Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
18 registered members (buck91, deoxy4, Inspecktor, bachman, FFeng7, 1 invisible), 1,122 guests, and 32 spiders.
Topics306,047
Posts5,286,364
Members71,593
VMEO 0w20 thicker than PP & QSUD 5w20 #5423247 05/07/20 08:08 AM
B
Bighorn2500 Offline OP
B
Been bored so I did some research and compiled the data after looking at my oil stash.
Valvoline Modern Engine Oil 0W20 is actually a hair bit thicker by the numbers then Pennzoil Platinum 5W20 & a slight bit thicker than some others based of KV @100c.
I'm just guessing better base stocks or the add pack creates this?
BTW bought some 0w20 on clearance for $13.99 a 5 quart jug.
[Linked Image]
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: VMEO 0w20 thicker than PP & QSUD 5w20 [Re: Bighorn2500] #5423295 05/07/20 09:40 AM
Danno Offline
Same theme.
Noticed VME 5W-20 is thinner than PP 5W-20 at -30C, but VME is thicker at 100C, and the VME VI is lower.
Could this be due to a better base stock for the VME?
Wonder if GTL is all its cracked up to be?
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: VMEO 0w20 thicker than PP & QSUD 5w20 [Re: Bighorn2500] #5423306 05/07/20 10:02 AM
K
ka9mnx Offline
K
The HTHS is missing from most which would be a more telling story.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: VMEO 0w20 thicker than PP & QSUD 5w20 [Re: ka9mnx] #5423308 05/07/20 10:08 AM
B
B
Majority of the product detail sheets online did not provide then otherwise I would have included.
Re: VMEO 0w20 thicker than PP & QSUD 5w20 [Re: Bighorn2500] #5423335 05/07/20 11:05 AM
K
ka9mnx Offline
K
I know, it's sad. Even the more open man's (Mobil1) used to provide more information.
Re: VMEO 0w20 thicker than PP & QSUD 5w20 [Re: Bighorn2500] #5423339 05/07/20 11:09 AM
Cujet Offline
It's good to remember that the goal of many oils designed for fuel efficiency is a low HTHS.
Re: VMEO 0w20 thicker than PP & QSUD 5w20 [Re: Bighorn2500] #5423474 05/07/20 02:57 PM
G
Gokhan Offline
G
High KV100 for a 0W-20 is a bad thing in terms of engine wear. It shows that it has a thinner base oil and a higher VII content. The engine wear is dicated by the base-oil viscosity; so, you want the lowest KV100 possible, not a high KV100.
Here is the estimated base-oil viscosity and VII content values for the VME with the HTHS data as a guess:
Estimated base-oil viscosity at 150 °C (BO DV150) and VII content of selected oils
Note in the spreadsheet how the Euro-OEM version Valvoline SynPower™ MST C5 0W-20 has a low KV100 because it is designed with reducing the engine wear and engine deposits being the primary concern for Euro-OEM oils. For ILSAC oils on the other hand, the fuel economy is the primary concern; so, they use a thinner base oil with a higher VII content -- resulting in a higher KV100 -- to increase the viscosity index VI for better fuel economy, while compromising the engine wear and engine deposits.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
