I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
51 registered members (Arcoril, ArrestMeRedZ, 928, Black_Thunder, AZjeff, 77GrandPrix, 6 invisible), 1,469 guests, and 43 spiders.
Topics306,030
Posts5,285,225
Members71,566
Amsoil ATF for 2017 Elantra #5423473 05/07/20 02:49 PM
F
flinter Offline OP
F
Hi,
As my 2017 Elantra approaches 40K, and since I plan on getting it 10+ years (I drive about 12K a year), I am looking at doing a automatic transmission fluid change shortly. I know it has been said in some forums over the years that you MUST use genuine Hyundai SP4-M, otherwise you will void the warranty. Is that STILL the case for the 2017-2020 Elantra models? Any real benefits to use Amsoil over Hyundai OEM SP4-M, or is Amsoil mainly marketing hype?
Thanks
Michael in NJ
2017 Hyundai Elantra SE Value Edition
Purchased new with 10 miles
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5423477 05/07/20 03:02 PM
Rat407 Offline
I take it you have the 2.0? It looks like AMSOIL recommends the ATL. I would run that for sure. I really like AMSOIL's ATF fluids. I'm sure others here will say it is overkill or don't waste the money but for how many times you change the ATF fluid to me it is worth the cost for a quality fluid that has served me well for over 197k miles on a Silverado that tows often.
2002 Silverado 5.3 5w-20 AMSOIL
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5423480 05/07/20 03:12 PM
M
Mainia Offline
M
I ran Redline D6 in my Elantra GT and did a 100% flush by draining the pan, filling the pan and did 4 cycles of pumping out the fluid through the radiator cooler to get all the old Hyundai fluid out of the torque converter. I had a long hose attached to the ATF exit and brought the hose and bucket to the drivers seat area. I filled the trans and peed the ATF into the bucket until it grabbed air and I shut the car off and refilled the trans with 4 Qts. I repeated this 3 times till clean fluid came out and then did the final refill. The final refill I added 1 1/2 Qt type F racing Redline and 1 1/2 qt of low viscosity Redline type F to reduce the slip agents as I think it and Amsoil SS ATF still have too much slip agents in them for how I want my trans to work, but that's just me tuning shifting crispness. It took 13 Qts. to get it flushed out. Just a note: Hyundai fluid SP4-M is very good fluid, it is a synthetic, it is not garbage like like the semi -synthetic Toyota WS. I found some Hyundai external advertising PDFs that were posted for about a year and then taken down that said it was Ester based at one time. Whether they changed it, or they just went with a different spec sheet that did not post it had high Ester in it, who knows. Make sure you do a 100% flush and not just a pan dump.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5423486 05/07/20 03:27 PM
SevenBizzos Offline
The Amsoil FE ATF meets the SP-IV spec. Keep the mileage logs and receipts.
There is a nice thread about this that was about a Sonata, but the points on using the fluid are valid.
BITOG Sonata 2017 ATF Thread
2018 Ford Edge Sport 22k - Amsoil XL 5W-30, EA15k43
2009 Hyundai Sonata V6 Limited 175k - Mobi1 5W-30 HM, Puralator Pure One PL-35610
2002 Mustang GT 75k - Amsoil XL 5W-30, EA011,Rained on 7 times
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5423498 05/07/20 03:40 PM
F
flinter Offline OP
F
Rat407,
Yes, I have the 2.0 engine. And what is ATL??
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5423522 05/07/20 04:28 PM
Rat407 Offline
Originally Posted by flinter
Rat407,
It is the ATF fluid. Low viscosity that AMSOIL recommends if you look your vehicle up on their look-up guide.
Re: Amsoil ATF for 2017 Elantra [Re: Rat407] #5423544 05/07/20 04:59 PM
F
flinter Offline OP
F
rat407,
Ok, it actually shows 2 choices, the one you mentioned and another one for much less money!
Re: Amsoil ATF for 2017 Elantra [Re: SevenBizzos] #5423618 05/07/20 07:46 PM
M
Mainia Offline
M
SP-IV is the previous spec ATF. SP4-M is the latest spec.
2005 Honda Civic
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5424382 05/08/20 09:53 PM
harry j Offline
I have been using Amsoil ATF for many years. The original, un-rebuilt automatic transmission is still soldiering on after 578,000 miles.
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5424511 05/09/20 07:32 AM
M
MaximaGuy Offline
M
Stick with OEM fluids and having driven Hyundai on business they have super slick transmissions - I couldn't believe it was geared they drive like CVTs.
Their engineering is solid and fluids are solid - a lot to be desired from my German GLE350 in the transmission department (it may be a good idea for German engineers to learn a few things in the transmission department from the Koreans).
Having said that never screwww around in 3 things in a car, plugs, coolants and transmission fluids. You will repay dearly.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Amsoil ATF for 2017 Elantra [Re: Mainia] #5424559 05/09/20 09:04 AM
SevenBizzos Offline
Yes. Thank you for clarifying!
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5432937 05/19/20 12:31 AM
O
oilboy123 Offline
O
I've used Amsoil ATF in ATF+4 mopar, DexII, Mercon, and Mercon V vehicles. I just put Amsoil low Viscosity trans fluid in my Daughters 2018 Ford Edge. Have not driven it much after changing it. I have been impressed with how it has performed in different applications.
I don't know how it would do in the Elantra. I would try it............
Loyalty to country ALWAYS. Loyalty to government, when it deserves it.
― Mark Twain
Re: Amsoil ATF for 2017 Elantra [Re: MaximaGuy] #5433055 05/19/20 07:45 AM
G
Gebo Offline
G
Now that's what I'm talking about.... approved
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5433342 05/19/20 01:28 PM
R
Ram02 Offline
R
Just do 2 drain and fills with Amsoil SS and your set for the life of that Hyundai
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: Amsoil ATF for 2017 Elantra [Re: flinter] #5433421 05/19/20 02:56 PM
B
blufeb95 Online Content
Online Content
B
I went and looked a 2017 manual, the manual just says SP4, not SP4-m, Aisin makes an SP4 fluid that's pretty reasonably priced around $7/qt on Rock Auto. I'd stick with using a fluid that's explicitly SP4 during the warranty period.
