D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
101 registered members (01rangerxl, 10WSmuckers, 2K2AcuraTL, 28oz, 4WD, 830Lee, 14 invisible), 1,815 guests, and 71 spiders.
Topics306,265
Posts5,289,276
Members71,615
Post how much fluid remains in trany / torque converter during a drain and fill #5423031 05/06/20 08:45 PM
J
JimPghPA Offline OP
J
Please use this thread to post information on how much fluid remains in the transmission, torque converter, and cooler during a drain and fill of the trany fluid and how much new fluid is put in, for different vehicles if you have that information, so you can get an idea of what percent of the old fluid remains in the trany.
I have a 2016 Honda CR-V with the CVT trany and AWD. The AWD version of this system takes 4 and 1/2 quarts to fill it back up after a drain. I have 20,500 miles on the vehicle and plan on drain and fills every 25K miles because I consider the hills of Pittsburgh to be severe service, and I plan on keeping this vehicle for a very long time. I was wondering how much fluid remains in the trany when this is done so I called the local Honda dealer and spoke to someone in the parts department. They were not sure but think a new dry unit would take about 7 quarts to fill. If that is correct then 7 - 4.5 = 2.5 quarts of the old fluid remaining in. That means after a drain and fill there would be about 64% new fluid in the trany and torque converter.
If anyone has more accurate information about how much fluid a dry system of a 2016 Honda CR-V CVT AWD takes please let me know.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423039 05/06/20 08:55 PM
samven Offline
Just did an 03 Ram 5-45. 12 qt fluid capacity needed 7 qts after pan drop and both filters were replaced. Front end was jacked up and I think I got about 1 qt more than I normally would.
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423041 05/06/20 08:57 PM
J
JimPghPA Offline OP
J
I saw a post on a Honda CR-V forum where someone said that they checked the trany fluid after the dealer did a drain and fill and it was dark. They complained that the dealer did not change the fluid, and charged them for doing it when they did not. But after thinking about it, I thought that if the old fluid was really dark and enough of it stayed in, then it could make the new fluid look dark. So maybe that is something to keep in mind when the fluid is drained and filled. Some vehicles take quite a bit of fluid for the torque converter and usually the old fluid in the torque converter stays there during a drain and fill, and then mixes with the new fluid when the vehicle is ran after the fill.
JimPghPa
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423053 05/06/20 09:13 PM
J
JeffKeryk Offline
J
I got a well used 2015 Altima with 80K miles from Hertz for a friend. The CVT had never been serviced.
The fluid was almost black on the initial service.
I did another in about 2K miles; the fluid looked better.
The 3rd was done later (don't remember mileage) and the fluid looked reasonable.
You will be fine. Honda CVTs don't seem to have problems like other makes.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423054 05/06/20 09:14 PM
slacktide_bitog Offline
That method sounds good to me approved
One drain and fill each time the MM suggests it will be more than enough to last a long time smile
The case of Castrol CVT on Amazon is still the best deal, but theirs is red, which some people don't like. That doesn't stop the Castrol from being a good choice for your Honda.
However, if you don't like that, Walmart has Valvoline CVT at a good price and is amber colored.
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423077 05/06/20 09:43 PM
W
Wolf359 Offline
W
I never worried about getting every last drop of transmission fluid out. The factory recommendation is typically to drain the fluid and refill. They usually don't mention getting the fluid out of the torque converter so if you're following the standard recommendation, it's expected that there will be old fluid in the torque converter. I always felt it was a little OCD for the ones who wanted to get every last drop of old fluid out when the manufacturer never calls for that.
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423141 05/07/20 12:50 AM
N
NothingNew Offline
N
https://www.amsoil.com/lookup/auto-...yl-engine-code-k24w9-8/?volume=us-volume
For Automatic Transmission: BLJA (AWD)....VTF20
Capacities: 4.5 quarts Initial Fill
BLJA (AWD) Total Fill 8.9 quarts
Looks like a drain and fill gets just over 50% new fluid. I'd do 2x drain and fill to start. Then a single d&f every 25k sounds reasonable.
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423173 05/07/20 05:29 AM
L
Lubener Offline
L
2003 Ford 4R70W, dry capacity w/ oil cooler 13.9 quarts. Recent pan drop, filter and two day drain time yielded just shy of 7 quarts.
The "thinking" man's friend.
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423188 05/07/20 06:27 AM
R
Railrust Offline
R
I would say 2-3 quarts depending on the unit, more or less.
But I would tell you that I have owned Hondas (still actually have one in the family) and I always just did a drain and fill once a year, whether it needed it or not. One had 289,000 miles by the time I sold it (not one single problem with that tranny). And the other we still own (2008 CRV 144,000 miles), not a single issue with that entire vehicle. Never had anything quite as reliable as this one.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423191 05/07/20 06:39 AM
Donald Offline
Its on the Amsoil website for almost all vehicles.
2015 Ford F-250 w/Powerstroke
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423380 05/07/20 12:06 PM
bdcardinal Offline
Well considering I spent a good amount of yesterday and will be today emptying core transmissions that people didn't drain, it varies between 1-2 quarts on a 4R70W to 8 on a Torqshift.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5423394 05/07/20 12:26 PM
P
Pelican Offline
P
I don't know about CVT, but in the regular many shifts tranny what stays in the TC is about 60% so a D & F would only change about 40%
Anybody rebuilding a tranny ought to get a TC with a drain plug, like they used to have.
Re: Post how much fluid remains in trany / torque converter during a drain and fill [Re: JimPghPA] #5424903 05/09/20 04:49 PM
A
ARB1977 Offline
A
About a 1/3 fluid drains out of the pan on my Tacoma.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
