GTX Ultraclean now in 0W-20
by wemay - 06/05/20 08:38 AM
Glassware for bevarages
by Duffyjr - 06/05/20 08:24 AM
New Permatex Orange Threadlocker
by Snagglefoot - 06/05/20 07:39 AM
Peak Blue 64oz Diesel Cetane Booster $14.49
by Bighorn2500 - 06/05/20 07:22 AM
OTC Stinger 3 Ton Jack Stands, no good
by michaelluscher - 06/05/20 06:44 AM
$900 + a lot of shipping/fees electric car
by madRiver - 06/05/20 06:44 AM
PUP SP
by Koncrete_Cam - 06/05/20 05:52 AM
Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
Jettero, TinyHouseTruck, stubby73, Polkaman, Ramboagain
71610 Registered Users
100 registered members (440Magnum, 1911CHAMPION, aquariuscsm, AndyB, 2015_PSD, 2004tdigls, 7 invisible), 1,592 guests, and 44 spiders.
Topics306,237
Posts5,288,777
Members71,610
Pertronix Distibutor Help #5423597 05/07/20 07:04 PM
J
JeffKeryk Offline OP
J
A friend has a 55 F100 with Chevy 350 base crate engine and 700R4 transmission.
It ran with an HEI, but the HEI had problems and was a tight fit against the firewall.
He bought a Pertronix Bullet Distributor (ready to run) and Flame Thrower external coil.
Installed distributor and wired it to coil. Used 12v from HEI wire to + side of coil.
No spark. Nothing out of coil.
Does anyone have experience with these?
I have a trouble ticket in with Pertronix...
Thanks in advance.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5423616 05/07/20 07:42 PM
spasm3 Online Happy
Online Happy
Is he using the HEI module? If he had problems before, the module could be the problem.
Get a meter out and see if there is 12 going to the coil.
[img]https://www.jalopyjournal.com/forum/attachments/hei-jpg.2926295/[/img]
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5423643 05/07/20 08:17 PM
Chris142 Offline
I can't help. I had zero luck with Pertronix products. I had one that replaced GM points. It caught on fire one day. Burned my distributer down and the paint off my hood lol
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5423683 05/07/20 09:03 PM
J
J
The HEI is removed. The distributor is the Pertronix Billet Ready to Run.
There is 12v to the coil.
2018 Lexus RX450h
2006 Acura TSX
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5423699 05/07/20 09:33 PM
clinebarger Offline
2001 Chevy Camaro L92/4L80E
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5424004 05/08/20 11:00 AM
J
J
Pertronix sent me a troubleshooting guide.
Basically sez you need 10v or better when cranking engine. 14.2v with engine running.
I only checked with key on.
Given this truck has been rewired and may not have sufficient voltage this is my next test.
Thanks to all.
2018 Lexus RX450h
2006 Acura TSX
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5424029 05/08/20 11:48 AM
W
wag123 Offline
W
Is there a ballast resistor or ballast resistance wire in the ignition system's power delivery circuit?
Re: Pertronix Distibutor Help [Re: Chris142] #5424071 05/08/20 12:38 PM
U
user52165 Offline
U
It's been a long time, but back in the day, I had good luck with Allison or Mallory pointless setups. Pertronix was always rated poorly by those who installed. This is a very simple basic system. Rip out all ignition wiring and start over. And use upgraded battery cables and gear reduction high torque starter.
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5424110 05/08/20 01:27 PM
J
J
180* out. Oldest trick in the book.
I'm fired.
Thanks for the suggestions.
Sometimes I gotta laugh at my stupidity.
2018 Lexus RX450h
2006 Acura TSX
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5424138 05/08/20 01:59 PM
M
mk378 Online Content
Online Content
M
Being out of timing it would still spark though.
Looking briefly at the Pertronix website I see that they have different models for clockwise or counterclockwise rotation, so make sure you have the right one for the application. Though it may fire you're going to have operational issues with the wrong rotation. Also the "simple two wire" setup means that it depends on grounding through the distributor body to the engine block. When you have the clamp loose for adjustment it may not be grounded very well.
Re: Pertronix Distibutor Help [Re: mk378] #5424164 05/08/20 02:43 PM
J
J
I agree, which is what blew me away.
Out of time should kick, sputter, backfire. It did none of those.
Now it's running fine.
2018 Lexus RX450h
2006 Acura TSX
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5424170 05/08/20 02:54 PM
M
Online Content
M
Being exactly 180 degrees off timing an engine will generally do nothing but crank like it is not sparking at all. Maybe if you completely flood it, it will eventually backfire all the accumulated gas.
But if you do a spark test there will be sparks. Also if you hook up a timing light you'll see cylinder 1 firing on the TDC mark on the crank pulley like it should. But it is firing at the "other" TDC.
Re: Pertronix Distibutor Help [Re: mk378] #5424190 05/08/20 03:23 PM
J
J
That's where I was. But the timing light was not firing. I haven't used the light in a long time.
FYI - someone else found the problem earlier this morning; I was not there today.
2018 Lexus RX450h
2006 Acura TSX
Re: Pertronix Distibutor Help [Re: JeffKeryk] #5425028 05/09/20 07:57 PM
another Todd Offline
I have replaced the points/condenser on several vehicles and boats with a Pertronics module and they have always worked perfectly. Love them. Never installed a complete Pertronics distributor though.
2017 Ford Escape 2.0
2002 GMC Yukon
2008 Yamaha Rhino 700 FI
2010 Itasca Meridain/Freightliner Cummins 6.7 non DEF
