Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
16 registered members (bachman, Char Baby, blufeb95, BlakeB, bbhero, 1 invisible), 1,084 guests, and 42 spiders.
Topics306,047
Posts5,286,360
Members71,593
best way to pour oil in my car. #5422889 05/06/20 06:33 PM
J
JustinH Offline OP
J
Seems like a dumb question.
I have a 2016 Escape with the 2.5L engine.
I did my first oil change on it a few months back, now time to do again.
The oil fill hole is very small, and is buried under the plastic cowl.
The first time I did it, I rigged a funnel under there and bent the cowl up with one hand while I poured oil from a 5 quart jug akwardly.
No spills but I don't want to do it like that again.
I thought of buying quarts of oil, but it seems like that way of buying oil is cost prohibitive compared to jugs, and bags.
Can anyone recommend an oil can with a long flexible pour spout that is good quality and easy to measure?
Takes 5.7 quarts.
'16 Ford Escape
'11 Scion XB
Re: best way to pour oil in my car. [Re: JustinH] #5422900 05/06/20 06:46 PM
G
gfh77665 Offline
G
My 2006 Honda Odyssey was similar. I used a long narrow funnel, then I held a standard funnel over the narrow one. The two funnels allowed me to bend the path of the oil flow. I just had to avoid overflow from pouring too fast. It worked OK. I am not sure if this would apply to your Escape or not.
Re: best way to pour oil in my car. [Re: JustinH] #5422907 05/06/20 06:50 PM
skyactiv Offline
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: best way to pour oil in my car. [Re: JustinH] #5422910 05/06/20 06:52 PM
N
NormanBuntz Offline
N
Maybe one of those long transmission fluid funnels would work.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: best way to pour oil in my car. [Re: JustinH] #5422913 05/06/20 06:53 PM
W
Wolf359 Online Content
Online Content
W
I tend to pour from a 5 quart jug sideways. That way it doesn't glug when pouring which causes spills. Otherwise any old funnel works.
Re: best way to pour oil in my car. [Re: JustinH] #5422914 05/06/20 06:53 PM
Z
zfasts03 Offline
Z
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: best way to pour oil in my car. [Re: JustinH] #5422933 05/06/20 07:19 PM
B
Blkstanger Offline
B
My Escape is the same way. I use a funnel with a bend in it like the red one posted above. Works great.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: best way to pour oil in my car. [Re: Wolf359] #5422942 05/06/20 07:25 PM
I
Imp4 Offline
I
Sideways no glug pour for the win!!!!
Re: best way to pour oil in my car. [Re: JustinH] #5422953 05/06/20 07:33 PM
T
tig1 Offline
T
I have a 2017 Fusion with the 2.5 and I have none of the problems you speak of. Can you send a pic so we can see what you are talking about?
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: best way to pour oil in my car. [Re: JustinH] #5422981 05/06/20 07:53 PM
supton Offline
One method would be to buy 6 single quarts of what you plan to use. Use that up. Then buy the 5qt containers, or box, or what have you. Keep the empty single quart bottles and just transfer from the qty container into the smaller ones.
You could go as far as to buy just one container and keep shuttling back and forth, moving one qt at a time, but for the nuisance it might be worth doing it in the off days (refilling the single quart bottles that is).
IMO 5.7 is close enough to 6 to just dump 6 in, unless if you can show that it puts it way over the line... of course, if you're transferring into single bottles, it's trivial to put 0.7qt into one, I guess.
Can you find a funnel that has threads on it that match your engine? I think someone posted a funnel here for some Toyota applications.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: best way to pour oil in my car. [Re: JustinH] #5422982 05/06/20 07:53 PM
A
Alfred_B Offline
A
I use a 2 gallon garden sprayer. Fill the necessary amount of oil, pressurize it and let it fill the engine.
Works well, and saves time.
Re: best way to pour oil in my car. [Re: JustinH] #5423044 05/06/20 09:01 PM
slacktide_bitog Offline
Just get your oil at Napa. Their individual quart bottles go on sale a few times a year, no minimum, no maximum, so you're not stuck to multiples of 5 or 12.
The warehouse club boxes of 6 quarts would also suit your needs, or anywhere else you can buy by the case.
As you have discovered, the single quarts are easier to pour. The only time I use 5qt jugs is if the car takes around 5 quarts or something I can round to 5qt (4.9, 5.1, etc)
You might also like those flexible tubes that you'd use to fill a manual transmission or a diff.
Re: best way to pour oil in my car. [Re: JustinH] #5423055 05/06/20 09:14 PM
P
pbm Offline
P
I also have a 2016 Escape with the 2.5 …..that cowl that you speak of does make it hard to pour oil but a $1.00 long funnel
from Walmart makes it easy...changing the battery is far more difficult than it should be because of that cowl.
'Journalism is Dead'
Re: best way to pour oil in my car. [Re: JustinH] #5423105 05/06/20 10:31 PM
4
40w8 Offline
4
My BMW X1 and Mazda RX8 are both easy to get to, but I'm just shaky, so I'm gonna make a funnel out of my leftover Techron 20 oz container. Just cut the bottom off.
Re: best way to pour oil in my car. [Re: JustinH] #5423282 05/07/20 09:22 AM
G
Gebo Offline
G
https://www.motivxtools.com/collections/oil-funnels
I dump 5 qt oil container into my Toyotas and this funnel will take is as fast as it comes out of the jug. Makes me giggle every oil change as I try to choke it but I can't. They might have something for you.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
