Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
24 registered members (bachman, BlakeB, bworley, ajchien, Cdn17Sport6MT, 2 invisible), 1,174 guests, and 58 spiders.
Topics305,879
Posts5,281,962
Members71,528
Electrician question 120v/240v dual purpose cord. #5423566 05/07/20 05:55 PM
dja4260 Offline OP
I'm purchasing a unit the operates on 120v OR 240V with the flip of a switch. The manufacture tells you to cut the cord to make the change from 120v to 240v.
With that said, I'd like the flexability to use this unit on either 120v or 240v whenever I please.
I'd like to use my existing 240v receptable that my dryer uses or any other 120v receptacle of my choosing.
In the video below, a guy makes a cord that would serve that purpose.
120v to 240v plug in
Thoughts on this cord? I'm not an electrician.
I understand the reason why the company tells you to cut the cord.
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423570 05/07/20 06:05 PM
M
mk378 Offline
M
I have seen this before. Someone, quite likely you, will inevitably come along and plug a 120 volt appliance into that 240 volt socket, and kaboom.
It's only a couple of minutes to swap on a different plug if you wanted to change back.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423572 05/07/20 06:07 PM
O
Oildudeny Offline
O
Won't work you'll have to decide if you want 120 or 240v.. A 120v cord will have a hot,neutral and ground.. The 240v cord in that setup is 2 hots and a ground. Play it safe if it came wired for 120v leave it. Don't get yourself killed.
Re: Electrician question 120v/240v dual purpose cord. [Re: mk378] #5423575 05/07/20 06:13 PM
dja4260 Offline OP
I expected a response such as this. You'd be correct that it would only take minutes to change out the end of the cord. I need to put the 240v on a GFI as well since I'll be playing with liquid.
1997 HD Sportster
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423576 05/07/20 06:13 PM
Snagglefoot Offline
I have a 220 V 40 Amp RV receptacle at outside corner of my house so visitors can park their RV and use their AC. I also have a crossover plug to go back to 110 V for my log splitter. No way to confuse them.
If you want the job done right......do it yourself.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423578 05/07/20 06:15 PM
U
user52165 Offline
U
What is this unit? There are usually benefits to using 240V full time. But don't get caught up in the instant switching game from 120 to 240.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423584 05/07/20 06:29 PM
F
Farnsworth Offline
F
You need a four wire feed. To get 120 the neutral carries current. I would think it requires a small panel then supply a 240 and 120 outlet separately from that panel. Check with a licensed electrician.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423587 05/07/20 06:41 PM
dja4260 Offline OP
It's a homebrewing electric kettle. There is a switch on the unit, behind a cover that you switch for 120v / 240v. I have a 240v plug in my basement and workshop, and 120v on my patio and kitchen. I'd enjoy the flexability to brew where I choose based on weather, plans for the day, etc.
240v speeds up the brewing process significantly.
1997 HD Sportster
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423596 05/07/20 07:02 PM
M
mk378 Offline
M
Once you have tried both you'll never want to use it on 120 again. It is possible to make up 240 volt extension cords.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423602 05/07/20 07:16 PM
samven Offline
The adaptor cable he shows will work just fine, it is identical to the adaptor that I received from the factory with my stick welder. The only difference is that my welder automatically senses the voltage and changes over but you have to remember to flip the switch, thats the very important part and only danger I see.
Re: Electrician question 120v/240v dual purpose cord. [Re: Farnsworth] #5423605 05/07/20 07:24 PM
B
bullwinkle Offline
B
The 4 wire outlet (usually twist lock) will have 2 hot leads, a neutral, and a ground. Either hot lead to the neutral will give 120 VAC, the two hot leads would be 240 VAC. It would be possible to wire different receptacles, in different locations, for either 120 VAC (one of the hot leads won't be installed), or 240 VAC (won't need the neutral), but they would use the same plug. The 240 would be on a 2 pole breaker, the 120 would be on a 1 pole, and the plug/cord cap and receptacles are actually marked 120V/240V-that's what many generators use. I wouldn't bet on it passing code, but the only thing that would happen if you messed up would be a burned out brewer.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423607 05/07/20 07:26 PM
W
Wolf359 Online Content
Online Content
W
I'm just a little confused why you would do this. The outlets are different depending if they're 120 or 240. There's a reason for standards. Plus a dryer is typically a 30 amp outlet and that's different than a 20 amp 240v oultet.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423835 05/08/20 06:51 AM
Donald Offline
Do it so its safe. You will forget or be thinking about something else.
2015 Ford F-250 w/Powerstroke
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5423949 05/08/20 09:22 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
You could take a 240 terminal, which is setup with two hots, a neutral and ground, and connect to it a multi-wire branch circuit. Thus you could have a 240V outlet, and on the other end of a conductor, TWO 120V circuits that share a neutral.
That would be foolproof as long as the 240V end uses their NEMA receptacle, and the two 120V receptacles use the correct NEMA variant there. So you cant plug one into the other. But the design and female male polarity would need to be correct and foolproof.
That said, that's related to the circuit design. Not the load. I wouldnt want something that could change at a flip of a switch, without something that forces an exclusive alignment if using 210 or 240. Not sure how to do that - its why the NEMA setups are what they are.
Re: Electrician question 120v/240v dual purpose cord. [Re: dja4260] #5424050 05/08/20 12:11 PM
P
PandaBear Offline
P
So let me ask you this: the "home brewing" means for home use, not a home made kettle, right? In a nutshell the heating element is wired to either 120V or 240V with no electronics that can only work on 1 voltage / have to step down? You want to make sure you don't accidentally kill yourself if one of the "neutral" originally designed is touching the exterior then, I assume?
How many amps are you using? If I were you I'd keep the cord as is (120V) and use an "adapter" to work around voltage difference, or if you want it really safe, use the Europe / British / Asia style 220-240V plug / socket so you don't accidentally plug something 120V into 240V and fry it.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
