Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
73 registered members (4WD, ArrestMeRedZ, 762fermeandyou, 86cutlass307, 55hambone, aquariuscsm, 6 invisible), 1,984 guests, and 31 spiders.
Topics306,299
Posts5,289,808
Members71,618
Dead Short #5422690 05/06/20 01:32 PM
V
VQLT Offline OP
V
Easiest way to find a dead short without test equipment? keep blowing turn signal fuse (92 Nissan Pathfinder) sometimes the fuse will last a few months sometimes it blows w/in 15 minutes. must be a loose wire shorting out. just cant seem to find it. frown
Re: Dead Short [Re: VQLT] #5422693 05/06/20 01:36 PM
Donald Offline
Have you started out by looking at all the sockets that hold a bulb that blinks? Cracks and frayed wire?
Correct fuse?
Correct bulbs?
2015 Ford F-250 w/Powerstroke
Re: Dead Short [Re: Donald] #5422697 05/06/20 01:40 PM
V
VQLT Offline OP
V
yes. and I should also note that the emergency flashers work and they use the same bulb (not sure if they use the complete same wire circuit) I was thinking since the flashers work but the turn signal blows the fuse it might be in the turn signal lever?
Re: Dead Short [Re: VQLT] #5422701 05/06/20 01:49 PM
Dave9 Offline
The easiest way to find a short without test equipment is to buy test equipment. That's like asking what's the easiest way to ride a bike without a bike.
I mean sure, you can look for broken wires, black scorch marks, molten areas, sparks, smoke, fire, and little ninjas with wire cutting swords, but otherwise you are going to have to check on whether the emergency flasher does use the same wire ( pull the bulb housing and see if there's more than one bulb element or wire involved), and if it does you could always run a new wire. If it doesn't use a different wire then yes it is probably your signal lever which may or may not lend itself to being opened, inspected, and possibly cleaned out. Depends on how much trouble that is, whether to take it out to check it and possibly clean it, rather than buy a new one ahead of time.
If you have any kind of bulb out alert system in the vehicle, that monitors the flashers, you might also use your unavailable test equipment to check that too. wink
A multimeter is well worth owning, even if it's a low end $10 special.
Re: Dead Short [Re: Dave9] #5422703 05/06/20 01:52 PM
V
VQLT Offline OP
V
i'm not electrically inclined. what specific test equipment can find a short? I have used a multi-meter to test batteries smile but that's about it
Re: Dead Short [Re: VQLT] #5422704 05/06/20 01:52 PM
M
mk378 Offline
M
It's not a "dead short" if it occurs intermittently. Testing when it isn't shorted (which is almost all the time) will not reveal anything. Though of course you should look for frayed wires, broken parts and other obvious potential problems.
And you say the hazards don't cause it, but you only turn them on for a brief test.
First note if it happens on right or left turns.
There are circuit breakers that plug in in place of fuses, swapping in one of those can help reveal the problem since it will reset and let you try again.
Re: Dead Short [Re: VQLT] #5422724 05/06/20 02:15 PM
R
ragtoplvr Offline
R
This is a joke, sort of. Replace fuse with solid wire, carry wire cutters. When you smell rubber burning, hunt for the melting wire and cut it in two. Where the melting stops, there is your short.
Please please do not do this. I did know an old time mechanic from the 50's that would use this method. Of course cars then had like 20 wires total.
Rod
Re: Dead Short [Re: VQLT] #5422726 05/06/20 02:18 PM
c502cid Offline
You can also do the wiggle test to find an intermittent short if the fuse isn't blowing immediately. Put in a new fuse and start wiggling wires. When they fuse blows many times you found where or close to where the short was.
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Dead Short [Re: VQLT] #5422731 05/06/20 02:23 PM
W
wag123 Offline
W
I believe that the hazards are on a different circuit/fuse and I believe that the turn signal fuse also powers the backup lamps.
Does your Pathfinder happen to have a trailer wiring harness? If so, trace the wires down and look for a frayed wire. Also, if it has a logic box (very likely), it could be the source of your problem. The easiest way to check this is by disconnecting it from the vehicle to see if the fuse stops blowing.
This is the correct tool to use to find automotive electrical short circuits.
https://www.amazon.com/Tool-Aid-25100-Short-Tester/dp/B000RFLR0U
I have had one in my tool box for many years and have used it many times to find shorts.
Re: Dead Short [Re: VQLT] #5422735 05/06/20 02:26 PM
Chris142 Offline
Check the trailer wires at the rear bumper if it has that.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Dead Short [Re: VQLT] #5422738 05/06/20 02:29 PM
O
Oildudeny Offline
O
Hows the condition of the negative battery cable?
Re: Dead Short [Re: Dave9] #5422745 05/06/20 02:38 PM
E
exranger06 Offline
E
Originally Posted by Dave9
The easiest way to find a short without test equipment is to buy test equipment get a wiring diagram. That's like asking what's the easiest way to ride a bike without a bike.
Fixed it for you. Any time you have an electrical problem, your very first step should always be to get a wiring diagram. How are you going to trace the wires from one end to the other if you don't know where they go and what they connect to? How do you know which wires should have voltage if you don't even know how the circuit works? A wiring diagram lays it all out and shows you exactly how the circuit works, where the wires go, the color of every wire, any connectors and splices they go through, including which pin in the connector they're connected to, the location of the connectors and splices, and some even show the route/location of the whole wiring harness.
Trying to solve electrical problems without a wiring diagram is like trying to fix it while blindfolded.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Dead Short [Re: VQLT] #5422752 05/06/20 02:51 PM
Donald Offline
BTW - its not a dead short but rather an intermittent short.
Re: Dead Short [Re: Oildudeny] #5422758 05/06/20 03:03 PM
V
VQLT Offline OP
V
i cleaned the battery terminals but did not check condition of the battery cable. if the negative cable was bad, wouldn't it blow more fuses than just the turn signals?
does not appear to have a trailer wire harness
Re: Dead Short [Re: VQLT] #5422774 05/06/20 03:20 PM
K
Kawiguy454 Offline
K
A dead short will always blow the fuse immediately. You have a loose bare wire, contamination across terminals or a loose connection near the fuse.
A voltmeter is cheap. get one and Put it on appropriate Amps measurement then measure across the blown fuse with the circuit hot. Is the amp draw close to value of the fuse? If so over time it will blow. If not Is it the correct fuse value and is it a Chinese fuse from harbor freight? Check the bulb socket for contamination (partial short). Make sure the connections the fuse plugs in are also clean. Loose connections will generate heat which can conduct up to the fuse filament and melt it.
