Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
17 registered members (blufeb95, BlakeB, ArrestMeRedZ, dishdude, bachman, E365, 2 invisible), 1,165 guests, and 45 spiders.
Topics306,047
Posts5,286,353
Members71,593
Page 1 of 6 1 2 6
Interesting look at Mazda OE 0w20 SN/GF5 #5423671 05/07/20 08:50 PM
B
buster Offline OP
B
SA is 1.03, just above the dexos limit of 1.0. Noack is 13.1%. Lot of moly and boron.
[Linked Image]
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423702 05/07/20 09:37 PM
CT8 Offline
Spanish or Portuguese?
2015 F150 2.7
2018 F350 6.2
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423719 05/07/20 10:24 PM
E
E150GT Offline
E
I used to use Mazda oil from the dealer but I got tired of paying $8.60 a quart
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423729 05/07/20 10:52 PM
T
tundraotto Offline
T
Lots of moly, boron and calcium indeed...........not so much TBN
Shame the "Mazda moly oil" is so expensive.
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423730 05/07/20 10:57 PM
Strjock81 Offline
High Noack indicative of less than stellar base stocks?
2016 White Town and Country Touring
2015 White Yukon XL Denali
2014 White Ram 2500 CCSB 4x4 Cummins Bighorn
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: Strjock81] #5423733 05/07/20 11:06 PM
G
Gokhan Offline
G
No, the CCS is pretty low. You need to take the CCS and Noack simultaneously into consideration. Therefore, the base oil is likely Group III+ and/or GTL.
The additive package seems outdated with no magnesium and a weak TBN despite the high SA.
An MSDS shows that it is made by Total.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: Gokhan] #5423753 05/08/20 01:14 AM
G
Gokhan Offline
G
Note that the viscosity index VI = 219 is ultra high, meaning the base oil is very thin and the VII content is very high, typical of Japanese-OEM oils aimed at improving the fuel economy through a ultra-high VI by increasing the VII content, which could compromise the engine wear and engine deposits.
Therefore, the reason for the high Noack is the very thin base oil. The base oil is otherwise still Group III+ and/or GTL according to the CCS and Noack.
Interestingly the oxidation number, if correct, may indicate the presence of a small amount of a POE (polyol ester) base stock (3 - 4%). I saw the same thing with the TGMO 0W-20 -- it could be another Japanese-OEM thing not talked about.
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423815 05/08/20 06:18 AM
O
Oildudeny Offline
O
Has everything Mobil AFE is packing
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423818 05/08/20 06:24 AM
B
buster Offline OP
B
cheers
Definitely wouldn't be my first choice lol.
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423839 05/08/20 06:54 AM
B
benjy Offline
B
overpriced like most dealer products + poor oil according to specs!!
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: benjy] #5423938 05/08/20 09:04 AM
A
ARCOgraphite Offline
A
Really ?
Never found mid-high NOACK to be an issue in practice.
But maybe I don't practice enough ...
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5423965 05/08/20 09:51 AM
DBMaster Offline
It makes great lube for folding knife pivots! I used it for a short while, but have since switched to M1 EP 0W-20, High Mileage (I have 115,000 miles on the Mazda3).
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: DBMaster] #5424120 05/08/20 01:44 PM
Strjock81 Offline
What kind of OCI do you run on your knife pivots? Got any UOAs?
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: Strjock81] #5424141 05/08/20 02:02 PM
DBMaster Offline
LOL. The OCI is based upon feel. Knives with ball bearing pivots are awesome. I keep a medical syringe with the Mazda oil in it. Hopefully, no one will ever get the bright idea of injecting himself with it.
For my car I now am stuck with a mere 15,000 mile OCI because microGreen went out of business. I was using their filters and running 30,000 miles between oil changes. LOL
Re: Interesting look at Mazda OE 0w20 SN/GF5 [Re: buster] #5424240 05/08/20 04:41 PM
H
haggler Offline
H
This is the oem mazda oil for Europe made by Total. Can tell by the packaging. Comes in 0w20 and 5w30.
The USA Mazda "moly" oil is made by Idemitsu - ZEPRO Eco Medalist Advanced Moly. On the amazon questions section Idemitsu confirms it's the Mazda factory fill, maybe Subaru also.
2019 MX-5 Soft Top Miata - Soul Red Crystal - M1 EP 0w20 - M1 EP 108a Filter
2020 Chevrolet Equinox - Factory Fill/Filter
Page 1 of 6 1 2 6
