Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
77 registered members (azjake, Blkstanger, 2015_PSD, 87sammy, aquariuscsm, 8 invisible), 1,892 guests, and 40 spiders.
Topics306,086
Posts5,287,113
Members71,596
Accord 2.4L Valve Cover Leak #5422746 05/06/20 02:44 PM
T
tc1446 Offline OP
T
Just noticed valve cover is seeping on my '13 Accord 2.4L . Front of motor is sticky from the residue, but not anywhere near enough that any has dropped on concrete floor. Is this a pricey job if done by a dealer?
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422750 05/06/20 02:48 PM
I
Imp4 Online Content
Online Content
I
RepairPal says about $275 for that job near me.
Granted, that's at an independent and not a dealer, so add 30%-50% for a ballpark dealer price.
Also please note that this job can be done in your driveway for the cost of the gasket (about $40 at Amazon for OEM) and about 2 hours of your time.
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422755 05/06/20 02:57 PM
H
hallstevenson Offline
H
This is a 7 year old car and one of the most common on the road. Absolutely no need to have this work done by a dealer. Any/every competent independent repair shop can easily handle this repair and for a substantial savings over the dealer's charges.
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422778 05/06/20 03:23 PM
B
blufeb95 Offline
B
I don't know about that car specifically but most 4-bangers it's really easy to change the valve cover gasket yourself.
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422783 05/06/20 03:33 PM
K
krismoriah72 Offline
K
Get a valve adjustment done, the valve cover replacement labor will be nearly free.
Re: Accord 2.4L Valve Cover Leak [Re: blufeb95] #5422787 05/06/20 03:36 PM
L
Leo99 Online Content
Online Content
L
Very easy on my Toyotas. Lots of videos on youtube for the Honda. Here's one. https://www.youtube.com/watch?v=YPQH68OsRLI
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Accord 2.4L Valve Cover Leak [Re: krismoriah72] #5422791 05/06/20 03:41 PM
The Critic Offline
At your mileage it is due for a valve adjustment anyway.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422821 05/06/20 04:30 PM
B
Bogdon Offline
B
Research the reliability of a non-OEM valve gasket cover versus the Honda variant. Some of the non-OEMs for my 06 Sentra Spec V are known to leak.
It doesn't seem like too difficult an undertaking. The key element is a thorough cleaning before putting in the new part/parts. If I'm not mistaken, there's typically a sealing process which suggests to me that this kind of work is best done by an experienced mechanic.
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422829 05/06/20 04:49 PM
J
JMJNet Offline
J
Replacing the VC gasket is easy for a 4 cylinder engine.
Just get Felpro gasket set.
Usually comes with the spark plug seals also, at least it was in the set for Camry.
The question to ask is why is it leaking?
Is the PCV bad? needs cleaning or replacement.
I am not sure if Honda have PCV.
  • 2017 Toyota Sienna
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422836 05/06/20 05:12 PM
Dave Sherman Offline
Having done a valve adjustment on a K24, it's not hard. Wouldn't hurt to check the valve lash anyway. Only thing that might not be commonly known is the service manual calls for two dabs of RTV at the front of the engine where the "points" on the valve cover meet the block. You'll probably see the old dabs from the factory. Scrape the old stuff of gently, replace the gaskets, put two fresh dabs on, and slip the cover back on. The "doughnuts" around the spark plug wells might catch on the sleeves, so take it easy. Actually, at 110K you're due for spark plugs if you haven't already done them. Good time to do it since the coil packs have to come off anyway.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422850 05/06/20 05:39 PM
Dave9 Offline
It could take you as long (or probably longer once you factor in paperwork and phone tag too) to drop it off at a shop, go home, then go back to pick it up when finished, as the time it takes to just DIY At Your Convenience.
Just something to think about... Unless DIY repairs aren't practical or allowed in your location and you are avoiding friends & family located repair sites because of the unspeakable event that we shall not speak of.
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422858 05/06/20 05:58 PM
J
JeffKeryk Offline
J
I don't think he is talking about the K24; in 2013 the new Accord used the Earth Dreams engine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422863 05/06/20 06:05 PM
T
tc1446 Offline OP
T
Thanks folks for good advice. I'm too senior (can't say that 3 letter word) to do the work.
It actually has 121,000 on it. I guess it is time to change the OEM plugs. It has been primarily my wife's car, gently driven, and computer shows last three fill-ups as 33 and 34 Mpg. She got 44 up and 38 back on a trip to Md last year.
It has been turned over to me since I traded my KIA on her new car (seems I always get the old one's!) and was in process of cleaning it today when I noticed the seepage from the VC.
There are two independent's nearby but I'm not familiar with their work. Will ask around to find out.
PS: Doe it use a belt or chain for timing?
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422867 05/06/20 06:09 PM
B
blufeb95 Offline
B
Should be a chain on the 2.4L
Re: Accord 2.4L Valve Cover Leak [Re: tc1446] #5422878 05/06/20 06:23 PM
J
Jake_J Offline
J
I'd check to see if the valve cover bolts haven't loosen up over time. It's pretty common on Honda and Toyota 4 cylinders that are around 10 years old, they don't need much torque but they shouldn't be loose. The 2.4L uses a timing chain, all the K engines do. The Earth Dreams 2.4L is just a revised and renamed K24.
