I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
21 registered members (dishdude, csandste, dave1251, dubber09, clinebarger, carlprop, 2 invisible), 1,202 guests, and 35 spiders.
Topics306,032
Posts5,285,235
Members71,566
Leaf spring surface rust #5422211 05/06/20 01:16 AM
O
OilUzer Offline OP
O
Is it bad to spray anti rust like Rust-Oleum on leaf springs to prevent rust?
I've had a very good luck with some WD-40 under running boards, etc. little spray once in a while ... most likely not a good idea to spray the leaf springs with.
Re: Leaf spring surface rust [Re: OilUzer] #5422216 05/06/20 01:24 AM
T
TmanP Online Content
Online Content
T
Why not Fluid Film or Krown? I'd use something designed for rust resistance... (Probably not a rubberized coating, but an oil-based spray).
Does the vehicle ever see road salt in WA? If not I'd not be awfully concerned, but FF or similar could only help.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Leaf spring surface rust [Re: TmanP] #5422221 05/06/20 01:57 AM
O
OilUzer Offline OP
O
I am on the west side and it doesn't get that cold here. some nights they spray salt brine on the roads but 2 days later it's washed off by the rain. the brine is dry shortly after spray (I've touched it while walking the dog) but I'm sure right after a little rain or moisture it can be nasty. I assume in a liquid form, it can go anywhere under the car.
Overall salt is not a major issue on the W. side of the state. E. Side gets pretty cold and lots of ice & snow.
Re: Leaf spring surface rust [Re: OilUzer] #5422260 05/06/20 05:17 AM
CourierDriver Offline
Some folks are gonna get ulcers over this...…………….. crackmeup
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
No matter what time it is,its always time for a nap
Re: Leaf spring surface rust [Re: OilUzer] #5422263 05/06/20 05:22 AM
PimTac Offline
The stuff most locales use here is not salt but some sort of calcium preparation if I recall correctly. You’ll see those lines on the road. They are afraid that the salt will wash into the Puget Sound and make it saltier. 🙄
I wouldn’t do anything. Surface rust is normal.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Leaf spring surface rust [Re: PimTac] #5422270 05/06/20 05:44 AM
O
OilUzer Offline OP
O
Yes, those lines are brine. It's a mixture of rock salt (sodium chroride) and magnesium chloride and/or calcium chloride dissolved in water for spraying ... From what I've read, it's worst than just salt or sand because the liquid coats every nook and cranny under the car. It's a nasty stuff.
Re: Leaf spring surface rust [Re: OilUzer] #5422277 05/06/20 06:05 AM
P
Phishin Offline
P
Corrosion X HD. That's all you'll never need. You can get it on Amazon.
Stuff is ridiculously good.
https://www.amazon.com/Corrosion-X-90102-Anti-Corrosion-Lubricant-16-Ounce/dp/B003HFTI0S/
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Leaf spring surface rust [Re: CourierDriver] #5422297 05/06/20 06:24 AM
F
FT92 Offline
F
for sure ….lol
Re: Leaf spring surface rust [Re: OilUzer] #5422316 05/06/20 06:48 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
There is no problem applying a coating to leaf springs. It can only help prevent corrosion.
Re: Leaf spring surface rust [Re: OilUzer] #5422339 05/06/20 07:20 AM
supton Offline
I tried using FF on my leaves and still lost them. From what I can tell, Tundra uses low quality springs. So as they say... YMMV.
Back when mine went, a few people wondered if something tacky like FF might trap sand between the leaves, where it could be come a lapping compound. Dunno.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Leaf spring surface rust [Re: TmanP] #5422345 05/06/20 07:26 AM
Donald Offline
+1
2015 Ford F-250 w/Powerstroke
Re: Leaf spring surface rust [Re: OilUzer] #5422357 05/06/20 07:44 AM
Z
Zaedock Offline
Z
Nothing wrong with painting leaves and using FF. I do both and they look like new on an eight year old West Mass truck.
I'd be more concerned about the shackles. Mine get the same treatment as the leaves. I have replaced quite a few on customers trucks.
I also replaced quite a few spring mounts (riveted to the frame) which mostly seemed to happen to Ford Rangers around here. Luckily, my Matco air chisel slices through rivets like a hot knife through butter.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Leaf spring surface rust [Re: OilUzer] #5422376 05/06/20 08:08 AM
Z
Zaedock Offline
Z
I read the comment regarding sand/dirt between the leaves. My springs have friction pads, but I just ran out to look and apparently I did not spray between the leaves, just the outside. I didn't see any weirdness with sand getting stuck between the leaves if there is any overspray.
Re: Leaf spring surface rust [Re: PimTac] #5422408 05/06/20 08:39 AM
Donald Offline
They put liquid brine down before the storm and salt/sand mix during or after the storm.
Sometimes the storm never happens but the brine was put down anyway.
At work they have put down a brown liquid that smelled like cow manure. Did not want to slip and fall on some of that stuff.
Re: Leaf spring surface rust [Re: Donald] #5422492 05/06/20 09:42 AM
PimTac Offline
New York is its own country the way they do stuff there.
The brine stuff here works great if put down before it freezes. Timing is the key. Once a heavy snow falls it doesn’t matter anyway. The roads are full of wild spinning vehicles with panicky drivers. Even a light dusting starts the chaos.
2017 Mazda CX5
Roki OEM filter.
