Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
81 registered members (4WD, 2015_PSD, 28oz, 2010Civic, 2004tdigls, 55hambone, 7 invisible), 2,282 guests, and 31 spiders.
Topics306,297
Posts5,289,787
Members71,618
What fluid to run in fresh PS system #5423792 05/08/20 04:57 AM
L
luca Offline OP
L
So I just finished replacing the power steering gear, power steering pump and all the lines in my 1998 GMC Sierra. Everything is new.
Is it ok to run Maxlife ATF as power steering fluid (I have some already)? Or do I need to run branded "power steering fluid" that's approved for GM PS systems?
Re: What fluid to run in fresh PS system [Re: luca] #5423803 05/08/20 05:32 AM
M
MParr Offline
M
Valvoline Power Steering Fluid. It meets GM and Ford specs.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: What fluid to run in fresh PS system [Re: luca] #5423809 05/08/20 05:52 AM
G
GMguy84 Offline
G
Lucas cause it's DA BEST thumbsup
[Linked Image]
01 Silverado 1500HD Shell RGT 5W30/XG3675
01 Suburban 1500 Delo 10W30 400XLE/Protec166
02 Suburban 1500 Delo 10W30 400XLE/Protec166
82 Trans Am (KITT) M1 10W40HM/XG5
Re: What fluid to run in fresh PS system [Re: luca] #5423832 05/08/20 06:45 AM
Donald Offline
I would go with Valvoline. Or Amsoil. Skip the Lucas anything.
2015 Ford F-250 w/Powerstroke
Re: What fluid to run in fresh PS system [Re: luca] #5423901 05/08/20 08:25 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I see that Lubeguard has some. Id think it may be a good option since it uses their wax esters.
Re: What fluid to run in fresh PS system [Re: luca] #5423904 05/08/20 08:27 AM
Marco620 Offline
I would use Lubegard,Amsoil,or Redline. Skip the Lucas but if you see it anywhere put something in front of it to protect the uninformed.
15' Civic r18, 337,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Gumout PEA
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
Re: What fluid to run in fresh PS system [Re: luca] #5423929 05/08/20 08:50 AM
CT8 Online Content
Online Content
What is the recommended fluid?
2015 F150 2.7
2018 F350 6.2
Re: What fluid to run in fresh PS system [Re: CT8] #5423931 05/08/20 08:52 AM
G
Gebo Offline
G
That's what I would use. The recommended fluid.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: What fluid to run in fresh PS system [Re: luca] #5423960 05/08/20 09:42 AM
G
Gebo Offline
G
I just did a little searching at it "appears" your PS fluid should not be an ATF. It needs to be a PS fluid and probably GM.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: What fluid to run in fresh PS system [Re: luca] #5423970 05/08/20 09:58 AM
M
mattwithcats Offline
M
Older GM vehicles use Dexron III as a power steering fluid...
Maxlife is Dexron VI, viscosity is too low...
Get the blue jug of Dex/Merc, or any Dexron III....
https://www.walmart.com/ip/Valvoline-DEX-MERC-Automatic-Transmission-Fluid-1-Gallon/15125788
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: What fluid to run in fresh PS system [Re: luca] #5423972 05/08/20 10:02 AM
T
tig1 Offline
T
I have used M1 ATF in my PS pumps for about 30 years and have never had a pump failure. Yet. Also my pumps are very quite in sub zero temps.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: What fluid to run in fresh PS system [Re: luca] #5423982 05/08/20 10:22 AM
Z
zzyzzx Offline
Z
Re: What fluid to run in fresh PS system [Re: luca] #5424019 05/08/20 11:26 AM
slacktide_bitog Online Content
Online Content
Yes, you can use Maxlife smile
Re: What fluid to run in fresh PS system [Re: luca] #5424124 05/08/20 01:48 PM
R
RyanY Offline
R
A lot of hate for Lucas products around here and I can't say it is all unwarranted. However I agree with @GMguy84 that Lucas PS fluid is a solid performer (maybe not "best" but it is right up there). Of course, IMO it is only worth straying from OEM fluids/parts when you have a problem to solve, so the OP's new PS system will likely do fine on any GM-approved or compatible fluid. But if the steering becomes notchy or otherwise un-smooth, don't knock Lucas until you try it! Their universal "For all power steering systems, even Honda" stuff smoothed out the steering in my Honda and Cad when approved fluids did not. Just sayin'
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
Re: What fluid to run in fresh PS system [Re: tig1] #5424128 05/08/20 01:52 PM
B
BAJA_05 Online Content
Online Content
B
I know and you drink your medication and vitamins down daily with M1 also right???
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
