T10 LED replacements did you use?
True victory does not come from defeating an enemy, true victory comes from giving love and changing an enemies heart.
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5423899 05/08/20 08:24 AM
E
E150GT Offline
E
Do they dim?
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: Cujet] #5423907 05/08/20 08:30 AM
wemay Offline
100%. Often times "better" just means a white or bluish light vs quality with these 'upgrades'. I'm glad the OP got good results from his.
2019 Volkswagen Passat Wolfsburg TSI: OE VW508.00 0W-20, OE filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE oil filter
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5423968 05/08/20 09:54 AM
Dave9 Offline
Umm, it seems like they were JUST replaced recently, so we have no idea if they are quality bulbs or will dim or burn out in tens of hours. Don't believe for one second, lofty claims of tens of thousands of hours lifespan that some garbage products make. Then again it is entirely possible to make long lasting LED bulbs, and they are usually dimmer than the incan bulbs they replaced when forced to fit in a small form factor as a retrofit.
A link would help. "Chipset" is not how they guard against reverse polarity in something that tiny, it is probably nothing more than a diode rectifier, which is fine, but says nothing about how overdriven the LEDs are for the amount of heatsinking present, vs brittleness of lead free solder, etc.
If they are brighter or bluer then I'd consider them a downgrade. Regardless of the lifespan, optimal night visibility is attained with less than fully bright dash lights and the more they get away from cold white (blue) and into the red spectrum, the better. That won't matter so much for the plate bulbs unless they are glaring into the eyes of the driver behind you, but is it an improvement if others can see your plate better? grin2
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5424049 05/08/20 12:10 PM
W
wrcsixeight Offline
W
My dash was lit up green with 194's inside a green plastic housing.
I wanted a red dash, so bought red LEDs replaced them and removed the green plastic housing. Way too bright, and they would not dim properly going from 100% too brightness to 85% which was still way too bright, then shutting off completely. Balls. Tried to live with it, but could not. Was not going to wire up a PWM LED dimmer just for the dash bulbs.
Replaced red T10 LEDs with red 194 incandescent, and no green plastic. All is well.
At same time, Replaced turn signal indicators with green Leds. Very bright, fine for daytime but switching lanes on the highway at night and they were too bright and would screw with my night vision. One started flickering within 2 years. Replaced with incandescent 194's. All is well.
High beam indicator also got replaced with a blue LED. Was blindingly bright. Too much work involved in taking apart dash just to swap it back, and I used 3 layers of 35% window tint to tame it down, and more recently replaced it back with a 194 incandescent. All is well.
The red LEDs I bought I employ elsewhere for non exterior signalling duty. They put out more heat than the 194 incandescents for similar current draw, and have all started flickering or failed outright with little use.
I tried some 1157 LEDs in my taillights. They had proper brightness difference between low and high 'filaments' and were slightly brighter than 1157 and seemed a genuine improvement initially.
Lasted less than 2 years before one failed completely and the other would start flickering once it heated up. Replaced with 3496 incandescent. All is well.
I wish I had all that money (and time) back I invested in LEDs only to return the incandescent.
Granted these were LEDs from a few years ago and LED's keep getting better, but still, I'll not be revisiting them again.
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: E150GT] #5424517 05/09/20 07:45 AM
dwcopple Offline OP
Originally Posted by E150GT
Do they dim?
Yes. Here's what I bought:
SEE HERE CLICK ME
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5425845 05/10/20 08:20 PM
N
Normac Offline
N
Do they dim?
SEE HERE CLICK ME
Cool. Thanks for that. Something I'll have to check into this week while i'm off work.
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: Dave9] #5425992 05/11/20 03:26 AM
bachman Offline
Car forums can be quite handy for stuff like that.
Often times, I'd found popular mods were easy to find. Other owners listed project details, photos, tips, etc... They rated how well it worked out or listed specifics to what was used and where they purchased,, even best prices too. This could be anything from modded exhaust systems, complete interior/exterior lighting and LED's, engine tunes / re-flash or turbo's , dyno tuning - on and on.
There is plenty of info out there by others who've already been there. Diode dynamics or CarID were some popular sources on Nissan Infiinti forums for projects on the 350 / 370Z or G-series. I think lighting is popular because it's almost pennies on the dollar for costs versus other projects. thumbsup
I did LED on my G going by others information and your point about the type and direction of plate lights is accurate. If the flood of hyper white is not on the plate or even too bright, you won't get the desired benefit. Blinding traffic behind you isn't a desired benefit either. Knowing these details before you buy is vital unless you have time and money to burn. smile
95 Honda Nighthawk- Rotella T6 syn
17 Golf SW 4MO dsg- Dealer LOF/5-6k *New spec syn -VW/Audi XOM ?
16 Mazda CX9 Tour- Dealer LOF/5-6k Casterol full syn
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5429678 05/15/20 08:07 AM
K
kc8adu Offline
K
vast majority of the led drop in replacements are poor quality.
either they dont last,have poor light distribution,poor color rendering,or all the above at once.
i repair lots of clusters and other vehicle controls and when i do a led upgrade i use quality leds and install them permanently.
they will dim and cast no ugly bright spots on the instrument faces.
i take out lots of those plug in led things and some are only a few months old but totally cooked.
ones from recognized brands are just"ok".
but they even run too hot for good lifespan.
Re: Swapped my gauge cluster incandescent bulbs for LED, wow! [Re: dwcopple] #5429788 05/15/20 10:32 AM
J
JTK Offline
J
Which vehicle did you do?
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
