Forums Migration
Please read this thread
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
101 registered members (2009Edge, BAJA_05, 2015_PSD, Aichiguy, asisensei, ABerns, 9 invisible), 2,051 guests, and 24 spiders.
Topics307,563
Posts5,313,203
Members71,876
Time or Mileage? #5422199 05/06/20 12:18 AM
A
Averroes Offline OP
A
Hope you’re all doing well and staying mentally and physically it during this COVID-19 mishap.
I was pondering about my manual transmission fluid and wondering when I should change it. Car is a 370z, last MTF change was in 2017, since then I’ve accumulated 13,000 km on the transmission fluid. Would it be overkill to change it now? I know brake and clutch fluid is hydroscopic so I change it every 2-3 years, regardless of the mileage.
Same question would be for the differential fluid, should that be time or kilometres based?
Thanks in advance for the help and insight l, it’s greatly appreciated.
Synthetic or bust.
Re: Time or Mileage? [Re: Averroes] #5422210 05/06/20 12:43 AM
B
blufeb95 Online Content
Online Content
B
You shouldn't need to change it that often, the Manual says to inspect the fluid every 10k miles, you're just under 10k miles, they recommend changing the fluid every 20k miles or 24 months if you use the car to haul lots of stuff or drive it through mud a lot, If you're not using it in that kind of severe service I guess I'd just go until 30k miles.
Re: Time or Mileage? [Re: Averroes] #5422266 05/06/20 05:30 AM
L
Lubener Offline
L
Mileage not time on manual transmissions and differential lubricants.
The "thinking" man's friend.
Re: Time or Mileage? [Re: Averroes] #5422284 05/06/20 06:12 AM
B
Bogdon Offline
B
I did it at 75,000 miles on a 2006 Sentra Spec V. Haven't noticed any before and after differences. I used the specified Nissan manual transmission fluid for that car. Price wise, I didn't find it to be much more than the others.
Re: Time or Mileage? [Re: Lubener] #5422522 05/06/20 10:14 AM
N
nwjones18 Offline
N
+1
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Time or Mileage? [Re: Averroes] #5424208 05/08/20 03:48 PM
A
Averroes Offline OP
A
Thanks for all the replies, they are greatly appreciated. Any additional input would be welcomed as well.
Synthetic or bust.
