Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
88 registered members (antonmnster, 4WD, andy2001, Alfred_B, Arrechera, Atrocious, 6 invisible), 2,095 guests, and 24 spiders.
Topics307,450
Posts5,311,404
Members71,850
To winterize or not? #5423482 05/07/20 03:23 PM
slomo Offline OP
I have noticed that if I drain my mowers and trimmers that the fuel lines, diaphragms and such get brittle and fail on me. Hard starting or not and leaking fuel issues. This method was me dumping or using all the fuel then running the engine till it dies WITH the choke on.
Now that I have stopped doing the above, I've had zero issues. My new method is running fuel stabilizer year round. I fill each tank full to leave no air in the tank in winter months. Next spring they all start like they were brand new.
I spent $180.00 on a gas tank and fuel lines for my Maruyama trimmer. You guessed it, I ran it dry in the prior fall season. Oh and all my gear is kept inside my cozy garage.
What do you guys do?
slomo
Re: To winterize or not? [Re: slomo] #5423483 05/07/20 03:26 PM
F
FirstNissan Offline
F
I personally have been putting Sta-Bil into all of my small-engines for years. Something I learned from my pops when I was a kid. It seems to have worked thus far. Other, than that, I keep the tank half full during the winter just so that no lines freeze (I had read this years ago related to cars so I applied it to my smaller engines as well).
2017 Toyota Sienna
2019 Toyota Camry
Re: To winterize or not? [Re: slomo] #5423491 05/07/20 03:31 PM
R
ripcord Offline
R
I stopped draining for the winter after finding a farm co-op place that sells ethanol free fuel. I try to remember to add some Sta-Bil if I'm buying gas near the end of the cutting season. Since I've been running non-alcohol gas, I haven't had to work on a OPE carb since.
Re: To winterize or not? [Re: slomo] #5423502 05/07/20 03:51 PM
Dave9 Offline
I suspect that your fuel lines got brittle from age, not from being drained, that it was just coincidence that you happened to be draining them when it finally happened.
What I do is nothing. I don't get special fuel, use the same E10 that i use for vehicles at my preferred gas station (due to discounts from their affiliation with a grocery store). I do only mix 2 cycle oil mix at the rate I'll use it in the next couple months, then at end of season any gas left in cans gets put in a car or truck to use up, and start fresh with fuel in the spring (except for fresh I get for snowblower use in early winter, then any of that leftover gets put in a car to use up too.
The way I look at it, special fuel that I have to go out of my way for, or pay more for, and draining things, is more hassle than just cleaning and rebuilding a carb, replacing a primer bulb or putting bulk fuel line on every few years. I mean for small engines, especially 2 cycle. Anything I have that's 2HP or more, doesn't even need that done but once in a blue moon, after at least 10 years of use and then usually just a carb cleaning and new gaskets. Granted that's not commercial use. If I were using equipment commercially then I'd just have a spare carb for everything to swap in quick when needed, and then rebuild the old at my leisure.
Re: To winterize or not? [Re: slomo] #5423504 05/07/20 03:55 PM
supton Offline
I push to a corner and call it a day. When the next season comes around, I put in fresh gas and start. My stuff is freebie, old, easy to fix and nothing fancy. I expect a carb rebuild from time to time, but so far, other than when I first get the equipment, I have had little issues. YMMV.
I did give in and start using Tru-fuel in my chainsaw and weedwacker. So there's that.
Heh, I bought a used 4 wheeler recently. It had sat for at least 4 years. The gas tank had varnish of some sort in it. I put a rag onto a stick and mopped out what I could; I wound up replacing the fuel pump and the fuel lines. Dumped in fresh gas and ran it--no carb cleaning done, no gas treatment. I know E10 is belittled for what it can do when it gets loaded up with water, but I've found it to be good enough at keeping things clean, as long as one keeps it fresh--as in, run it low and refill. But again, I have little to lose if I guess wrong, so I hate to recommend to do as I do.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: To winterize or not? [Re: Dave9] #5423507 05/07/20 03:58 PM
F
fdcg27 Offline
F
^^^ This!
I put the mower back to work a few weeks back. After sitting for six months or so with maybe a quarter of a tank of fuel it started on the fourth or fifth pull.
I've found no advantage in using fuel additives and no disadvantage in using E10.
18 Accord Hybrid 30K HGMO 0W-20
17 Forester 36K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: To winterize or not? [Re: slomo] #5423515 05/07/20 04:16 PM
spasm3 Online Happy
Online Happy
I park my ope with fuel in it. My last mix of the season is 93 octane with stabil and tcw-3 1oz to 5 gallons of fuel. Seems if i leave fuel in the carbs, there is less air/oxygen and i have less problems with float stick and gum.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: To winterize or not? [Re: slomo] #5423517 05/07/20 04:19 PM
slomo Offline OP
Might be a coincidence on old fuel lines and the tank I replaced, just being old. My thought was with 2 cycle fuel that obviously has oil in it, tends to keep the lines and such lubed up and no air inside them to dry out and crack. I know the stabilizer has stopped all the multiple pulls to start and carb issues. Fuel lines that have had fuel inside them then left dry get hard as rocks.
slomo
Re: To winterize or not? [Re: slomo] #5423519 05/07/20 04:22 PM
J
joekingcorvette Offline
J
Yes I stabilize the fuel in everything and try to keep the tanks 100% full in the wintertime. My boat has a 115 HP Merc 4 stroke and those motors are very expensive. I have no had any problem at all with stabilizer and a full tank. The Corvette and small engines and riding lawn mower get the same treatment. I ran a Jiffy ice auger out of gas one year and had to take it to the shop because it didn't run correctly after sitting with an empty tank. I used to run everything out of gas and had ok results as well however I prefer full tanks with stabilized Premium now.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: To winterize or not? [Re: slomo] #5423527 05/07/20 04:33 PM
K
Kamele0N Offline
K
slomo
@the end of the season I just fill OPE with...
https://aspenfuel.co.uk/
And let it run enough to get to the carb....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: To winterize or not? [Re: Kamele0N] #5423529 05/07/20 04:35 PM
K
Kamele0N Offline
K
slomo
EDIT: for lesser used equipement (chainsaw trimmer) I run those solo on that fuel...its cheaper then my nerves when OPE doesnt want to start on stale fuel...
I also "rotate" fuel.....what it is not consumed in a summertime its passed to the winter equipement
Re: To winterize or not? [Re: slomo] #5423536 05/07/20 04:46 PM
69GTX Offline
Last couple years I changed to fully draining the system by letting the mower run out of fuel. I do add MMO and Techron all the time to keep the system clean from deposits and parts all lubricated. Next season, starts on first pull....using 6 month old gas to boot. This current mower has been trouble free with this routine. Leaving Stabil treated fuel in the tank prior to this always let to hard starts requiring starting fluid and other tricks. No more. I'm guessing Stabil is less combustible than MMO and Techron.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: To winterize or not? [Re: slomo] #5423542 05/07/20 04:57 PM
Duffyjr Online Content
Online Content
I do use red sta-bil all the time along with a shot of Star Tron and E0 but when I'm done with the mower or blowers I just park them, I don't eve bother with filling the tank, worked for me for close to 30 years.
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: To winterize or not? [Re: slomo] #5423606 05/07/20 07:25 PM
2
2010Civic Offline
2
You spent $180 on a weed wacker gas tank?
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: To winterize or not? [Re: slomo] #5423700 05/07/20 09:33 PM
CT8 Offline
I never have used stabilizer in any ope and I have 3 two strokes and 3 Honda GX160 engines, a Briggs Vanguard engine on a generator and a Honda GX 230 on a pressure washer and some other Honda lower end lawn mower engine and I have not had a problem with any of them sitting all winter. Some are 20 years old.
2015 F150 2.7
2018 F350 6.2
