KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
107 registered members (4WD, agarb, 830Lee, aquariuscsm, AndyB, Alfred_B, 11 invisible), 2,189 guests, and 47 spiders.
Topics305,997
Posts5,284,338
Members71,558
storing new motorcycle battery #5423221 05/07/20 07:36 AM
Z
zrxkawboy Offline OP
Z
Long story short, I thought I needed a new motorcycle battery, but it looks like the old one is OK. In the mean time, I ordered a new Yuasa. Since it comes dry with the acid in a separate container, I'm thinking it should be fine to put it on the shelf and store until needed...right?
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: storing new motorcycle battery [Re: zrxkawboy] #5423235 05/07/20 07:50 AM
SHOZ Offline
Yes a dry cell will store indefinably as long as it stays dry. Seal it up good.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: storing new motorcycle battery [Re: zrxkawboy] #5423237 05/07/20 07:53 AM
R
ragtoplvr Offline
R
That is the correct. good for a few years as long as the seal over the cell opening is intact. If the seal is broken when you get it, send it back. If you break it, activate immediately.
Follow the activation procedure, fill, let soak, charge, let rest again, charge a little more.
You can fill and install right away, this will cost you somewhere between 20% and 50% of battery life.
Rod
Re: storing new motorcycle battery [Re: zrxkawboy] #5423241 05/07/20 07:59 AM
G
gman2304 Offline
G
I’m sure the new battery will be fine stored dry, but how old is your old battery? What made you think the old one was going bad? Since you have already bought a new battery, why not go ahead and use it? My battery is 3 1/2 years old and starts my motorcycle fine, but I’ll probably replace mine soon. I wouldn’t want to be stranded in the middle of nowhere with a dead battery, knowing I have a new one on the shelf at home.
Re: storing new motorcycle battery [Re: zrxkawboy] #5423246 05/07/20 08:06 AM
SHOZ Offline
We use to make dry cell industrial batteries for fork trucks and submarines back in the day. They charge the plates up in big open tank rows with the individual pos/neg plates alternated and then linked with a lead strap. The acid they use is rather weak around 1.050 sg or so, whereas a finished battery will be around 1.250-1.275 sg.
The positive plate after being formed is just hung and dried in an oven. The negative plate that is now converted to active material is put in racks to dry, there is some sort of chemical reaction with air as they get warm and steam off the water. Then the negative plates are put in a big solvent filled pressure cooker to drive out the water. A battery made with this process is ready to go once filled.
Re: storing new motorcycle battery [Re: zrxkawboy] #5423310 05/07/20 10:11 AM
M
mrsilv04 Offline
M
That's the beauty of dry charged batteries.... shelf stable for a long time.
In three decades of motorcycling, that's about the only advantage that I've ever been able to find, though.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: storing new motorcycle battery [Re: zrxkawboy] #5423313 05/07/20 10:16 AM
SHOZ Offline
Small battery you are better off with an AGM.
Re: storing new motorcycle battery [Re: zrxkawboy] #5423451 05/07/20 02:18 PM
R
ragtoplvr Offline
R
They make dry charge AGM.
Rod
Re: storing new motorcycle battery [Re: ragtoplvr] #5423455 05/07/20 02:22 PM
SHOZ Offline
Rod
That would be a neat trick. Last AGM I bought for my John Deere only last 15 years.
Re: storing new motorcycle battery [Re: zrxkawboy] #5423457 05/07/20 02:26 PM
K
Kawiguy454 Offline
K
Store wet batteries in cool place. heat will lower lifespan
Re: storing new motorcycle battery [Re: SHOZ] #5423513 05/07/20 04:12 PM
R
ragtoplvr Offline
R
Rod
Yuasa makes them so must be OK.. They say shelf life is 5 years.
