Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
90 registered members (Alfred_B, 830Lee, akh, 97prizm, ABN_CBT_ENGR, 4WD, 4 invisible), 2,131 guests, and 72 spiders.
Topics306,053
Posts5,286,527
Members71,593
Drain plug advice #5423324 05/07/20 10:44 AM
6
64bawagon Offline OP
6
I am going to drop the trans pan and change the fluid in my 2010 Wrangler Sport. When I have it off I would like to add a drain plug for future maintenance, does anyone have a recommendation on a reliable one to install and is ther a specific area of the pan thats best suited ?
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Drain plug advice [Re: 64bawagon] #5423328 05/07/20 10:57 AM
L
Leo99 Offline
L
Can you buy a new pan with a drain plug already installed?
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Drain plug advice [Re: 64bawagon] #5423329 05/07/20 10:57 AM
R
ragtoplvr Online Content
Online Content
R
Just a metal roof washer head self drilling screw in #10-32 located where it does not bother anything is perfect. if you strip it they make them in #12 and #14 sizes
Re: Drain plug advice [Re: 64bawagon] #5423337 05/07/20 11:09 AM
J
JMJNet Offline
J
Did you check the Jeep forum to see if anybody has done what you want to do?
There are more Jeep owners there than here.
So it should be more practical for you.
  • 2017 Toyota Sienna
Re: Drain plug advice [Re: Leo99] #5423351 05/07/20 11:29 AM
G
Gebo Online Content
Online Content
G
I like this thinking...
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Drain plug advice [Re: 64bawagon] #5423358 05/07/20 11:33 AM
U
UG_Passat Offline
U
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Drain plug advice [Re: 64bawagon] #5423395 05/07/20 12:31 PM
R
ripcord Offline
R
Another option is to buy a oil extractor. https://www.amazon.com/s?k=oil+extractor
Re: Drain plug advice [Re: 64bawagon] #5423411 05/07/20 12:57 PM
DBMaster Offline
I installed one of these kits on the pan of the TH400 transmission of my 72 Pontiac when I was much younger. It worked well and didn't leak.
https://www.amazon.com/80250-Automatic-Transmission-Universal-Drain/dp/B00029WR78
Re: Drain plug advice [Re: 64bawagon] #5423431 05/07/20 01:47 PM
Chris142 Offline
Take it to radiator shop and have them solder one in. We do it all the time.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Drain plug advice [Re: 64bawagon] #5423440 05/07/20 01:58 PM
K
Kira Online Content
Online Content
K
FMI (For My Information): What engine is in your 2010 Wrangler Sport? Just askin'
I went through this with my Ranger. I feared installing the above mentioned drain plug kit was leak prone.
People here got on and said they work fine and that I was over-thinking the fix. Good; I'm glad they work. I'd just use the kit if I were in your shoes.
Sis had the 4.0 6 in her '99 XJ and the transmission pan indeed had the gasketed sheet metal screw in the pan. When you unscrewed it EXACTLY one gallon of fluid drained. How clever of them. Still, that weak little screw didn't make me feel good.
My story ended happily because Dorman had a pan with a plug ($34) AND Amazon offered used ones for $11. I decided to go that way.
They sent me a new one for the $11.
Re: Drain plug advice [Re: 64bawagon] #5423447 05/07/20 02:14 PM
6
6
Its has the 3.8 liter minivan engine. No other engine options that year. It has less than 45k on it but its been flawless in 10 yrs.
Re: Drain plug advice [Re: 64bawagon] #5423448 05/07/20 02:15 PM
K
Kawiguy454 Offline
K
If you go the DIY route and have the pan removed I would weld a fine thread nut to the OUTSIDE of the pan. Then carefully drill the through hole afterward and use a bolt/washer to plug it. If you use as same nut / thread as the magnetic drain plugs available at AZ that would be a bonus.
Reason being that all the through hole drain kits Ive ever seen are basically a hollow bolt with a nut on the inside and a plugh that threads in, With this setup when you drain fluid you'll always have an amount that wont drain and all the heavy particulates will stay in the pan.... Bad. If you have the Dough an nice aluminum pan with integrated lowpoint drain is the way to go.
Re: Drain plug advice [Re: 64bawagon] #5423485 05/07/20 03:26 PM
Scuder Offline
This might fit the bill. The cheapest I've seen it from a company I trust. They price match with no hassle. Also available on Amazon, so with Prime, it might be less with shipping. Summit, PartsGeek. $31.79 plus shipping on Rock Auto.
https://www.jegs.com/webapp/wcs/sto...=&Nrpp=&No=&persistYmm=false
2019 Jeep Compass
2009 Pontiac Vibe
1968 Barracuda Formula S 340
Re: Drain plug advice [Re: 64bawagon] #5423569 05/07/20 06:05 PM
sloinker Offline
Buy the pan with a drain plug. Replace existing pan, buy a filter that comes with a new gasket, buy the Red Line C+ ATF,About 6 quarts iirc, have an inch pound torque wrench, look on youtube for the tightening and torque sequence. Easy-Peasy.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Drain plug advice [Re: DBMaster] #5423619 05/07/20 07:50 PM
K
K20FA5 Offline
K
I used to have a 2008 Ranger that I put something similar in and it worked fine. Never leaked and made pan drops much cleaner!
Mine-18 Silverado LT Z71 5.3L
Wife-17 XC90 T6 Inscription Polestar 2.0L twin charged
Kid-19 Sentra 1.8L
Kid-12 Civic 1.8L
