e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
76 registered members (4WD, 2015_PSD, 94astro, Avery4, 2010Civic, 7 invisible), 2,267 guests, and 94 spiders.
Topics306,301
Posts5,289,831
Members71,618
Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine #5423762 05/08/20 01:49 AM
M
mahanddeem Offline OP
M
Hello,
Last month, I changed the engine oil and filter in my brother in law Honda HRV 2018 AWD.
We got Mobil1(from walmart) and Honda OEM filter 15400-PLM-A02 (from a local Honda dealer).
I was surprised by how heavy and quality the Honda OEM filter seems. Liked it a lot.
This OEM filter is the equivalent of Mobil1 M110A (according to Mobil 1 website oil selector)
My Nissan engine can use Mobil M110A. I would assume since both engines can use M110A then both engines can use the said Honda filter.
1. Will I be safe using this Honda filter on my Nissan engine?
2. Anyone knows the bypass pressure setting on the Honda filter? Should I be concerned about that?
Thanks
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5423768 05/08/20 02:31 AM
ctechbob Offline
Don't see why not. If both cars cross to the M110A then it should be perfectly fine.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5423770 05/08/20 02:33 AM
W
WhyMe Offline
W
# 7317 filter which crosses with the mobil is used in both nissan and honda engines for years. maybe a few others also. i would have no problem using the honda filter in your nissan
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: ctechbob] #5423774 05/08/20 02:57 AM
Z
ZeeOSix Offline
Z
+1 ... and the bypass setting in either filter should also be adequate for either car.
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5423930 05/08/20 08:51 AM
CT8 Online Content
Online Content
Name brand clash will happen.
2015 F150 2.7
2018 F350 6.2
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5423967 05/08/20 09:54 AM
N
NormanBuntz Offline
N
Many Nissan and Infiniti owners whose cars call for the 6607 short filter opt instead to use the 7317 long filter unless you have space restrictions on your model.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424014 05/08/20 11:17 AM
U
UncleDave Offline
U
Originally Posted by mahanddeem
Hello,
Thanks
1. yes it will be fine.
2. Dont know but you'll be fine - it uses a standard fram bypass poppet - I think 18LB?
Heres a cut and paste of an AO2 Its a decently constructed filter.
Not a 20K mile piece- but you will be good for one OCI even though Honda leaves them in a log time.
UD
https://www.youtube.com/watch?v=t3HLwZFXIG4&t=4s
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424021 05/08/20 11:27 AM
slacktide_bitog Online Content
Online Content
Yes, you can use the Honda filter on your Nissan with no problem. Most Japanese cars use the same size oil filter, except Toyota
The A02 is a PH7317
The bypass setting of the 7317 and 6607 are the same. The only difference is the length.
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424025 05/08/20 11:38 AM
deoxy4 Offline
You can check cross reference number for the 15400-PLM-A02 filter in the link below. There are a number of Nissan oil filter numbers.
https://www.oilfilter-crossreference.com/convert/HONDA/15400-PLMA02
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424054 05/08/20 12:14 PM
A
aquariuscsm Offline
A
My 300ZX came with an Ac Delco oil filter. I’d bought it from a Chevrolet dealership in Dallas.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424067 05/08/20 12:31 PM
F
FordBroncoVWJeta Offline
F
The OEM Honda filter is just a rebadged Fram.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424074 05/08/20 12:42 PM
M
M
Thanks guys for the replies
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: deoxy4] #5424075 05/08/20 12:42 PM
M
M
Good link. That's very helpful. Thanks
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: NormanBuntz] #5424078 05/08/20 12:46 PM
M
M
In my Maxima 2009, no space restriction at all. I used both short and long Nissan filters before. But I am considering this longer (M110A) equivalent Honda filter now instead of the shorty nissan one.
Re: Honda OEM filter Honda 15400-PLM-A02 in my Nissan engine [Re: mahanddeem] #5424146 05/08/20 02:10 PM
diyjake Offline
Is the PH7317 a good filter? I have been using XG7317 but it might be overkill since I usually change my oil very 5k.
